Brilliant!
Review by SchotterWoodworking posted 12-29-2013 11:03 PM 3387 views 2 times favorited 8 comments Add to Favorites Watch
Brilliant! No-picture-s No-picture-s Click the pictures to enlarge them
My first experience spraying Minwax Polycrylic has been outstanding: thins and sprays better than oil based poly, no flammable fumes, easy to clean up and looks great. The biggest downside: sanding! The grain is raised twofold using the water based, plan on using 220 to knock down the first bristles and 400 to finish. I’m sold.
View SchotterWoodworking's profile
SchotterWoodworking
113 posts in 3266 days
8 comments so far
View JustJoe's profile
JustJoe
1554 posts in 2274 days
#1 posted 12-30-2013 12:30 AM
Hi. I just got a small sprayer this month and I’m looking to finish some boxes, but Minwax and “outstanding” aren’t two words I usually hear in the same sentence. Do you have a pic of a finished project that you sprayed?
What did you thin it with, and what ratio? And what do you mean with the sanding bit? Is it just a matter of water-base raising the grain with the first coat, or do 2nd/3rd/13th coats not go on smoothly?
And what’s the finish look/feel like – glass, plastic, richly oiled wood, somewhere in between?
thanks.
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
View mcase's profile
mcase
446 posts in 3365 days
#2 posted 12-30-2013 12:39 AM
I use this a lot and it can look great. I sand it with a 600 grit wet and then wax it and the finish is nice. There are some limitations you might want to keep in mind. It is not a very tough finish and is not suitable for a table top say. It also can absorb stains from simple handling. I made a set of kitchen cabinets (for myself thank heaven) and found that after a couple of years that it darkened and looked greasy around the knobs were people came into contact with it. These darkened greasy looking areas would not clean up as it was really absorbed into the finish. Also any grease spills tend to darken stain it. Another area where it did not hold up so well was on the wood trim near the sink. Water seem to get through it too and darken the wood. So its not the most resistant of finishes. I still use it on the sides of cabinets and areas that take less abuse, but never on the doors or any parts that actually get touched or wet.
View jumbojack's profile
jumbojack
1685 posts in 2860 days
#3 posted 12-30-2013 02:45 AM
I think, even after this sparkling review, I’ll stick to my smelly, flammable lacquer.
View TheOldTimer's profile
TheOldTimer
226 posts in 3322 days
#4 posted 12-30-2013 04:25 AM
I am not a great fan of this product. That said, I do use water base finishes 90% of the time on all projects. If you want to keep the grain from raising and to keep the stain from bleeding, use a 1lb. cut of dewaxed shellac as a first coat after staining. The shellac will seal the stain or material. I do not sand the shellac but sand the first coat of finish after application. Most of the time, prior coats do not need sanding. I sand with 300G paper and if the additional coats do need a sanding, I use 400G. It is getting harder to get oil base finished due to the environment. Some suppliers do not carry them any longer here in Arizona. I mix my own dewaxed shellac from flake material but it is also commercially available in 2lb. cut. You can cut it down to a 1lb. cut with denatured alcohol and it goes a long way. I prefer to make my own, as I know its age. Age effects drying time of the product. One drawback of water base finishes is that they are temperature sensitive at time of application. Here is Arizona when the temperatures are above 90 degrees I do not use them. I shut down my woodworking during the summer months as woodworking in 100-120 degree temperatures is not fun!
-- TheOldTimer,Chandler Arizona
View Mainiac Matt 's profile
Mainiac Matt
8609 posts in 2564 days
#5 posted 12-30-2013 02:02 PM
I’ve used quite a bit of the Polycrylic. I’ve always brushed it on.
Dries fast and gives a nice end result.
I use a three step process for finishing pine trim.
1. General finishes “natural” conditioner
2. General finishes die stain (I like the Pecan on pine)
3. Minwax Polycrylic… I hand sand with 400 after the first coat and then put two more on without sanding.
-- I yam what I yam and that's all what I yam
Craftsman on the lake
2843 posts in 3673 days
#6 posted 12-30-2013 10:28 PM
I’ve used it a lot with an hvlp sprayer. I dust the first coat on then lightly sand it after it dries. Then I put 2-4 more coats on and do a light sanding before the last coat. I have it in my kitchen and I find that it is pretty water resistant. I don’t know why some say it isn’t. It seems to handle water just as well as the oil based one after it’s good and dry. I wouldn’t use it on a wood countertop but then again neither would I the oil based one.
View grumpy749's profile
grumpy749
228 posts in 2613 days
#7 posted 01-01-2014 03:23 AM
Thanks oldtimer for the finishing tip using a one pound cut of dewaxed shellac as a pre coat to stain finishing. I always use oil based finishes and also experience a stain bleeding problem. I’ve read about this finishing process before so I will try this soon. As far as your temperature problem goes no sympathy here, try minus 25 like we have got on new years eve here in northern Alberta. My shop is however toasty warm. lol.
-- Denis in Grande Prairie. Yesterday is history, tomorrow is a mistery, but today is a gift. That is why it is called the present.....Pink !
View Tennessee's profile
Tennessee
2893 posts in 2750 days
#8 posted 01-06-2014 08:03 PM
I’m with you, jumbojack!
