Review by Blackie_ posted 10-29-2013 12:59 PM 8433 views 2 times favorited 41 comments Add to Favorites Watch
Average rating: 3.5
4 reviews total
Add my Review
Gone No-picture-s No-picture-s Click the pictures to enlarge them
-- Randy - If I'm not on LJ's then I'm making Saw Dust. Please feel free to visit my store location at
View Blackie_'s profile
4846 posts in 2442 days
41 comments so far
View Woodwrecker's profile
4128 posts in 3505 days
#1 posted 10-29-2013 01:52 PM
I have that sander as well, and although it works nicely and was a good value for the price, I have found that I don’t use it as often as I thought I would.
Before I bought a spindle sander, I found other ways to achieve the same results and return to them more often.
For what it’s worth, has great replacement sleeves at good prices.
-- Eric, central Florida / Utor praemia operibus duris
View b2rtch's profile
4851 posts in 2978 days
#2 posted 10-29-2013 03:05 PM
I bougth one of this used for $100.00 many years ago.
I “love” it.
It certainly is the most used tool in my shop
-- Bert
View Don W's profile
Don W
18659 posts in 2497 days
#3 posted 10-29-2013 03:07 PM
i’ve had the same one for several years. It gets a lot of use. I would buy another.
-- - Collecting is an investment in the past, and the future.
View Howie's profile
2656 posts in 2853 days
#4 posted 10-29-2013 04:08 PM
I’ve had this unit for about 5 years and if it breaks I’ll buy another. definitley 5 stars from me.
-- Life is good.
View newTim's profile
607 posts in 3536 days
#5 posted 10-29-2013 04:52 PM
Blackie… thanks for the review. I’ve been thinking about getting one of these, but I have a question. I have a Delta spindle sander and changing the sleeves is a pain in the ass. There is no locking mechanism so I have to jam a screw driver into the throat so I can break the nut free. I think you are supposed to be able to do this by gripping the sleeve/drum, but I’ve never been able to do it. Tightening is also a problem for the same reason. If the nut doesn’t compress the rubber drum the sleeve will slip up and down as you are sanding. Poor design IMO, but it is what it is.
So my question is how hard is it to change sleeves? Does it have a locking mechanism? How about changing from the drum to the belt?
As an aside, I read some of the product reviews for spindle sanders in Fine Woodworking and elsewhere and this is the type of question I often find the reviewers do not address. Don’t you wish Festool made a spindle sander? :)
-- tim hill
View pintodeluxe's profile
5587 posts in 2743 days
#6 posted 10-29-2013 05:35 PM
Changing sleeves is quick and easy. I use the belt most often, because the left side is just a large diameter spindle. The belt feature allows you to do things plain spindle sanders can’t, like chamfer the ends of a tenon precisely. I also prefer the belt for fairing gentle curves, as it is less likely to dig in than a small spindle.
#7 posted 10-29-2013 05:40 PM
Tim, I’m not quite sure I follow your question about the locking mechanism but I’ll do my best to answer, I have a few sets of drums so I’m always picking through to find which one fits the sleeve the best but all drums fit the spindle shaft which I believe to be 1/2” don’t quote me on that as when I use a 1/2” sleeve it just slides right down over the shaft without a drum, to lock the drums down there is a left handed threaded shaft that a left threaded locking nut screws down onto with proper sized washer between the knob and the drum to compress the drum the knob that comes with the unit has a nice finger turning grip for easy turning but you are only limited to roughly 4.5” that’s why I modified it by grinding the finger grip away narrowing it down.
Swapping the belt with the drum is a breeze a very quick process and the unit has a nice storage area on the back for the belt.
View Jim Jakosh's profile
Jim Jakosh
20162 posts in 3035 days
#8 posted 10-29-2013 05:45 PM
Randy, that looks like a real handy machine. As for that knob, take it off and put a hex nut in its place and use a wrench on it. That is what I have on my Ryobi spindle sander.
#9 posted 10-29-2013 06:17 PM
I never use the spindle only the belt in five years I might have used the spindle once) but it is very easy to change from on to the the other or the change the sleeve, I do not see why you would need a locking mechanism.
“Don’t you wish Festool made a spindle sander?” NO!
They would not make it any better than Rigid and it would cost at least $1500.00
-- Bert
View Jeff's profile
425 posts in 3124 days
#10 posted 10-29-2013 06:41 PM
No locking mechanism is needed. The tightening bolt is left hand threaded so it tightens on itself. Sometimes it tightens too much but a pair of pliers solves that.
#11 posted 10-29-2013 06:57 PM
Jim, that thought had crossed my mind from the git-go but and (I’m not a machinist) it’s left handed threads not right handed, I’d have to find a special bolt and nut store for this I’m thinking? I don’t really know the difference between course and machine threads. Now… that you have me thinking I guess I could take the knob with me to the store but I doubt that any box store is going to have a left handed bolt to try it on that’s why I mentioned a special store.
View OggieOglethorpe's profile
1276 posts in 2040 days
#12 posted 10-29-2013 09:23 PM
This machine is a steal! I was considering spending a lot more on a Jet or Grizzly spindle sander and a stationary belt sander, ‘till I tried one of these.
The spindle knob works great! I don’t see any need to replace it, if you don’t have the specific clearance issue of the OP. The dust collection is great with a Shop-Vac, too… The vacuum works far better than my big cyclone with this unit.
Last Christmas, I used my unit to flush up splines and sand the sides of a run of 35-40 gift boxes, from 80 grit to 320, no skipped grits, and the belt performed flawlessly, with just a 2 second tracking adjustment after each grit change. I’ve gotten a lot of mileage out of the spindle, too… The price / performance ratio of this machine is out of sight.
There’s a seller on Amazon that sells excellent quality belts and spindles in that fit this tool in bulk, from extra coarse to 320-400.
View cutworm's profile
1075 posts in 2723 days
#13 posted 10-30-2013 12:17 AM
1+ Bert. I like my sander.
Thanks for the post. You almost never see any negatives about this sander.
I’ll gloat a little at getting mine for $115. New.
Klingspor has belts and sleeves. I like their sandpaper.
I saw on here where someone made a wooden knob to go over the lefthand screw head making it easier to remove.
-- Steve - "Never Give Up"
View DocSavage45's profile
8474 posts in 2772 days
#14 posted 10-30-2013 12:52 AM
Thanks for your review! It looked like a winner to me after looking at a number of spindle sanders. I remember your discussion about the problems you were having. After 6 months of continued use looks like you have a winner. what are the total space requirements to use the machine in your shop?
-- Cau Haus Designs, Thomas J. Tieffenbacher
#15 posted 10-30-2013 02:54 AM
Tom I’ve been looking at projects here on LJ and am going to take on two flip top caddies, one for sanding and the other for planning. it’s no more bigger then the other brands.
showing 1 through 15 of 41 comments
