JET JCS-10
Review by JHIM posted 12-07-2013 09:55 PM 9726 views 0 times favorited 13 comments Add to Favorites Watch
Average rating: 4.0
1 review total
Add my Review
JET JCS-10 No-picture-s No-picture-s Click the pictures to enlarge them
All together a press solid table saw. I have been looking for a while and come across this one. He added a 30” fence rail ,had it dialed in extremely tight. feather boards galore ,push sticks, home aid router attachment ,and Two cross cut sleds..i still have my eye open for another one just because the 2HP is lacking power..or maybe I just need to break down and but a high dollar blade? Any thoughts or recommendations?
All together I give it s B+
(image off google)
-- "the hard jobs will take a while..the impossible will take a bit longer"
View JHIM's profile
JHIM
124 posts in 2009 days
13 comments so far
View CharlesA's profile
CharlesA
3358 posts in 2032 days
#1 posted 12-07-2013 11:39 PM
I’d buy a good blade before buying a new table saw. I know that thin kerf blades are recommended for 1.5 hp saws—would be worth trying here. I’m very happy with thin kerf Freud rip blade adn a thin kerf DeWalt all purpose blade.
Especially worth it if the blade is used. Could be dull.
View BigAl98's profile (online now)
BigAl98
173 posts in 3273 days
#2 posted 12-08-2013 12:19 AM
I’ve found most of the saw is in the motor…..ie you’ll spend a pretty penny for a 3 hp or larger motor.
-- Al,New Jersey -To thine own self be true
View gfadvm's profile
gfadvm
14940 posts in 2924 days
#3 posted 12-08-2013 01:33 AM
Try the Freud Diablo blades (I use a 40 and a 24 tooth in my 2HP saw and have no complaints). They are inexpensive but I have mine resharpened and they cut better than new.
View Woodknack's profile
Woodknack
12455 posts in 2614 days
#4 posted 12-08-2013 02:54 AM
Probably just need a sharp blade, high dollar or not.
You should use a picture of your saw rather than a picture of someone else’s.
View jeff's profile
jeff
1132 posts in 3699 days
#5 posted 12-08-2013 04:19 AM
I think a new thin kerf blade would be in order,for any saw really…It helped my Rigid 4512…
-- Jeff,Tucson,Az.
View NormG's profile
NormG
6375 posts in 3238 days
#6 posted 12-08-2013 09:04 PM
Go for the sharp and/or new blade first. If the saw itself is not letting you perform tasks you need, then replace the saw. However, you will still need a new blade
-- Norman - I never never make a mistake, I just change the design.
View pintodeluxe's profile
pintodeluxe
5815 posts in 3048 days
#7 posted 12-09-2013 04:26 PM
Try a thin kerf blade, for example a Diablo 1024 ripping blade. It will zip through 8/4 oak like you wouldn’t believe. I started with a 50 tooth full kerf industrial Freud blade, and noticed slow feed rates and too much resistance to feeding thick lumber. Thin kerf makes all the difference for these mid-size saws. Plus the Diablo blades are inexpensive, and widely available at Home Depot, etc.
View JHIM's profile
JHIM
#8 posted 12-09-2013 06:47 PM
looks like i will be trying a different blade! thanks everyone
View Mainiac Matt 's profile
Mainiac Matt
8609 posts in 2563 days
#9 posted 12-09-2013 07:26 PM
I have an older Jet CTAS model and agree that they are well built saws. Basically, one of the earliest Tawainese clones of the venerable Delta Unisaw.
Are you basing your assessment that 2 HP isn’t enough umph based on any particular problem you’ve experienced with the saw, or is it more based on saw vs. saw spec. comparisons.
If you’ve observed a problem that you think points to lack of HP, you’ll need to detail it in order to get meaninful feed back. You’ve received some good ideas for blades…. Thin kerf is probably appropriate for a 2 HP saw… and dedicated rip and cross cut blades will give both good cut quality and efficient use of available power.
If your concerns are driven by spec comparisons, I suggest you put some miles on the saw… it may serve you very well as is.
As far as combo blades go, I have the Fusion blade that Andy mentioned above and like it quite a bit, but it takes more effort and power to rip with it than it would a dedicated rip blade.
-- I yam what I yam and that's all what I yam
Woodknack
#10 posted 12-10-2013 05:02 AM
Also, is may sound obvious but rip blades require much less power than using a combo blade to rip. My full kerf rip blade will zip through wood that bogs down a thin kerf combo.
View mbs's profile
mbs
1657 posts in 3174 days
#11 posted 12-11-2013 03:12 PM
Some blades are made for very specific uses. For example, I have a rip blade that is made for 1”-2” thick wood. It is not intended to work well or thin wood.
I generally prefer buying an industrial grade blade that has plenty of sharpening capacity rather than purchasing a less expensive disposable blade. The last Freud GLR (Glue Line Rip) blade i purchased didn’t last long at all.
A member of the LJ, Knottscott, has done plenty of testing and documenting of blades. I’ve been happy with his recommendations.
For general purpose blades I can recommend the Tenyru Gold series thin kerf blade. Cuts like butter. I made many 2” wide, 0.090” thick walnut laminate strips and glued them together without any planing/sanding and had no gaps. I can also recommend the Forest woodworker II. both of these blades are pricey. Scott may know of some great deals since he stays abreast of the blade market.
-- Sorry the reply is so long. I didn't have time to write a short reply.
View rustynails's profile
rustynails
807 posts in 2763 days
#12 posted 12-11-2013 10:22 PM
I used to have a 1.5 hp jet contractor saw and it cut everything I sent at it so I am guessing it’s your blade. I also used to have a blue Jet cabinet saw and it looked just like yours. If you are interested I have a brand new throat plate that takes inserts for zero clearance and dato blades that I would be willing to sell if you are interested.
12 unused inserts and one unused master plate. New it ran closes to $175.00. I would let it go for $50.00.
Good luck with the cutting.
View MerylL's profile
MerylL
70 posts in 1605 days
#13 posted 09-13-2014 03:57 AM
This forum is a live encyclopedia. I’m always just so amazed at how much I learn here. (Off-topic, I know, but I’m just so in awe!)
