Quick Review of a Great Little Cyclone!
Review by WoodJitsu posted 11-26-2013 10:09 PM 10684 views 0 times favorited 9 comments Add to Favorites Watch
Quick Review of a Great Little Cyclone! No-picture-s No-picture-s Click the pictures to enlarge them
Like every other woodworker, I owned a Habor Freight 2HP dust collector. It served me well in its stock form, but I knew it was leaving lots of fines floating around my small shop and I needed to either upgrade it or buy something new. I looked at all the options with the filters, baffles, etc, but I came to the conclusion that for a few extra bucks (ok, more than a few) I could really upgrade. So I took the plunge and bought the Grizzly cyclone. My concern was the the CFM, I’ll address that later. Ordered Monday, received it Friday. First thing to note, this sucker (heh) is heavy. Assembly was easy, with the only hard part of lifting the motor/shroud unit up once the stand was assembled. I did it by myself, but would recommend a friend if you have one handy. My only complaint about the construction of this cyclone was the fact that it was easy to over torque the bolts and the embedded nuts in the stand would turn. Had to be careful when tightening. Otherwise, this thing is built like a tank. I wasn’t sure what to expect, but the build quality of this DC has far exceeded my expectations.
So you’re saying “Yeah, that’s great and all, but how does it perform compared to the HF DC?” Well… as I mentioned earlier, I was nervous that I was downgrading CFM with this purchase. I didn’t. In fact, it’s MUCH stronger than the HF. Few things to bare in mind here. A) MY HF was bone stock, so I’m sure the CFM was limited compared to a modified unit. B) I have no scientific method of testing them other than feeling the suction side by side. C) The new one was more expensive, so it has to better, right :) But seriously, in my opinion, the Grizzly out performs the Harbor Freight by a noticeable amount. I’m currently running a 6” to double 4” adapter. Without the 4” adapter, the 6” opening pulls like crazy. I would love to pipe the shop in 6”, but I think that’s beyond my space capability.
I had read that this will trigger a 20A circuit with the 6” opening. Mine didn’t. In fact, I’m running my TS and this collector on the same circuit. I start the DC first, then power on the TS and have not blown the breaker. I plan to run another 20A for the DC, but for now, it all works on the same one (I was surprised by this!)
Remote works great and is so handy to have. I was always lurching over to turn on the HF, so this is a welcome upgrade.
I do have 1 complaint (other than the bolt issue) It’s louder than the HF. Noticeably louder. It whines like a turbine and is a little annoying since it’s at close proximity to my TS and Jointer. No problem, I’ll just throw on the hearing protection when needed, but I wish it were a little quieter.
This was my first major Grizzly purchase and I’m very happy with the product. I had almost spent a few hundred more on the Laguna, but I’m glad I didn’t. Now I can put that money towards my next purchase, a grizzly jointer. If you’re on the fence, get off it and get one of these, your lungs will thank you!
-- Family, Friends, Jiu Jitsu, Woodworking. Order varies daily!
View WoodJitsu's profile
WoodJitsu
49 posts in 3027 days
9 comments so far
View PSUmike's profile
PSUmike
31 posts in 2402 days
#1 posted 11-27-2013 12:34 AM
I’m glad you’re happy with this. I’ve been meaning to pickup a dust collector, and I’ll take your review into serious consideration when I do.
I’ve got a 6” Grizzly jointer, and I’ve been completely happy with it thus far. It’s absolutely my favorite tool.
View darthford's profile
darthford
612 posts in 2158 days
#2 posted 11-27-2013 01:53 AM
I’m a member of this fan club club
View ellen35's profile
ellen35
2739 posts in 3667 days
#3 posted 11-27-2013 04:23 PM
I too am a member of the “fan” club. I’ve had mine for close to a year. I really bought it because I wanted the filter clean out handle on top. I was tired of taking my HF apart to clean the filter. This really has much more suck than the HF.
View pintodeluxe's profile
pintodeluxe
5815 posts in 3048 days
#4 posted 11-27-2013 07:33 PM
Nice review, thanks for the information. That unit has a tempting price point.
View Mainiac Matt 's profile
Mainiac Matt
8609 posts in 2563 days
#5 posted 11-27-2013 08:46 PM
Glad to hear you’re happy with the DC.
Just a couple points to note (and no I’m not bashing HF, so all the HF fan boys can settle down… as I love HF and own plenty of their tools).
Frst, a “true” 2 HP Induction motor wired for 110 volts will pull 14 amps at max power, and the starting surge will trip a 15 amp. breaker. So how do companies (Sears TS, HF DC, Shop Vac, etc….) sell their 2, 3 and even 5 HP machines with 15 amp circuit plugs on them. Easy, they play games with the HP rating. You’ll find that these machines are closer to 1.5 or 1.75 HP.
So while many companies play games with “peak HP” ratings (where the take the max. amps seen on starting surge and use that number to calculate the HP) I’ve found that Grizzly advertises a “true” HP rating. And that’s why anything they sell that’s rated over 1.75 HP is wired for 220 volt only.
Second, your side by side comparison is not an apples to apples comparison. You would need to hook the HF up to a cyclone pre-filter like a Thien top hat. The Grizzly appears to pull harder in your side by side, but it’s pulling through a cyclone which adds resistance to flow (head loss), where the HF doesn’t. So advantage HF.
But the Grizzly has a lot more surface area in the pleated filter than the HF does in the bag, so advantage Grizzly.
I’d like to see a side by side with a suped up HF with a Wynn pleated cartridge filter and a Thein Top hat.
But then again, some guys want a DC and not a DC project :^)
-- I yam what I yam and that's all what I yam
darthford
#6 posted 11-29-2013 01:17 PM
I hear you Matt, I put a Fluke on the Grizzly when it randomly tripped my 20 amp 220 volt breaker and at start-up it was sucking like 60 amps then steady at 18 amps. I wired everything up to a dedicated 30 amp breaker and have been good to go.
View bigfred's profile
bigfred
7 posts in 2243 days
#7 posted 01-12-2014 10:45 PM
I have a new grizzly dust-collector to be delivered this wed. i’ll post more on it later.
-- fred, Kentucky,
View 680's profile
680
3 posts in 1883 days
#8 posted 01-17-2014 04:34 PM
The only dust collection I have is a little shop 1.5 HP shop vacuum. I own a Rigid 4512, router table with a 7518 and a chop saw. My space is one bay of a 3 car garage, I have noticed how much dust accumulates after a day of woodwork. I read through Bill Lintz’s information on DC and it concerns me because I plan on doing this for a long time. I am restricted to 110 for power. I guess I could have 220 set up professionally if I need to. Do you guys think it is overkill to use this piece of equipment for DC on the aforementioned equipment?
View Bearhunter's profile
Bearhunter
1 post in 1652 days
#9 posted 07-09-2014 04:59 PM
I have the same Grizzly cyclone dust collector. The two major faults I have with the machine are the casters and the weak framework. I will be looking into changing the light duty, small, cheap furniture-type casters the machine came with. They do not roll very well, and get stuck on the smallest thing on the floor. The weight and bulk of this machine would be served much better with 3” or even 4” casters. Changing out the original casters is a must for me.
The framework for this machine is a bit too light. I find when rolling the machine, the frame flexes and springs around way too much.. Either a larger tubing should have been used, spans between supporting braces reduced, or additional bracing should have been welded into place. I will be studying the problem with an eye to welding additional bracing to stiffen the frame and take the springiness out of it.
Other than these two faults, I like the machine. I would have paid a bit more money for a stiffer framework and better casters.
