ECE Jack plane
Review by arthurbvb posted 11-22-2013 08:06 PM 8977 views 0 times favorited 7 comments Add to Favorites Watch
ECE Jack plane ECE Jack plane No-picture-s Click the pictures to enlarge them
I have this plane now for two years. I have the version with the ironwood sole. I really enjoy using this plane. It is one of the tools that I use the most. I mainly use it on pine, but also one beech, walnut and maple.
This plane literary glides over the wood and takes no effort to plane. I also have a wooden jointer plane and a low angle jack plane but I rarely use them. This small plane however is much more comfortable to use. For big projects I of course use the jointer and for shooting end grain I use the jackplane.
I find adjusting this plane much easier and faster than metal planes and waxing the sole is not necessary. In the picture I use it for flatting an end grain cutting board. I think it is much faster to do this with a hand plane than with a band sander or a router.
The blade takes a keen edge and holds it relatively well (probably not as long as a Lie Nielsen but it is also less than half of the price)
View arthurbvb's profile
arthurbvb
18 posts in 1918 days
7 comments so far
View bobasaurus's profile
bobasaurus
3549 posts in 3425 days
#1 posted 11-22-2013 11:17 PM
I’m really impressed that you can flatten end grain cutting boards with that plane. Do you plane at a skew for a lower angle cut? I’ll give this a try on my next cutting board.
I have the primus jack and it’s a good plane, but one of the adjustment mechanisms is machined oddly making the lateral adjustment wonky (it always favors one edge). Maybe the standard wedged jack would be more useful.
A few more questinos about your plane (sorry, I’m a curious guy): how big is the mouth opening, and do you sharpen a camber on the blade? Thanks for the review.
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
View waho6o9's profile
waho6o9
8539 posts in 2818 days
#2 posted 11-23-2013 01:52 AM
Amazing, thanks for the review.
View poopiekat's profile
poopiekat
4408 posts in 3975 days
#3 posted 11-23-2013 02:13 AM
I like these, I have a couple of Emmerich, and two Nooitgedagt planes. If you’re used to conventional Stanleys, these require a bit of getting used to. Once you discover the technical quirks and adapt to them, they are a joy to use.
One of my Nooitgedagt planes has a serious camber on the cutter, and I use it like a #40 scrub plane.
Thanks for a review on an often overlooked tool!
arthurbvb
#4 posted 11-23-2013 07:53 AM
When I am planing end grain I keep the plane at a skew. The bite which you take with the plane is less wide and I think therefore the plane is easier to push. I do not know if this changes the angle cut. It is very important to put a big chamfer on the far side of the cutting board otherwise the fibers will break out. When I start with planing, the cutting board I make sure that the blade is protruding a little more on one side of the plane. You do get more plane tracks but you can take a little deeper cut and it is easier to start. when the board is flat I resharpen my blade, put the blade straight and take some light passes and finish with a block plane. Afterwards you will only need little sanding.
I don’t put a camber on a blade but I do put chamfers on the edges. I use diamond stones and a leather strop (the method I saw paul sellers do on youtube). I do have a big camber on my ECE scrub plane. I do not know the exact size of the mouth opening but I think that the mouth opening is a little bit bigger than in metal planes. But I don’t think tear is a much bigger problem than with metal planes.
Poopiekat,
I also have one nooitgedacht chisel (very nice chisel) and a very long jointer plane from nooitgedacht which I find awkward to use because of its length. You are probably from holland or bought them there.
bobasaurus
#5 posted 11-24-2013 02:12 AM
Thanks for the information Arthur. I’ll have to give your one-edge-deeper trick a try.
View TechRedneck's profile
TechRedneck
770 posts in 3098 days
#6 posted 11-24-2013 02:57 AM
I picked up one of these at a flea market, $20 so I had to get it. Most of my planes are vintage metal, however many people discount the wood body planes at their own peril. These planes (when sharpened and tuned correctly) are an absolute dream to use. I love how smooth, light and fast they feel.
Here is a shot of the medallion and the camber of the blade. I was surprised at the aggressiveness of the camber but it seems to work well and tears up the wood. One of these days I am going to get a replacement blade and put a slighter camber on it.
This is one of my favorite Jack planes.
-- Mike.... West Virginia. "Man is a tool using animal. Without tools he is nothing, with tools he is all.". T Carlyle
arthurbvb
#7 posted 11-24-2013 11:10 AM
The plane you have looks like a scrub plane, I think I have the same. I use it a lot for dimensioning wood (across the grain)
