| Review by GarageWoodworks | posted 57 days ago | 524 views | 0 times favorited | 7 comments | ![]() |
Initial Set up My TS-Aligner Jr. arrived with the instruction video and manual in a foam case. Each component of the TS-Aligner has it’s own home in the foam insert.
The manual was easy to read and understand. The video (DVD) that was included was also put together nicely. It goes through the capabilities of the device (some I never even thought of). I think it will serve as a nice reference to refer back to later.
One of the features of the TS-Aligner Jr. that I really liked was how nicely it fit in my miter slot. The bottom of the TS-Aligner Jr. base has three bearings with an adjustable middle bearing . The middle guide bearing was easily adjusted using one of the provided allen wrenches.
It also traveled the length of the slot very smoothly. After having miter gauges that behaved sloppily in the miter slot no matter how much I adjusted them, I was VERY impressed with how nicely it performed in the miter slot.
Once the middle guide bearing was adjusted there was absolutely NO play in the miter slot.
Alignment Capabilities
First I placed the tool in my miter slot and moved the TS-Aligner Jr. into my table saw blade until both points made contact with the blade. Very subtle changes in the angle of the blade are represented by big movements in the dial indicator reading. Therefore it allows for very accurate adjustments.
I was able to quickly and accurately align my blade to 90° without having to sight down a square placed against the blade (traditional method).
I next tried to align my blade to 45°. In order for me to get my blade exactly at 45° according to the dial indicator reading, I had to adjust my positive stop on my table saw (which means it was set up incorrectly the whole time I have owned this saw.).
Angles in between 45° and 90° are also a cinch to adjust accurately using the TS-Aligner Jr. On the back of the instruction manual is a “tangent table” that allows you to adjust the blade tilt to the desired angle by making adjustments until the dial indicator reads the appropriate distance value on the table. This is based on basic trigonometry for a right triangle. In my opinion this is the real ‘meat and potatoes’ of the device and what makes this device indispensable.
I next checked the alignment of my table saw blade for parallel with the miter slot. This is done by zeroing the indicator at the front of the blade and then moving the TS-Aligner Jr. to the back of the blade and re-measuring. If the indicator does not read zero at the back of the blade than your blade is NOT parallel. My blade is off by 0.006”. The manual states that as little as 0.005” can adversely affect the quality of your cuts. I will need to adjust my table saw. This is a problem that I never knew existed until now.
In order to check the alignment of other tools such as a jointer fence, you need to remove the three bearings on the bottom of the device which are attached with allen bolts. This was easy to do and very straight forward. In order to keep the plunger of the TS-Aligner Jr.’s perpendicular to the jointer fence, it is recommended that you use a square.
What is really nice about the tool is that I can set my table saw blade to any angle in between 45o and 90o and than take the device over to the jointer and set the exact same angle quickly and accurately.
Another utility for the TS-Aligner Jr. that I think is a huge plus is the ability to quickly and accurately align my miter gauge to 90° to the miter gauge slot. The old way I would do it was by using the 5-cut method. This method is time consuming and wastes plywood! First you have to attach the stylus offset which was very straight forward. Next place a square against your miter gauge and zero the dial indicator with the TS-Aligner Jr. at the top of the square. Next slide your miter gauge forward until the TS-Aligner Jr reaches the bottom of the square. If your indicator does not read zero than your miter gauge is not calibrated correctly.
My miter gauge was not correctly aligned to 90° when positioned at 90°. All that would be required is to adjust my miter gauge until the forward and backward positions were in agreement according to the dial indicator. This method saves a huge amount of time and is more accurate than performing the 5-cut method. I can now have my miter gauge calibrated before I would of had the second of the 5-cuts made using my old method. Plus the TS-Aligner Jr has the added advantage of being more accurate.
Aside from calibrating miter gauges, the TS-Aligner Jr. can align your table saw rip fence parallel with the miter slot. This is done by placing the TS-Aligner Jr. at the front of the rip fence and zeroing the dial indicator. Next move the TS-Aligner Jr. to the back of the rip fence and if your reading deviates from zero, your fence is NOT parallel.
My rip fence was off by 0.004” from front to back. My rip fence tilts to the left from front to back. All I need to do is adjust my rip fence until the measurement in the back of the rip fence measures zero. This is a lot less time consuming than the method I use to use, which was by performing test cuts. I use to rip off a strip of plywood and measure with a caliper the width of the cut off from the front and back of the strip of wood. The difference between the two measurements is correlated with how far from alignment your table saw rip fence is. The TS-Aligner Jr. makes the rip fence alignment process much easier.
Another useful feature of the TS-Aligner Jr. is the ability to use it as a height gage using the included upright bar. Once the dial indicator is zeroed at the router plate, the height of the router bit can be determined with great accuracy.
This completely eliminates the need to make ‘test cuts’ to determine the height.
Hope you enjoyed my review.
Most of this review was copy and pasted from my website. You can find a more complete review here on my website.
This review was also performed using my old Delta contractors saw. I have since upgraded to a PM2000.
No affiliation, just a very satisfied enduser.
-- -Brian of High Point, NC (http://www.garagewoodworks.com)
7 comments so far
Chris
home | projects | blog
1140 posts in 434 days
posted 56 days ago
Great review… Looks like a nice tool to have if you use any machinery.
-- Chris
PurpLev
262 posts in 91 days
posted 54 days ago
Thanx for the review – very insightful. looks like this aligner has many uses that most others do not. I like having versatile tools that do various operations rather than have 10 tools for each… I am definitely in the market for an accuracy measuring device and from this review It looks like I know which one to get!
-- My Drinking Club has a Woodworking Problem...
sIKE
442 posts in 197 days
posted 52 days ago
Looks like a very useful tool. I might just go out and get e one. Thank for the informative review. They take allot of time to do and us LJ’s really appreciate it when someone sits down and does one with the depth of information this one provides.
Tony
549 posts in 473 days
posted 51 days ago
Great review and a few good tips on alignment
thetimberkid
1373 posts in 146 days
posted 51 days ago
Great reveiw!
Thanks for the post
Callum
-- There is no such thing as a mistake....just a design modification Check out my site http://thetimberkid.blogspot.com/
Tony - Memphis
1 post in 25 days
posted 25 days ago
Wow Brian, we might be related! I’ve been using a TS Aligner Jr for a while. Nice tool. Still learning how/what to use it. And, I just wheeled my new PM2000 in the shop over the weekend to replace my old Delta 34-444. But wait, there’s more….my parents live in High Point. I’m orginally from Goldsboro.
Tony – Memphis
GarageWoodworks
58 posts in 66 days
posted 25 days ago
Tony,
That is funny! I use my TS-Aligner Jr 3-4 times a project session. It gives me piece of mind to know that my miter gauge is perfectly square before cross-cutting expensive lumber. OR that my jointer fence is on target before squaring a leg.
You are going to love your new PM2000. I bought mine to replace a Delts 34-600 contractors saw. Maybe your my long lost twin my parents didn’t know about.?.?
