Panel clamps, perfect for cutting boards
Review by CalgaryGeoff posted 11-30-2013 04:26 AM 24458 views 6 times favorited 29 comments Add to Favorites Watch
Panel clamps, perfect for cutting boards Panel clamps, perfect for cutting boards No-picture-s Click the pictures to enlarge them
I’ve been building end grain cutting boards for years and using pipe clamps and glue up jigs. Usually very messy and a slight bow developed during glue ups. Well, a fellow LJ member and I have been thinking there has to be a better way. Recently he sent me a link to check out some new clamps, wow, it looks like the perfect solution to cutting board glue up. Here’s a link to a 50 second YouTube video showing an animation of them in action.
http://www.youtube.com/watch?v=_SYR957YcJY
Damstom D300 BLACK Edition Panel Clamp
I’m going to order some as to me these clamps look perfect for cutting board glue ups.
Does anyone here have experience using them?
-- If you believe you can or can not do a thing, you are correct.
View CalgaryGeoff's profile
CalgaryGeoff
937 posts in 2721 days
29 comments so far
View Monte Pittman's profile
Monte Pittman
30153 posts in 2578 days
#1 posted 11-30-2013 04:30 AM
They look perfect for it.
View WhoMe's profile
WhoMe
1564 posts in 3483 days
#2 posted 11-30-2013 05:00 AM
I just recently saw these. Pretty slick looking and they look perfect for what the video shows. Especially since the upper and lower bars look like they be used like clamping cauls.
-- I'm not clumsy.. It's just the floor hates me, the tables and chairs are bullies, the wall gets in the way AAANNNDDD table saws BITE my fingers!!!.. - Mike -
View lew's profile
lew
12510 posts in 3995 days
#3 posted 11-30-2013 05:14 AM
Thanks, Geoff!
View robscastle's profile
robscastle
5632 posts in 2444 days
#4 posted 11-30-2013 05:27 AM
I checked out the video on utube, they certainly look OK.
I would be wanting to see a demo of them before buying, there seems to be no locking of the parallel bars at the back.
This may not be necessary due to clamping pressure, but I would be putting a G Clamp on the end, just to be sure.
Now I am off to find out price and availability in Aust.
-- Regards Rob
robscastle
#5 posted 11-30-2013 05:34 AM
Information direct from the Damston Site
CLEARANCE
D300-2012 – Clearance – D300 Panel Clamp 2012 – 38” were $74.95 now $59.95 ( In Canada?)
They appear to be a Korean product but made in Canada.
A give away “Asian” warning I noticed,
Don’t put fingers between the wooden pieces and the tightening system.
Certainly better than the $300 -$400 each for the “Frontline Engineering products.
A Note: even the build yourself clamps have a rear clamping section
-- Regards Rob
View BoardSMITH's profile
BoardSMITH
121 posts in 2503 days
#6 posted 11-30-2013 12:03 PM
YIKES!!!!! $70.00 each plus all the small parts that can become loose and lost in a shop. Based on the retail cost, it would cost over $2500.00 to replace the clamps I now use. Maybe okay for the occasional user but far too expensive to make sense for a production shop. I am sure there is a far cheaper and equally as effective a way.
-- David www.TheBoardSMITH.com
View michelletwo's profile
michelletwo
2773 posts in 3255 days
#7 posted 11-30-2013 01:36 PM
didn’t Lee Valley in Canada have a red set up ? they had cauls & clamps of some sort? if my memory serves me, and it usually doesn’t :-)
View poopiekat's profile
poopiekat
4408 posts in 3974 days
#8 posted 11-30-2013 02:00 PM
A review for a product you haven’t even used yet? And five stars, already? Are you serious, CalgaryGeoff?
View Brad_Nailor's profile
Brad_Nailor
2539 posts in 4197 days
#9 posted 11-30-2013 02:31 PM
These look like they could be useful for panel/side grain glue-ups, but the biggest problem I have when I do end grain is keeping the slices from swaying or developing a curve. I glue up my end grains a few slices at a time, and the best way to do it I have found is to use a jig with perpendicular edges and clamp to that..allowing you to keep things flat as you go..I never really worry about getting the top perfectly flush because I drum sand anyways after the glue up so slight variations aren’t a big deal..but I do try to keep things as flat as possible. Along with the expense I really don’t see these as a solution..to the problems I experience doing end grain anyways..
Also, I have found that making sure your blank panel is perfectly flat and thicknesses consistently along the entire surface. I learned the hard way that even a slight (1/64) variation in the thickness of the blank from edge to center, adds up quickly to a bow you cant clamp out!
View HarveyM's profile
HarveyM
106 posts in 2262 days
#10 posted 11-30-2013 02:43 PM
Lee Valley have their Veritas panel clamp, and bowclamp (Maple clamping cauls). There’s also the WoodRiver Clamping System (cheaper Busy Bee sells in Canada), or the Plano press (more for the production shop)
-- Just a Duffer
View Andrew's profile
Andrew
316 posts in 2606 days
#11 posted 11-30-2013 03:12 PM
Here are the Woodriver clamps:
http://www.woodcraft.com/Product/2000321/1858/WoodRiver-Clamping-System.aspx
-- Andrew - Albany. NY
View CharlesA's profile (online now)
CharlesA
3360 posts in 2037 days
#12 posted 11-30-2013 03:46 PM
“A review for a product you haven’t even used yet? And five stars, already? Are you serious, CalgaryGeoff?”
My thoughts, exactly. This is a forum post, not a review.
CharlesA
#13 posted 11-30-2013 03:51 PM
Now that I’ve watched the video, not sure how it creates a lot of caul-like pressure with just thumbscrews holding down the cross pieces. The Woodriver (I haven’t used it) forces both down and in with heavy duty screw. Doesn’t look the the Veritas has a mechanism for down pressure other than the serrated post to hold the cauls in place.
I just looked more closely at the Woodriver clamps, and it appears that the difficulty with them is that you have screw the clamp to the cauls for each differently sized glue-up. would be way more convenient if you were regularly gluing up identical pieces. Lot of work for someone like me where every glue up is different.
View JustJoe's profile
JustJoe
1554 posts in 2278 days
#14 posted 11-30-2013 05:18 PM
+1 to CharlesA’s +1 of Poopiekat’s “Are you serious?” remark. This would make a decent forum discussion, but it’s not a review.
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
CalgaryGeoff
#15 posted 11-30-2013 09:35 PM
Wow, Lots of attention for a tool post. I choose to place this in tool reviews, not a forum cause it’s a tool. It looks like a solution to some of my issues during glue ups and I was sharing it. As far as the 5 star review goes, it was not rated by me, I left it with no stars. Just deal with it boys !!
Board smith, I’m looking for a solution to my glue ups, just a hobby shop.
Andrew, thanks for the post good idea.
showing 1 through 15 of 29 comments
