| Review by PurpLev | posted 1797 days ago | 3286 views | 2 times favorited | 17 comments | ![]() |
- Veritas Mk.II Sharpening System
- Brand: Veritas | Category: Sharpening Accessories
Be careful when using this product because it’ll help you get your blades so sharp you could cut yourself by holding them by the handle…
This tool is remarkably simple to use and accurate. I especially like the quick micro-bevel setup. If you are not sharpening blades on a regular bases so that you are comfortable holding them at the precise angel you want them while sharpening – this guide will double and triple the value of your blade!
I am the weekend warrior, and as such, I do not practice sharpening my chisels very often. I have had a single english marples for a long time, and thought I can freehand sharpen it – which I did- only to have an OK edge that would require some force to use, and would lose it’s shape in no time. for the longest time I wanted to get the MK-II, but always thought I don’t REALLY need it, and postponed this purchase until this weekend. I am using the “scary sharp” method, and have always heard of people achieve razor-blade sharpness off of their chisels, which sounded like a cool idea, but I never even got anywhere close to such a thing until this weekend. I have used the MK-II to sharpen and hone a brand new 6 piece Chisel set in less then 30 min, and also completely fixed (the odd bevel) and honed my old marples in less then 10 min (including regrinding the bevel) – all to a mirror finish, and a hair splitting razor sharp edge.
I should have gotten it much earlier. I never realized what difference it would be to work with properly honed chisels – the blade slices through the wood (almost) like a hot knife through butter without putting much more force then gravity itself – I was amazed at this as I have always believed you really need to work hard to cut mortices, and anything else involving chisels.
The MK-II makes it a fast, comfortable, adjustable process to take a dull blade, and hone it to a mirror finish. is also keeps your fingers far enough from the abrasive as to protect them from scratching. it got me to hone 7 chisels from scratch (100grit – 230 – 400 – 600 – 1000 – 2000) in less time than it used to take me to sharpen a single chisel freehand before – and apparently it wasn’t even a good sharpening as the bevel wasnt right, and it wasn’t really kept parallel to the abrasive!.
HIGHLY RECOMMENDED!
17 comments so far
motthunter
home | projects | blog
2129 posts in 1964 days
#1 posted 1797 days ago
I love mine. I truly don’t know Jack about sharpening and this guide helps me get it right and still remain ignorant to the process. It is a great tool
-- making sawdust....
tenontim
2129 posts in 1910 days
#2 posted 1797 days ago
Thanks for the review. I’ve been looking at one of these, but like you, I just haven’t been able to bring myself to buy one. I guess, because I’ll have to actually put a recognizable angle on my chisels. I have some second hand antique Japanese chisels that were sharpened by hand, and I’ve continued the tradition of having various angles on them. Usually I just touch them up on the waterstone and the buffing wheel. I have one of the cheaper roller guides that I use for my plane blades, but it would be nice to try out the micro bevel adjustment.
-- Tim-- http://www.tmuli.com
teenagewoodworker
2727 posts in 1934 days
#3 posted 1797 days ago
i’ve heard a ton about this jig too and also been putting off this purchase. i think that once i get some better chisels i might get this. thanks for the post!
lazyfiremaninTN
528 posts in 2118 days
#4 posted 1797 days ago
Hey TWW, This will turn ho-hum chisels into good chisels. I used Greg3g’s on my Irwins chisels and Groz planes in march when we visited him and my Planes are still kinda sharp and my chisels are still sharp enough that I don’t even need a mallet to square up corners.
This jig is the #1 item on my list to P/U ASAP
WayneC
9596 posts in 2263 days
#5 posted 1797 days ago
I have one and can recommend it as well. Also the camber roller accessory.
gbvinc
628 posts in 2112 days
#6 posted 1797 days ago
Have one, works great! Nice review!
Chris
1850 posts in 2157 days
#7 posted 1796 days ago
Love mine too…. I used to have and old side clamping jig that was just plain difficult to use. This jig is wonderful with any stone or sandpaper!
-- "Everything that is great and inspiring is created by the individual who labors in freedom" -- Albert Einstein
Don Niermann
197 posts in 2138 days
#8 posted 1796 days ago
Got it. Love it. Easy to get the same angles on every chi8sel and plane iron
-- WOOD/DON (...one has the right to ones opinion but not the right to ones own facts...)
John_Sr
11 posts in 1807 days
#9 posted 1796 days ago
I just purchased mine this weekend also. I am glas to hear that you are using the scary sharpe method. I still need to get some glass. great review.
PurpLev
7729 posts in 1814 days
#10 posted 1796 days ago
John_Sr: I just picked an old piece of glass from a window that was replaced… I cant stress enough how important it is to use a dead flat base surface. before using the glass I was using a “very flat” cutting board, but because I was trying to “protect” the cutting board from getting ruined, it wasn’t as secure, and worry free.
what I did with the glass was (double sided) taped a full sheet of 100 grit to it, and I use that entire sheet as a primary grit to set the rough angle, and then I just place the next grit on top of the 100grit paper, and the abrasive material keeps the finer grit paper from moving around. Once I’m done with the finer abrasive paper – I just move on to the next grit and place that next grit on the 100 grit paper using the same technique… swapping grits is a snap, and I can (surprisingly enough) re-hone a chisel in less then a minute (tested!) swapping between 600-1000-2000 grits on the fly.
lazyfiremaninTN
#11 posted 1796 days ago
I ran by a glass shop a couple of months ago and picked up a 12in x 12in x 3/8in piece of glass for $12. Got home, made a sleeve for it outa cardboard and duct tape.
Found my wet/dry sand paper superfine grits (1000 and 2000) at the automotive parts store. Couldn’t find it locally in a wood/home store. A friend (mechanic) suggested that I try the parts store.
PurpLev
#12 posted 1796 days ago
true. finer grits are not available at the big-box stores. I didnt even find them at Rockler to my surprise. but Woodcraft has them for $.50 a sheet and also has them in bulk packages – not bad at all, and good quality abrasive from my experience with it so far.
davidtheboxmaker
373 posts in 1971 days
#13 posted 1796 days ago
I’m still using the original version of the jig. I’ve made my own jig to make sure I load the item to be sharpened consistently. I can clearly remember the surpise the first time I used it and discovered the joy of sharp tools. That was a major day in my woodworking experience.
brunob
2275 posts in 2335 days
#14 posted 1796 days ago
Thanks for the comments. I’ll have to put one of these on my wish list.
-- Bruce from Central New York...now, if you'll pardon me, I have some sawdust to make.
Mark Shymanski
3960 posts in 1878 days
#15 posted 1796 days ago
Within moments of starting to use the MkII, that I got for Christmas, I poked myself in the finger with an extremely sharp chisel…I was so impressed that it got that sharp that quickly. Like you I was impressed with how little effort sharp chisels cut, I highly recommend the MKII. It certainly has made chiselling much more productive and fun…and probably safer as I am not trying to power through a cut but letting the tool do the work. Thanks for the review.
-- "Checking for square? what madness is this! The cabinet is square because I will it to be so!" Jeremy Greiner LJ Topic#20953 2011 Feb 2
View all comments »
