Rust Preventive
Review by OSU55 posted 01-17-2014 04:21 PM 3368 views 3 times favorited 2 comments Add to Favorites Watch
Rust Preventive No-picture-s No-picture-s Click the pictures to enlarge them
In my research for rust preventives for tools and firearms I came across a product called Alox, originally developed many years ago for naval ship applications. It is widely used in commercial/industrial applications but is not readily available to the consumer except as this product, Liquid Alox by Lee Precision, manufacturer of reloading equipment. Lee sells this for a lubricating coating for cast lead bullets, but it is the same calcium soap based alox used as a rust preventive. It is available on Amazon for ~$11 for 4 oz, enough to make about 3 quarts, probably enough to last a lifetime.
In the bottle it is a thick, dark brown gel. It can be reduced with mineral spirits or naptha (naptha is available at home builder stores). I reduce it maybe 15-20:1 with naptha in a small spray bottle. It will settle out overnight, but stirring or shaking the bottle suspends it back into solution. Spray a little on, spread around with fingers or a paper towel and let the naptha flash off. It dries to a somewhat hard, dry, thin film haze on the parts which can be buffed if desired. It is more durable than most rust preventives, and is not noticeable on the surface if buffed. It’s easily removed with mineral spirits or naptha. It works great for any ferrous materials, steel, cast iron, etc. I really like it for intricate shapes, like hand plane castings and blades, and the bottoms of cast iron tables on saws and jointers. I use furniture wax on the tops. I use it on firearms as well.
View OSU55's profile
OSU55
2033 posts in 2229 days
2 comments so far
View Mainiac Matt 's profile
Mainiac Matt
8621 posts in 2568 days
#1 posted 01-17-2014 09:06 PM
Who new that Lee’s “camel snot” bullet lube had other applications.
I use it on cast boolits, but now I may try it to prevent rust.
FYI, there’s a guy out there who sells an equivalent item for a lot less money under the name XLOX.
I guess he buys a drum of the industrial use stuff and then parses it out in pint size bottles.
-- I yam what I yam and that's all what I yam
View BigYin's profile
BigYin
421 posts in 2656 days
#2 posted 05-18-2017 05:08 PM
I gotta admit I never had rusty reloading dies and always used this stuff ….
-- ... Never Apologise For Being Right ...
