Great for general construction!
Review by smitdog posted 01-30-2014 03:56 PM 3359 views 1 time favorited 13 comments Add to Favorites Watch
Great for general construction! No-picture-s No-picture-s Click the pictures to enlarge them
I picked up this blade about 4 months ago while in the middle of a remodeling project. I have the el cheapo 12” sliding miter saw from HF and I still had the original blade on it that came with the saw, which is absolute junk. I had not really cut much on it and it was so dull that it was burning through things more than it was cutting! I could get it through a modern 2×4 with some effort but it was getting ridiculously dangerous to cut anything on it. The wall we were cutting was mostly made up of 100 yr old pine that might as well have been petrified wood! Had to pre-drill holes to get screws or nails to go in without breaking, this stuff was HARD! Needless to say, the dull blade would barely scar the surface of this stuff.
Well, on went the new Marples 40T blade I picked up at the local Lowes for under $40 (I figured the 40T would be better for this kind of rough work plus it was the cheapest). This blade sliced through that old pine like a hot knife through butter! Literally almost no extra pressure required to bring the blade down through 2.5”x4” (actual dimension) of extremely hard old pine. The saw now cuts better than it did when it was brand new, I actually enjoy using my miter saw once again. I have not used this blade for anything other than construction grade materials, no hardwood unless you consider the rock hard pine as hardwood :) I had even hit a couple of nails in the old stuff and the saw never slowed down, actually sliced the nail clean down it’s length for about 1.5 inches. I was worried that it may have chipped or broken off a tooth, but I couldn’t see anything by eye and it still cuts like a dream.
PROS:
Inexpensive! – $38 bucks right now online at Lowes
Easy cuts – Cuts through everything lightning fast with no effort. Made my cheap HF miter saw a joy to use
Large carbide – can definitely be resharpened a few times
Cuts everything – I have sliced up 4×6 treated posts, 2×12 treated pine, 3/4 ply, and the infamous 2 1/2×4 ancient pine in the remodel. All “like budda”.
CONS:
Tearout – This was expected with a 40T blade, it’s for general construction and not really intended for trim work or fine carpentry so I’m not marking off for it.
Overall I couldn’t be happier with this blade. I had heard good things about the 10 inch blades for table saw use and I thought I’d give the 12 incher a shot and I’m sure glad I did. I like it so much I’m going to buy the 80 or 96 tooth version for fine work and a 10 inch for the TS as soon as funds allow.
-- Jarrett - Mount Vernon, Ohio
View smitdog's profile
smitdog
415 posts in 2341 days
13 comments so far
View b2rtch's profile
b2rtch
4868 posts in 3284 days
#1 posted 01-30-2014 04:43 PM
I use the 50T combination, which is also a good blade
-- Bert
View lumberjoe's profile
lumberjoe
2899 posts in 2484 days
#2 posted 01-30-2014 04:49 PM
For the same price you can get the 50 tooth which cuts soooo much cleaner
View Ripthorn's profile
Ripthorn
1459 posts in 3221 days
#3 posted 01-30-2014 05:13 PM
I have the higher count 12” blade, and it cut so much better than the stock dewalt blade on my saw, a lot less tearout and less noise. I agree that it is a steal of a deal. I ended up getting the 50T 10” blade for my table saw, but it has not given me the same performance as the Delta blade I had on it (which needs a resharpening).
smitdog
#4 posted 01-30-2014 06:10 PM
I did not see a 50 tooth option in the 12”, are you thinking 10” 50T by chance or is there a 12” version? The 40T worked fine for 2×4s though so I’m happy. I am planning on getting the 50 tooth combo 10” for my table saw though.
View MT_Stringer's profile
MT_Stringer
3183 posts in 3467 days
#5 posted 01-30-2014 08:56 PM
I have the 10 inch 50T on my table saw. Works great, crosscut or rip.
View lab7654's profile
lab7654
266 posts in 2483 days
#6 posted 01-31-2014 12:11 AM
I agree with everything said; these blades are the best value I’ve found. My 50T combo blade never comes off the table saw when I’m working with most things. I’ll swap it for a cheap 40T blade if I’m working with questionable stuff though, just so I don’t risk losing the glass smooth cuts from the Marples. Next blade purchase will probably be a 24T Marples for long rips.
-- Tristin King -- When in doubt, sand it.
View Picklehead's profile
Picklehead
1053 posts in 2165 days
#7 posted 01-31-2014 02:55 AM
I have the 80 tooth Hi-ATB. Very nice performance for $53.
-- Quote from ebay tool listing: " Has nicks and dings wear and tear dust and dirt rust and pitting but in good working condition"
smitdog
#8 posted 01-31-2014 01:52 PM
Picklehead – I’m pretty sure that’s the one I’ll get for precision work, how is it with tearout? I’ll make a zci insert for the base and I use a backer fence for the really picky stuff so I’m thinking the 80 tooth will work just as well as a higher tooth count blade.
Picklehead
#9 posted 01-31-2014 03:50 PM
It’s very good with tearout. With a zci and backer fence you should have no issues. It does have a positive hook angle, pretty low, 10 degrees I think. I know you want negative hook angle for a miter saw, but at least it’s not too aggressive. The high angle of the top bevels helps a lot, and it’s really sharp, like “accidentally poke a hole in your finger while handling it” sharp. (Just noticed you’re talking about 12 inch blades, mine is 10 inch)
View dbhost's profile
dbhost
5767 posts in 3468 days
#10 posted 01-31-2014 04:32 PM
Looks like the Irwin Marples line is positioned as a decent competitor to Freud’s Diablo blades…
Does the blue stuff on the blade transfer to the piece being cut? My diablo blades sometimes do that and it annoys me to no end…
Picklehead
#11 posted 01-31-2014 04:42 PM
No blue paint transfer here. I should mention that the carbide tips on these seem extra wide/thick/beefy, which keeps your wood away from the paint (until you resharpen the blade enough to “disappear” all that carbide). They tout the extra carbide in the product info, and it would appear to be true.
smitdog
#12 posted 01-31-2014 05:09 PM
I haven’t noticed any blue on the wood either but I can’t say that I’ve paid that much attention either with only cutting 2×4s. I’ll keep my eye out next time I use it.
smitdog
#13 posted 11-12-2018 05:24 PM
Just in case anyone comes across this in a search – I’m still using the same blade 5 years later and have never had it sharpened. It still cuts anything I put on it, albeit with tearout. I do only use it for occasional construction grade work – I would never expect a 40 tooth 12 inch blade to do fine carpentry. But for what it is intended for, it works great!
