Shopsmith 40 grit sanding discs (5")
Review by Purrmaster posted 09-29-2013 09:46 AM 3170 views 0 times favorited 5 comments Add to Favorites Watch
Shopsmith 40 grit sanding discs (5") No-picture-s No-picture-s Click the pictures to enlarge them
I discovered these at Lowe’s about a year ago. Often I have need to sand out a defect and the lowest grit discs gets it done the most quickly.
These discs are 8 hole, hook and loop (velcro) 5 inch discs.
I’ve been very pleased with these discs. They cut pretty quickly and them seem to last a long time. Not as long as Abranet, but they’re pretty durable. These discs compare favorably with Diablo, 3M, and Norton (the other brands I’ve mostly used).
These things come in very handy. The only caveat I have is that it can be difficult to tell when the disc is worn. Even when worn the abrasive on the discs is pretty rough. And visually it’s nearly impossible to tell.
Note: I have also used the same discs but in 320 grit. They were equally good.
Next time you’re looking for some sanding discs, give these a shot and see what you think.
View Purrmaster's profile
Purrmaster
915 posts in 2333 days
5 comments so far
View pwalter's profile
pwalter
79 posts in 2824 days
#1 posted 09-29-2013 02:28 PM
I like these as well. Ever since Home Depot stopped carrying 3M these became my go to sandpaper. I HATE the diablo sandpaper that Home Depot now carries.
Purrmaster
#2 posted 09-30-2013 07:57 AM
I haven’t had any particular problem with the Diablo discs. They’re nothing to write home about but they get the job done.
View Tennessee's profile
Tennessee
2893 posts in 2754 days
#3 posted 09-30-2013 07:25 PM
I saw these and wondered how they would hold up. I am currently using Klingspor, their gold and their blue. Blue, not so hot. Gold, pretty good.
The Diablo discs at HD, I have no problems with their sanding ability, but with that stupid little hole pattern, not many of my ROS units can successfully pick up the dust correctly. Terrible, and they clog fast.
View CharlesA's profile
CharlesA
3361 posts in 2037 days
#4 posted 10-02-2013 12:55 AM
I’d been considering these before I saw the review, but hadn’t picked them up, in part because I only go to Lowe’s when they have something no one else carries (long story about corporate ethics). Anyway, I was headed to HD to pick up a pvc piece I needed and remembered this review, so I dropped by and picked up some 80, 120, and 180. Since they are $15/10 pack, I decided not to buy any other grits. Just used the 80 and 120 on a glued up table top (I was getting it reasonably smooth before cutting it to its final round shape, and I was pleased and surprised after using each. They looked completely unused. I have a bad habit if using my ROS like an angle grinder to quickly sand down a larger defect, and this completely messes up my usual Bosch discs, but couldn’t tell I had done it with these.
We’ll see if they’re worth the money, but so far I agree with the review.
Purrmaster
#5 posted 10-02-2013 03:11 AM
The “looking unused” thing can be deceptive. I’ve used them for quite a while and they looked virgin. Then I compared by touch to fresh discs and found they had worn quite a bit.
The hole pattern on Diablo discs is annoying.
