Some seriously slippery surfaces.
Review by BennyG posted 01-22-2014 06:46 PM 3916 views 3 times favorited 17 comments Add to Favorites Watch
Some seriously slippery surfaces. No-picture-s No-picture-s Click the pictures to enlarge them
This product is used to lubricate any surface in the shop where drag and hang ups across in feed/out feed tables, fences and the like are problematic. Used in place of silicone or other lubricants that would contaminate the woods/materials surface and create a build up of lube and sawdust on equipment and machinery.
I have used a similar more expensive product in a few of the larger production shops that I have worked in over the years and have seen first-hand the benefits of using a dry lubricant. Not only does it significantly reduce the amount of force required to move pieces through the machinery and equipment in the shop, it also greatly increases accuracy and most importantly increases safety by not having to “force” material through and across tables, blades, knives, bits etc.
Another benefit is that all of this is done without effecting the surface of the material when it comes time to finish your project. The solvent in PB Blaster’s Dry Lube evaporates almost immediately and leaves a white almost powdery surface. I have had NO finishing problems in my shop after almost 2 years of using this product. It is readily available anywhere PB Blaster product are sold and in my neck of the woods, Northeastern AZ, retails for $4.49 for a 9.3 oz. can at one of the big Home Improvement stores. The other similar product goes for anywhere just under $10 on one of the Big internet retailer to $15 + in some retail shops for a slightly larger 10.4 oz. can.
Give it a shot and see if you notice the benefits I have described. You may find yourself reaching for a can every time you fire up your tablesaw, planer, jointer, shaper, dovetail jig etc. Thanks for taking the time to read my review.
-- "Dear Lord, when I die, please let my wife have enough sense to sell my tools for their true value and not for what I told her I paid."
View BennyG's profile
15 posts in 1833 days
17 comments so far
View smitdog's profile
327 posts in 2038 days
#1 posted 01-22-2014 08:40 PM
I’m going to have to check my local stores to see if I can find this. I love all the Blaster products and I was wondering if they made a dry lube. Thanks for the review, it’s appreciated.
-- Jarrett - Mount Vernon, Ohio
View vskgaming's profile
83 posts in 1548 days
#2 posted 01-22-2014 09:06 PM
+1 on PB Blaster dry lube, i use it a lot too. Comes in handy for using in a swivel and pipe vise.
View JoeinGa's profile
7733 posts in 1940 days
#3 posted 01-22-2014 10:06 PM
PB Blaster makes several good products. Havent tried this one yet, but I will definitely give it a go.
View Mainiac Matt 's profile
Mainiac Matt
7800 posts in 2261 days
#4 posted 01-22-2014 11:49 PM
Going to have to check it out.
Is it a dry Molly?
-- Pine is fine, but Oak's no joke!
#5 posted 01-23-2014 01:31 PM
Hello Maniac, it is a PTFE base or as it is more commonly know, Teflon. Thanks to everyone for the comments.
View doubleDD's profile
7219 posts in 1976 days
#6 posted 01-23-2014 01:59 PM
Yes, good stuff.
View b2rtch's profile
4851 posts in 2981 days
#7 posted 01-23-2014 03:35 PM
Thank you for the review, I shall try it.
Do you use it on your cast iron tables?
-- Bert
View Woodknack's profile
11308 posts in 2313 days
#8 posted 01-23-2014 05:16 PM
I will definitely be looking for this.
-- Rick M,
#9 posted 01-23-2014 08:39 PM
B2rtch, pretty much anything that needs some “motion lotion.” The smother the surface the better performance you are going to get.
View woodcox's profile
2014 posts in 1945 days
#10 posted 01-24-2014 02:08 AM
Good review. I love this stuff. Another use I have found for it and other dry lubes, is applying it on car window and door weather stripping. It keeps them from freezing. I’m an automotive technician and I fix a lot of broken window regulators this time of year. Post repair I put it on customer’s cars and recommend it for them in the future. I also use it on my face vise screw. No more greasy wood.
-- "My god has more wood than your god" ... G. Carlin.
View woodchuckerNJ's profile
1261 posts in 1567 days
#11 posted 01-24-2014 02:42 AM
Thanks, that’s a good heads up.
It would be perfect for trunions and other lubes too.
-- Jeff NJ
View Dusty56's profile
11819 posts in 3621 days
#12 posted 01-25-2014 12:30 AM
Haven’t noticed it yet locally, but I will certainly look closer in the stores from now on.
Thanks for the nice “time tested” review : )
View hunter71's profile
3127 posts in 3119 days
#13 posted 01-26-2014 12:17 PM
Best penetrate I have ever used.
-- A childs smile is payment enough.
View Picklehead's profile
1041 posts in 1862 days
#14 posted 01-26-2014 12:32 PM
I got some based on your review. HD had it (hey, can I get fewer ads now?) but Lowes did not.
-- You've got to be smarter than the tree.
View NormG's profile
5900 posts in 2936 days
#15 posted 01-27-2014 01:48 AM
Wow, more tools for the arsenal
-- Norman - I never never make a mistake, I just change the design.
