Harbor Freight Digital Mini Moisture Meter
Review by Jerry posted 03-29-2014 05:28 PM 4452 views 0 times favorited 16 comments Add to Favorites Watch
Harbor Freight Digital Mini Moisture Meter No-picture-s No-picture-s Click the pictures to enlarge them
http://www.harborfreight.com/digital-mini-moisture-meter-67143.html
Again another stunning value from Harbor Freight $12.99 for something that measures moisture in wood, masonry, and doubles as a centigrade or fahrenheit thermometer. Compare this to 25 or 30 bucks elsewhere.
-- There are good ships and there are wood ships, the ships that sail the sea, but the best ships are friendships and may they always be. http://www.geraldlhunsucker.com/
View Jerry's profile
Jerry
2890 posts in 1847 days
16 comments so far
View Woodknack's profile
Woodknack
12430 posts in 2579 days
#1 posted 03-29-2014 07:11 PM
How is the battery life? Does it auto-shut off?
View NormG's profile
NormG
6283 posts in 3203 days
#2 posted 03-29-2014 07:51 PM
Thanks for sharing. I was looking ofr one and did not know HF had one. It will work for what I need it to
-- Norman - I never never make a mistake, I just change the design.
View Dallas's profile
Dallas
3599 posts in 2686 days
#3 posted 03-29-2014 08:00 PM
I’ve had that model since about 2011 and it’s still on it’s first set of batteries.
Seems plenty accurate to me.
117328 posts in 3776 days
#4 posted 03-29-2014 09:08 PM
Thanks for the review,interesting find.
Jerry
#5 posted 03-29-2014 09:52 PM
RE Rick M.: According to Dallas the batteries have lasted three years for him, and yes, it does auto shut off.
View Mark Davisson's profile
Mark Davisson
597 posts in 3516 days
#6 posted 03-29-2014 10:21 PM
I’m with NormG – didn’t know HF carried them!
-- I'm selfless because it feels so good!
View Roger's profile
Roger
20952 posts in 3003 days
#7 posted 03-30-2014 12:16 AM
Thnx for your review Jerry. HF has some diamonds in the ruff.
View rance's profile
rance
4266 posts in 3359 days
#8 posted 03-30-2014 12:32 AM
And don’t forget the two rules of buying at HF:
1) Always use your 20% off coupon.
2) Always get a free flashlight(or multimeter, or whatever)
Nice review. I’ll probably pick one up tomorrow.
View Stephenw's profile
Stephenw
273 posts in 2584 days
#9 posted 03-30-2014 03:09 PM
I’ve got one I purchased about a year ago. I haven’t used it much. I just took it out and found the batteries were still good.
It is pretty dry in Utah.
I’m getting 0% on dry wood stored inside.
I’m getting 7% on wood that spent the winter outside.
It would be nice to compare this tool against an expensive model.
Jerry
#10 posted 03-30-2014 08:04 PM
Stephenw, that is a great idea! If any lumberjocks out there have both, it would be an interesting test. I’m going to take this to the local wood shop and see if I can run a comparison against their store model when I’m there the next time I go.
View Big_Bob's profile
Big_Bob
173 posts in 3908 days
#11 posted 04-01-2014 06:10 AM
I have used the same tool for about 4 years and I just had to replace the batteries. Radio Shack wanted $16 for the batteries. So I went back to Harbor Freight and for $4 got new batteries. It should be good for another 4 years. And yes it has an auto shutoff. It works well I keep it hanging on my lathe.
-- Bob Clark, Tool Collector and Sawdust Maker
View Randy_ATX's profile
Randy_ATX
880 posts in 2641 days
#12 posted 04-01-2014 03:44 PM
The above comment at 0% MC makes me wonder about it’s accuracy.
-- Randy -- Austin, TX by way of Northwest (Woodville), OH
Big_Bob
#13 posted 04-03-2014 05:36 PM
Randy:
I use mine for woodturning. I am told you are safe finish turning at 10% I have never had a problem turning wood that read 10% or less using this meter. The meter only reads down to 8% lower than that it is below its range. But who cares below 8% is dryer than anyone would ever need for woodworking.
View Delain's profile
Delain
38 posts in 2123 days
#14 posted 04-16-2014 12:03 PM
I recently bought this meter and have been testing with a few wood types in my shop. Most of the wood I stick it with shows some sort of % reading. However, when I test some cherry rough boards I’ve had ‘stickered’ for about two months, it reads 0%. Seems hard to imagine it wouldn’t show something above 0%. Is it feasible to expect a zero content in wood that’s just been laying in your garage/shop versus systematically dried? Or is it characteristic of cherry?
Tested it also by spritzing some water on the cherry and then it will read from about 11% to 17%. On the same piece a few inches down from the damp spot it will again show 0%. This seems to say the meter works okay; just not sure how well.
Another thought, I haven’t tested any pieces where the meter showed a range of say 2% to 5%; always seems to read either 0% or from 6% to 17%. Not sure what to make of this, but I don’t have another means of comparing.
Based upon comments here and within the other two reviews I’ve seen so far, I think this is an excellent buy for the price and seems to be dependable enough.
Thoughts?
Delain
Jerry
#15 posted 04-16-2014 03:03 PM
As big bob mentioned anything lower than 8 percent is out of range
