Laguna LT18 3000 Bandsaw - Very Solid Saw
Review by Woodwrestler posted 01-07-2014 02:59 AM 13748 views 0 times favorited 15 comments Add to Favorites Watch
 Laguna LT18 3000 Bandsaw - Very Solid Saw  Laguna LT18 3000 Bandsaw - Very Solid Saw  Laguna LT18 3000 Bandsaw - Very Solid Saw Click the pictures to enlarge them
I have read so many reviews trashing Laguna that I had a hard time buying one of their tools. However, after doing a ton of research I ended up buying the LT18 3000. I did a ton of sifting through various options. Almost bought a Rikon 18, Minimax S45 ( just waiting to hear the barrage of you should have bought the MM16 the mystical beast of all bandsaws ) and also took a hard look at the Felder N4400. Anyway, the wife liked the Laguna we saw at Woodcraft and that always makes things easier to pitch. Although, I can afford to buy any of them I still place limits on myself for practical reasons. Of course I walked through the forest looking for Grizzlies and almost got taken by one but alas Laguna won the day.
1) The saw arrived well packaged with no damage and bolted with four bolts to the pallet.
2) I wrestled it off the pallet myself after taking off the table, motor, box of blades, mobility kit, and other misc items. It was a bit of a bear but got it off without any problems. Put the mobility kit on the saw in about 10 minutes and had here stable and on wheels. I than proceeded to assemble the rest of the saw. I didn’t need to look at the instructions because I had watched a video online on assembling them and it is pretty idiot proof. All in all it took me about 1.5 hours to have the whole thing assembled an over into its designated spot in the shop. Another 1 hour reconfiguring my 6” PVC runs and 4” branches to hook it up.
3) Initial blade install and tuning the guides was about 10 minutes. I am a bandsaw novice so I had to do some learning here.
4) About 5 minutes later I took a 2X12 piece of SYP and sliced a 1/8” piece with the basic 1/2” blade. Didn’t bother to put on the Resaw King.
A couple of key things:
1) The saw table was perfectly flat. Not as much as a bit of light making through the straight edge.
2) Very little vibration at all when running and very quiet. Didn’t do a nickel test but it will pass with ease.
3) The guides are straight forward to use. I really really like their guides versus bearings. I am sure it’s just a personal thing but there it is. Side to side adjustments are via hand screws. Thrust bearing is done by allan wrench. The lowers take two different allan wrenches but are easy to reach and adjust. The saw tensions the blade very well and there is zero movement when cutting.
4) The cast iron wheels are very large and heavy. No they are not like the HD’s or MM16’s but I am sure they will provide the necessary umph I need.
5) Blade tracks very steady with not back and forth and no moving at all on the tires. Very easy to put the blade on and get it to track. I did not check the wheels for coplanar as I watched the “Carter Guides” guy give a very long video on setting up bandsaws and he was adamant that it doesn’t matter ( I cringe now waiting for the abuse from the crowd ).
6) I would anticipated blade changes taking about 2 minutes once I get some practice. That is acceptable for a guy in his garage.
7) The fence was dead square with the table and miter slots.
8) The table is 20” X 20” but on the left side it has 5.75” additional inches of steel. So you really have a 26 X 20 table. Plenty big enough. Also has two miter slots one on each side of the blade.
9) The brake does and acceptable job and stops the blade in about 5-6 seconds with moderate pressure. ( Here comes the Grizzly motor brake comments now ).
I guess my only Cons on the entire saw would be the blade guide and like I said in the grand scheme of things it is fine.
I used the saw all day long as a dedicated rip saw while I had my crosscut sled on the table saw. I ripped about 30 pieces of wood on the saw and for a 1/2” blade and moving the stuff through quickly it left very little rough edges and I could clean them up with 1-2 passes of the sander. I also cut about 5 pieces of SYP from the 2X12 about 1/16 – 1/8 inch and the saw tracked right through. Didn’t bother with drift adjustments yet.
As far as Laguna goes….. I spent a ton of time talking to their sales folks and they were nothing but responsive and followed through on all my requests. I initially ordered the LT14 SUV and than upgraded a couple days later on the same day it was shipping. They were very nice about the change and it all got taking care of promptly. Took a week to get it here in NC from CA and that includes New Years Day. I have talked with Laguna folks on many occasions and have never anything but the best service.
-- What man is a man who does not make the world a better place?
View Woodwrestler's profile
Woodwrestler
56 posts in 2386 days
15 comments so far
View Kaleb the Swede's profile
Kaleb the Swede
1881 posts in 2209 days
#1 posted 01-07-2014 11:46 AM
Great review looks like you got a super band saw. I’m extremely jealous with my little black and decker 10 inch saw. One day….
-- Just trying to build something beautiful
View JustJoe's profile
JustJoe
1554 posts in 2278 days
#2 posted 01-07-2014 02:35 PM
How could you not buy an MM16!!!??? (just kidding)
Good review. That’s a monster of a saw. Hopefully it lasts forever and you don’t have to test Laguna’s customer service.
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
View CharlesNeil's profile
CharlesNeil
2469 posts in 4110 days
#3 posted 01-07-2014 04:38 PM
I have the SUV 14 with a Resaw King blade as well ..I have 3 other band saw’s.. This is by far the best band saw I have ever owned, and the Resaw King blade is superb ..I just resawed some 8/4 cherry 13 1/2 ” wide, it went thru like butter.
I know their customer service has had some bad press, but my experience was like yours, Could not have been better . Just my .02
View Surfside's profile
Surfside
3389 posts in 2413 days
#4 posted 01-07-2014 10:05 PM
Wow! A good band saw. That should serve you well. Enjoy!
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
View rustfever's profile
rustfever
763 posts in 3550 days
#5 posted 01-08-2014 03:02 AM
Your experiences with Laguna 18 is exactly as I had with my Laguna 16.
My 16 is a dream. Easy to adjust and easy to keep in adjustment.
The people at Laguna are helpful. The owner of Laguna will bend over backwards to be helpful and professional.
I am sold that Laguna tools are of the greatest value. Beats the ‘Green’ tools every day.
Ira
Central Cal.
-- Rustfever, Central California
Woodwrestler
#6 posted 01-08-2014 03:13 AM
I agree. I like Laguna as a company and when I compared it to other saws it was much better.
View nwbusa's profile
nwbusa
1021 posts in 2526 days
#7 posted 01-08-2014 06:58 AM
Glad to see some others with positive Laguna experiences. I own several Laguna tools, including a bandsaw, and they provide me with excellent service.
Thanks for the review and enjoy your new saw!
-- John, BC, Canada
View BenR's profile
BenR
341 posts in 2868 days
#8 posted 01-09-2014 11:20 PM
Thank you for the review. I’ve been looking at the Laguna bandsaws for an upgrade. Sounds like I am on the right tract.
-- Ben in Va
View RodNGun's profile
RodNGun
118 posts in 2543 days
#9 posted 01-14-2014 12:42 PM
I have the same saw and could not more pleased. With the Resaw king blade it’s as good as it gets. Laguna people were fantastic, I stopped in their warehouse and they demoed a bunch of saws for me. Very happy with my choice.
View Fettler's profile
Fettler
200 posts in 2237 days
#10 posted 01-17-2014 09:32 AM
I own this saw; it vibrates horribly.. The Vibration is worst with a 1” resaw king:
http://m.youtube.com/watch?v=F6fnPsVxd8g
I don’t have the mobility kit. Laguna sent me a replacement saw, the second one is slightly better than the first. I did not enjoy my customer service experience at all.
The resaw king slices like butter but the vibration results in a very unclean cut. Just looking at your pictures I can tell you’re getting better results than me.
As for coplanar pulleys, check that your tooth edge (or back) is parallel with the table. Otherwise you’ll run into issues cutting curves.
-- --Rob, Seattle, WA
Woodwrestler
#11 posted 01-18-2014 01:30 PM
I guess the question begs to be asked, why would you keep a defective saw. I would have sent it back, called VISA and done a charge back if needed.
View Jacquelyn Smith's profile
Jacquelyn Smith
95 posts in 2807 days
#12 posted 02-21-2014 03:49 AM
I wish I had the 18 but I could only afford the 16. I didn’t know about LJ at the time I purchased mine so I had no idea so many of you are unhappy with Laguna. Interesting. I have had a fantastic time with my saw and I get crispy old woodworkers in my shop digging the heck out of my resaw work. I bought a few resaw kings and milled a bunch of LONG and WIDE Gon Callo Alves (Tiger wood) Jatoba and Wenge, I haven’t had any trouble.
Recently I had a few jobs doing more of this kind of resaw work but I didn’t have my resaw kings, just a 1/2” three tooth resaw blade. I did it, beautiful, consistant, four boards out of one.
Seems like no matter what tool is out there someone always gets a crapper. I’m very glad it wasn’t me.
-- perfect45degree.com
View Antlers's profile
Antlers
7 posts in 951 days
#13 posted 06-15-2016 04:53 PM
How do you feel about your saw now, a couple years later?
Woodwrestler
#14 posted 06-15-2016 06:20 PM
Still love the saw. Same criticism is the blade guard having to be pulled off to change blades. Otherwise its a great saw and I have had no issues with it.
View BitXBit's profile
BitXBit
1 post in 728 days
#15 posted 01-23-2017 02:49 PM
I have a question I am hoping you can help me with. What are the dimension of the base. I plan on fabricating my own mobile base.
Thank you,
Paul
