Glad I Bought This Sanding Detailer
Review by Pie posted 02-04-2014 01:47 AM 2429 views 1 time favorited 3 comments Add to Favorites Watch
Glad I Bought This Sanding Detailer No-picture-s No-picture-s Click the pictures to enlarge them
The Sanding Detailer is ideal for finishing those hard to reach areas. The abrasive belt can be indexed. The Sanding Detailer is spring loaded to put tension on the abrasive belt. After the abrasive belt is used up, simply compress the tool and replace the abrasive belt with a fresh one. They are color coded for easy identification of grit.
So my wife and I walk into the local WoodCraft store for some scroll saw blades.Since I scrol saw and was looking for some small sanding files. Head over to the sand paper section and notice this Sanding Detailer kit. Hmmmmm it looks good but I’m not sure if I want to pull the trigger and spend the $25 for somethig I could use but don’t really need. As I am standing there trying to convince myself in my mind, my wife speaks up and tells me to go ahead and get it. I sure am glas I listen to her cuz when I got home I needed them and I have to say, they really works well. Rotating the sandpaper for as you use is super easy, just move your thumb or finger onto the sandpaper and pull down. The kit comes with 5 refills. I have used all 4 different grits and have a lot of use on them still. I like these because you can apply pressure where you need to and it gets into places that would be difficult other wise.
-- Pie
View Pie's profile
Pie
187 posts in 3401 days
3 comments so far
View ellen35's profile
ellen35
2738 posts in 3428 days
#1 posted 02-04-2014 11:33 AM
I also bought a set of these. I find them incredibly useful and the “quick change” sanding area is very convenient. I have used them innumerable times over the last month and find myself reaching for one when I need to sand a small area.
View cutworm's profile
cutworm
1075 posts in 2789 days
#2 posted 02-04-2014 10:23 PM
Nice, got to have.
-- Steve - "Never Give Up"
View ic3ss's profile
ic3ss
389 posts in 2773 days
#3 posted 02-05-2014 08:51 PM
Agreed. I use mine frequently.
Wayne
-- "I am endeavoring, ma'am, to construct a mnemonic memory circuit using stone knives and bear skins."
