Santa helped make up my mind for me this year.
Review by woodenwarrior posted 12-28-2013 11:52 AM 2117 views 0 times favorited 2 comments Add to Favorites Watch
Santa helped make up my mind for me this year. No-picture-s No-picture-s Click the pictures to enlarge them
I’m the type of guy that looks at something forever before actually buying it. The plunge base for my Bosch Colt trim router is no different. Thankfully I have a wife that works hand-in-hand with Santa and together they made the choice for me.
Out of the box, the plunge base’s fit and finish is spot on and the feel is solid and comfortable in the hand. I immediately took it out to the shop for a test run on a project I’m working on. The motor slides into the plunge base sleeve very easily once the double arrows are lined up (reading the instruction book helped as there is no clear cut way the router should enter and lock in the base). The best part is the plunge mechanism itself. The base remains locked until the locking lever is pressed, plunged and then stays firmly set once the lever is released. I really like this feature. My Porter Cable plunge base while smooth in the plunge, does not want to stay locked with the lever pressed and an inordinate amount of pressure is needed to make it so.
The handles are tilted forward and provide a very comfortable feel while maneuvering the router. The adjustable turret stops and sliding limiter all function very smoothly and provide a solid experience.
Now the gripes (they are small ones but gripes nonetheless): The plunge depth is a little bit wanting. I realize that its a trim router in a plunge base and not built for the jobs a full sized router should tackle but a little more depth would be nice. As with all of Bosch’s routers…everything is an accessory. Throw me a bone here and include the edge guide and base plate adapter for bushings with the plunge base. Lastly, the spindle lock cannot be depressed when the router is installed in the base so it must be removed to change bits.
All-in-all I am very happy with the plunge base but the plunge depth limit and inability to change bits with the router installed drop it down to four stars for me.
-- Do or do not...there is no try - Master Yoda
View woodenwarrior's profile
woodenwarrior
231 posts in 2278 days
2 comments so far
View Handtooler's profile
Handtooler
1618 posts in 2216 days
#1 posted 12-28-2013 03:02 PM
Many thanks for the heads-up and thorough review! Those are two things next on my want list. And although your gripes are few and well pointed out, they will not prevent my from selecting these. However, other’s reviews list the solid metal base not as good as DeWalt’s clear acrylic base for visibility I’ll go for Bosch’s colt.
Thanks again
-- Russell Pitner Hixson, TN 37343 bassboy40@outlook.com
View poopiekat's profile
poopiekat
4369 posts in 3818 days
#2 posted 12-29-2013 02:14 AM
Well, when you’ve already got the Colt router, this is the one-and-only plunge base option. I really like my Colt, it’s been really handy with the fixed base. Oddly, I paid more for the plunge base than I did for the router itself, but it’s been perfect for cleaning up shallow cuts for inlay on solid red oak. I agree, it’s a great accessory to have!
