Telpro The Troll® 49 Panel Handler
Review by JoelB posted 10-31-2013 03:35 AM 3585 views 0 times favorited 7 comments Add to Favorites Watch
Telpro The Troll® 49 Panel Handler Telpro The Troll® 49 Panel Handler Telpro The Troll® 49 Panel Handler Click the pictures to enlarge them
Just bought this to save my back when a client spec’d a project that required 20 sheets of 3/4” MDF. The Troll is an awesome back saver that makes it very easy to move sheet goods around the shop. My storage is roughly 75 feet away from my tablesaw so I needed a simple and inexpensive way to move the 20 sheets around with a minimum of lifting.
Basically, to use, you lay the Troll against the sheet at about midpoint. Then you lift/tilt the panel until the lip on the bottom of the Troll slips under the sheet (about 5 inches). Once the Troll slips under you set the sheet down on to the Troll. The weight of the sheet is what secures the Troll to the sheet. Once all of the weight is on the Troll you can easily steer the sheet around the shop. The wheels are a nice soft rubber and are big enough that they easily roll over small obstacles. Because the pivot point is in the center of the sheet, maneuverability is pretty good.
Overall I am very happy with my purchase…and my back is even more happy!
View JoelB's profile
18 posts in 3309 days
7 comments so far
View Mainiac Matt 's profile (online now)
Mainiac Matt
7817 posts in 2264 days
#1 posted 10-31-2013 12:57 PM
your back will thankyhou….. MDF aint light! and full size panels are always awkward to move around.
-- Pine is fine, but Oak's no joke!
View Bluepine38's profile
3379 posts in 3021 days
#2 posted 10-31-2013 02:18 PM
Inexpensive way to save a lot of work, and simple to boot, thank you for sharing.
View rrww's profile
263 posts in 2049 days
#3 posted 10-31-2013 10:59 PM
Does it tip easy? From the pictures it looks like it would be a pain to try to balance and steer it at the same time? I have carts for sheet goods, but you still have to pick up the sheet 6” to set it on the cart.
#4 posted 10-31-2013 11:28 PM
As far as tippy, I don’t think it is tippy at all. I mean you have to balance it as you would expect, but it really isn’t bad. I would imagine the heavier the wood the more stable it would be.
View jasonR's profile
19 posts in 2563 days
#5 posted 11-01-2013 02:20 AM
Wow! that looks a lot easier than using the claw of a hammer to help schlep heavy sheet goods around.
-- Jason
View mbs's profile
1652 posts in 2876 days
#6 posted 11-01-2013 10:59 AM
I found this you tube video.
-- Sorry the reply is so long. I didn't have time to write a short reply.
View Ottacat's profile
466 posts in 1787 days
#7 posted 11-04-2013 06:43 PM
Nice, I never knew this existed.
