Excellent option for portable dust collection
Review by lumberjoe posted 12-24-2013 07:52 PM 5854 views 1 time favorited 8 comments Add to Favorites Watch
Excellent option for portable dust collection No-picture-s No-picture-s Click the pictures to enlarge them
Like many, I don’t have the space or power requirements for a large dust collector. I need something small that doesn’t draw a lot of power (I only have 30 amps available). This little unit fits the bill. I have my tools aranged so everything that needs a proper 4” dust collector is in close proximity, and I have a quick connect on the hose.
The good:
This unit is quiet compared to a shop vac and has plenty of power when connected to one tool at a time. It has no trouble keeping up with any tool I have attached it to.
It’s fairly light and on lockable casters.
It comes with a 4” to 2.5” adapter
The not so good
It comes installed with chip guards to protect the impeller. This prohibits use on a planer or jointer. I plan on making a separator which should eliminate that problem
The bag is only 13 gallons. Again a separator and large trash can will fix that
The bag is 30 micron – useless. I plan on ordering two 5 micron bag from grizzly
The bag inflates quite a bit – this leads me to believe there is a lot of back pressure. I am going to put a wye on the outlet and run 2 bags if it still fully inflates with a separator.
Overall I am very happy with this unit – especially for the price. It can be had for under $100 if you catch a sale. It definitely generates enough CFM to evacuate dust directly from what it is connected to. This is not a good solution for long runs or multiple hookups.
View lumberjoe's profile
lumberjoe
2899 posts in 2484 days
8 comments so far
View dbhost's profile
dbhost
5767 posts in 3468 days
#1 posted 12-24-2013 08:32 PM
Check out AFF or maybe even Highland Woodworking, I bet you could get a 1 micron or better bag rigged up for those little dust collectors… Perhaps you could duct the exhaust / dump the fine dust outside away from your work area via a long hose / pipe?
View Hawaiilad's profile
Hawaiilad
3308 posts in 3256 days
#2 posted 12-24-2013 09:33 PM
I have and use a unit pretty much like that made for Sears. I have added a hose spliter and run 3 hoses to my joiner, planner and bandsaw with very good results. I am also hooking up a trash can separator to catch more dust, but this one works great for what I need right now
-- Larry in Hawaii,
View upinflames's profile
upinflames
217 posts in 2398 days
#3 posted 12-25-2013 12:57 PM
I have one of these, piped outside, but I do live out in the sticks with no neighbors. If you take the motor assembly out and seal everything good, tighten the bolts, and wax everything inside the housing plus the impeller, it will enhance the little guy just a bit. The impeller is not plastic, very handy little collector.
View LoydMoore's profile
LoydMoore
105 posts in 2192 days
#4 posted 12-25-2013 03:41 PM
I actually put a three way wye with three 5 micron bags on mine to reduce back pressure. I also built a Thein style separator. The separator work great since I have emptied the separator several times and the bags are still empty. If time and $$$s permit I am going to install an exhaust pipe this summer to take what little fine dust get past the separator outside.
-- Loyd, San Angelo, TX http:www.moorewoodenboxes.com
View Kaleb the Swede's profile
Kaleb the Swede
1880 posts in 2205 days
#5 posted 12-25-2013 11:46 PM
Good dust collector. I have one mounted on my wall, and have it piped to my miter saw, planer, and table saw with an 8 foot section of 4 inch pipe with a separator. I use blast gates of course. This little guy does a fine job for me in my little garage. Sure it would benice to have more power but it does very well
-- Just trying to build something beautiful
View Stephenw's profile
Stephenw
273 posts in 2621 days
#6 posted 12-26-2013 03:59 AM
I have this dust collector. I purchased a 5 micron bag from Rockler and it works much better.
http://www.rockler.com/5-micron-replacement-bag-for-rockler-wall-mount-dust-collector
View cutworm's profile
cutworm
1075 posts in 3029 days
#7 posted 12-26-2013 10:09 PM
thanks for the info. Looks nice and is what I need for my small space.
-- Steve - "Never Give Up"
View CalumetWoodworks's profile
CalumetWoodworks
129 posts in 2354 days
#8 posted 08-24-2015 12:56 PM
Thanks for the review! I am moving my woodworking to my basement for the winter (Central Wisconsin). This will fit the bill for keeping the dust out of the house!
