HF Aluminum bar clamp
Review by gamygeezer posted 01-27-2014 05:03 PM 21156 views 0 times favorited 34 comments Add to Favorites Watch
HF Aluminum bar clamp No-picture-s No-picture-s Click the pictures to enlarge them
Heat wave yesterday! All the way up to 57F! So I decided to go shopping. I rinsed off the sawdust, trimmed the ear hair, unclogged the sink and cranked up the old DRam. I went to Harbor Freight to check on the locking casters reviewed recently, but really had to browse the whole store.
I found a rack of aluminum bar clamps almost exactly like the ones I really like from Jorgensen. Had to get one (or so) of course. I picked the “36 inch”, a handy size, which actually has only a 32 inch capacity (minus a star for that). They had four sizes from “24 inch” to “60 inch”. “Life time warranty” Made in China.
Catalog info: http://www.harborfreight.com/36-aluminum-bar-clamp-60539.html
Comparison with Jorgensen:
Aside from the color difference, the heads are identical. Handle is longer on the HF clamp. The Jorgensen head is riveted on, the HF has what looks like an automotive push fastener.
The tail pieces are also the same. Both have the same fastener. In this photo you can see that the HF bar has a slight reveal down the side, so there might be a little less aluminum in the bar. The bar dimensions are the same, except for the length.
I got the 32” clamp for 10.99, the 24” Jorgensen is 24.97 at my HD.
I have used the Jorgensen clamps for about eight months and love them. Light weight, non-staining, and strong enough for all my glueups. If you resist “Made in China”, there are very similar ones made in the USA available at http://toolsforwoodworking.com/.
EDIT
Of course CharlesA and LJ are right, a review of clamps should show some clamping going on. The primary use for clamps is to pull glue joints together, especially problem joints. When I think of problem glue joints, I naturally think of Southern Yellow Pine, the most contrary wood I’ve ever met.
So I rummaged around in the garage, found a short 2X8, ripped into 3 and 4 inch widths, and watched as it relaxed into a classic crooked mess. I clamped one end together with my strongest 12” bar clamp and measured the gap at the other end at 5/16 inch.
This is my test bed. I then clamped the other end, first using the HF clamp and then a pipe clamp. Results shown below.
The clamps were both tightened to “thumb pain” pressure (very scientific here), which is the only measure I have. By the way, both clamps forced the other end to gap open against the bar clamp.
Thanks for your comments and patience.
-- What's a vibrant young guy like me doing in a broken down old body like this?
View gamygeezer's profile
gamygeezer
166 posts in 1819 days
34 comments so far
View CharlesA's profile
CharlesA
3355 posts in 2031 days
#1 posted 01-27-2014 05:11 PM
Did you see any difference in their clamping performance?
View Randy Sharp's profile
Randy Sharp
363 posts in 3906 days
#2 posted 01-27-2014 05:17 PM
Thanks for the review. I have a number of HF bar clamps and use them all the time. For simple glue-ups and pulling together mortise and tenon joinery, they work great for me.
I do notice some flex in the aluminum body, but that serves to tell me I’ve tightened up enough.
There is no pretense on my part that these are the same quality as the higher priced Jorgensen or Bessey, but I’ve not had one fail on me yet.
For the price, I’m happy with my HF choice and can heartily recommend them to the woodworking hobbyist.
-- Randy, Tupelo, MS ~ A man who honors his wife will have children who honor their father.
View mnguy's profile
mnguy
207 posts in 3632 days
#3 posted 01-27-2014 06:06 PM
I purchased what appear to be the same/similar clamp as the HF on a special from Lee Valley a few years ago. They were a set of (10) 24” clamps for cheap (don’t remember the exact price). The only major difference I see is that mine came with non-marring jaw pads. Mine have provided excellent service.
One plus for the Jorgensons is actually the shorter handle. The LV/HF handles hit the bench when turning; a shorter handle would actually be handier. Especially since I am not typically trying to crank up the pressure with these clamps. For that, I get out the parallel jaw or the pipe clamps.
View OggieOglethorpe's profile
OggieOglethorpe
1276 posts in 2343 days
#4 posted 01-27-2014 06:16 PM
One simple comment…
The Universal brand aluminum bar clamps, sold by TfWW, Woodcraft, and lots of others, are in a whole different league than either of the two clamps in the photos attached to this review.
I just thought I’d point that out… It’s not a simple China vs. USA sourced difference.
View carver1942's profile
carver1942
93 posts in 1938 days
#5 posted 01-27-2014 06:18 PM
Thanks for the review, gamygeezer.
I have a dozen of these clamps. I find they work great for glue ups. For the pressure needed for glue joints they don’t flex. If someone is clamping hard enough to flex them, there’s something wrong with their joint, plus a joint should not be squeezed so tight you end up with a dry joint. I own higher priced clamps, but these work just as good and enable me to own more clamps. You never can have enough clamps. I’m on a tight retirement budget and can’t always buy top of the line equipment. These clamps fit the bill.
gamygeezer
#6 posted 01-27-2014 06:32 PM
Barry, I have been eyeing those clamps from TfWW for quite a while. They are priced by the pair, and are thus really reasonable. Thanks for the observation. If I find I need more, especially 6 footers, I will certainly get them there.
Ken
View b2rtch's profile
b2rtch
4868 posts in 3282 days
#7 posted 01-27-2014 06:38 PM
I also have these clamps and I am also very happy with them
-- Bert
View Nicholas Hall's profile
Nicholas Hall
352 posts in 2340 days
#8 posted 01-27-2014 07:58 PM
Paul Sellers had a great post about these a little while back. He fills the cavity in the bar with a piece of wood to stiffen them up and give them more rigidity. It’s a pretty nice clamp for the money!
-- Outside of a dog, a book is a man's best friend. Inside of a dog, it's too dark to read. -Groucho Marx
View sgmdwk's profile
sgmdwk
308 posts in 2106 days
#9 posted 01-27-2014 10:43 PM
Like others here, I like these clamps because they provide a great value. I can collect a bunch of useful clamps for a fraction of the cost I’d pay elsewhere.
-- Dave K.
View whitebeast88's profile
whitebeast88
4128 posts in 2424 days
#10 posted 01-27-2014 11:00 PM
great review,i have 2-24” and 2-48”.so far am pretty satisfied with them especially for the price.i’ll be buying more when i go back to hf.
-- Marty.Athens,AL
View Larry's profile
Larry
24 posts in 2920 days
#11 posted 01-27-2014 11:56 PM
I have some of these in 48” and had one break just tightening by hand, probably a fluke, glad to know they have lifetime warranty, will take it back next trip. Otherwise I have been very satisfied with them, alot lighter than my pipe clamps.
View rrww's profile
rrww
263 posts in 2347 days
#12 posted 01-28-2014 12:37 AM
I have 48 or so of these. Hey – they are cheap. About 1 in 8 randomly break the casting near the base of the threaded end. Its annoying – it happens under very little pressure (one handed). I have had a couple guys crank them a little too much and the bar is very soft and can bend easy. Once this happens it bulges the sides of the clamp and the locking end can’t slid by the bulge very easy. In my opinion they are not as good as the premium brands. (But much cheaper) If it was me I would give three stars – just because the breaking is random. At this price I can’t really complain too much. They are great for most smaller glue ups, as long as you don’t try to force the wood with them.
View Craftsman70's profile
Craftsman70
244 posts in 2358 days
#13 posted 01-28-2014 06:24 AM
I got one…the casting broke with little pressure. I guess it was the 1 in 8. Maybe I’ll try another.
View lj61673's profile
lj61673
261 posts in 2633 days
#14 posted 01-28-2014 11:58 AM
Wow, all these comments about “great review”, did I miss something? Not one word about how the clamps actually work.
Is this a review about how they look? Or about how closely they resemble the Jorgensons?
This review section becomes more useless with each review like this one.
View rrww's profile
rrww
#15 posted 01-28-2014 12:13 PM
You must have missed something. To operate the clamp you adjust the stop to the proper width of your work piece then apply pressure by turning the handle to make it tighter. Most wood clamps operate in the same or similar matter. For any other details you can read what is written above. I hope that clears it up for ya…
showing 1 through 15 of 34 comments
