An obvious improvement over my Shop-Vac
Review by Kobra posted 10-05-2013 12:49 AM 8397 views 2 times favorited 11 comments Add to Favorites Watch
An obvious improvement over my Shop-Vac An obvious improvement over my Shop-Vac No-picture-s Click the pictures to enlarge them
After using my shop-vac as my dust collector for several months, I finally broke down and purchased a real dust collector. Let’s be honest, using a shop-vac for a dust collection system is akin to using a weed trimmer to mow your lawn.
Requirements –
1) I wanted a system with a relatively small footprint. Like most DIYers, lack of space is enemy #1.
2) Spend no more than $400. I couldn’t justify spending more money when woodworking is a hobby.
3) CFM greater than 400. The average CFM for a shop-vac is around 200. I wanted at least double that amount.
4) Filtration rating of 1 micron. All of my research pointed to this rating. This requirement reduced my options tenfold.
Purchase
After much deliberation, I ended up buying the Grizzly G0583Z. The base is 15”X26” with the overall height being 59”. Total cost including y-fitting, clamps and extra bags was $385. The hose and blast gates were purchased at Menards, so I ending up spending slightly more than $400. Grizzly claims the airflow capacity for the 583Z is 800 CFM. It uses a canister filter with a rating of 1 micron.
Assembly
Assembling the 583Z was super easy. It took me less than 45 minutes to get everything set up.
Positives
1) I noticed an obvious improvement the first time I used it with my table and band saw. The amount of sawdust on the floor was noticeably less. I still have to use my air compressor once in awhile to clean out the saws, but I put more of the blame on the saws themselves.
2) This thing is quieter than my shop-vac, which was a pleasant surprise.
3) Portability – This thing is small enough where I can move it around or out of the way depending on the situation.
Negatives
After a while, I started to notice a slight collection of dust around the seams. I used electrical tape to remedy this problem. Not a deal breaker just a minor annoyance.
Summary
This is a great dust collector for those who have limited space and/or a modest budget. It certainly won’t compete with the big boys, but it is an obvious improvement over the shop-vac route.
View Kobra's profile
Kobra
21 posts in 1987 days
11 comments so far
View Jokker78's profile
Jokker78
136 posts in 1784 days
#1 posted 10-05-2013 05:33 AM
My shop vac works great. it is very loud but it is better than nothing
-- Measure once, cut , measure again, cut and damn its still to short
View grumpy749's profile
grumpy749
228 posts in 2464 days
#2 posted 10-05-2013 02:28 PM
Put a small cyclone in front of it and then you’ve got something. I use a dust buddy, This saves the filter clogging problem. Dust is a killer…. ’’ What’s that car doing in your wood shop’‘
-- Denis in Grande Prairie. Yesterday is history, tomorrow is a mistery, but today is a gift. That is why it is called the present.....Pink !
Jokker78
#3 posted 10-05-2013 04:31 PM
Where do you find a dust buddy.
View felkadelic's profile
felkadelic
218 posts in 2627 days
#4 posted 10-06-2013 01:22 AM
I have this same unit. I found that some small magnets work well to hold the bag in place while applying the band clamp.
Kobra
#5 posted 10-06-2013 03:55 AM
+1 on the magnet trick. I struggled putting the bag on before using a couple of small magnets to hold it in place.
View woodmaker's profile
woodmaker
321 posts in 2778 days
#6 posted 10-07-2013 04:29 PM
I have this same one; works great! I use blue masking tape to hold the bag, works great at getting the band back on. I can only use one machine at a time so this unit makes sense. Owne dot for three years now and nothing has ever broken.
-- Mike
View redSLED's profile
redSLED
790 posts in 1979 days
#7 posted 10-17-2013 01:08 AM
Nicely written review – and you covered all the basic decision making considerations that I would have (I have a 12×8 workshop space). I was contemplating one of the newer 5-6 HP (peak) shop vac routes, but now I have more to think about – darn you and your informative dust collector review.
View ChipOffTheOldBlock's profile
ChipOffTheOldBlock
65 posts in 1825 days
#8 posted 03-20-2014 11:13 PM
Very nice write up, thanks.
-- "Excellence is a thousand things done just a little bit better"
View Gerry's profile
Gerry
264 posts in 3327 days
#9 posted 03-20-2014 11:31 PM
Good review and Nice acquisition! Re the dust around the edge of the bag, I’ve used some thin foam weather sealing tape between the bag and the metal ring, which greatly reduced the dust leaks.
Also, +1 on the addition of a second stage. Either a then baffle or a bought cyclone separator would make a big difference on how long the filter stays clean.
-- -Gerry, Hereford, AZ ” A really good woodworker knows how the hide his / her mistakes.”
woodmaker
#10 posted 03-21-2014 12:28 AM
I have the same collector now for 4 years, love it.
-- Mike
View boating4us's profile
boating4us
2 posts in 1246 days
#11 posted 12-31-2015 11:05 PM
Wow, Ive been looking for a decent affordable dust collection system for my Grizzly G0715P. I think Im ready to place the order on this model after this review & comments.
Thanks for all the input!
-- Steve
