Delta Heavy Duty Precision Miter Guage 36-946
Review by stanley2 posted 538 days ago 1151 views 0 times favorited 16 comments Add to Favorites Watch
Delta Heavy Duty Precision Miter Guage 36-946 No-picture-s No-picture-s Click the pictures to enlarge them
I have only seen this miter guage on ebay – never in a store nor in a Delta catalogue. When you search the product number on the Delta website it only comes up as an accessory to their hybrid tablesaw. The ebayer who lists it sells one a week and I lowballed it for 2 years before I finally got it for $80, including shipping. In the last two weeks they have sold for less than my $50.
What an improvement for my vintage unisaw! The design is excellent including an eccentric lock screw to set the guage to a true 90 degrees to the blade. This is a one-time step. It can be used in the left or right slot with simple changes to the assembly. Changing the fence angle is a snap by loosening the set screw and sliding the telescoping scale bar in or out to the degree number you want and re-setting the set screw. The scale has a number of detents for more commonly used angles for ease of setting the scale. The fence is easily moved side-to-side by loosening two thumb screws on the miter guage. There is an adjustable flip stop for fixing the distance of your piece from the blade for repetitive cuts. There is a quick release clamp, which I don’t use as I am used to using my hands over the fence to hold the work piece in place because I can see the operation better. Three expansion slots are provided to make fine adjustments to the slider.
The only shortcoming I have encountered is the height of the handle, which could have been made higher for a full hand grasp.
-- Phil in British Columbia
View stanley2's profile
stanley2
278 posts in 695 days
16 comments so far
View GaryK's profile
GaryK
9555 posts in 888 days
posted 538 days ago
Nice review, Thanks.
You could always make another handle couldn’t you, or even make an extension.?
stanley2
posted 538 days ago
HI Gary – I tried adapting a handle from a grinder but, naturally, Delta used a different thread.
View matt garcia's profile
matt garcia
733 posts in 571 days
posted 537 days ago
That looks a LOT like my Osborne miter gauge!! I love mine!! It was perfect right out of the box, and I used it righ in the middle of my Highboy project. I hope you like it, I love mine!!
-- Matt, Houston Texas
View Grumpy's profile (online now)
14948 posts in 751 days
posted 537 days ago
Great review Stanley. Looks like a good accessory.
View WayneC's profile (online now)
WayneC
6074 posts in 997 days
posted 537 days ago
You might check Rockler’s handles if you get a chance.
View sIKE's profile
sIKE
1094 posts in 653 days
posted 537 days ago
I have been looking at this one and the Osborne. Can’t make up my mind though, but if I can get it at $50 that could easily make up my mind.
stanley2
posted 537 days ago
Go on ebay and search “delta” – can’t miss it
View Dominic Vanacora's profile
Dominic Vanacora
504 posts in 769 days
posted 537 days ago
This is 6/10/08 and it now sells for $119.00. That would have been a great buy at 50.00 / a good buy at 80.00. But at 119.00 I don’t use it enough for that price.
-- Dominic, Trinity, Florida...Lets be safe out there.
View jonnyo's profile
jonnyo
1 post in 536 days
posted 536 days ago
I HAVE BEEN LOOKING FOR THIS FOR A LONG TIME ! I SAW NORM USING IT BUT HAVENT SEEN ONE ANYWHERE ! I LOOKED ON E-BAY, NOT THERE. NEVER HERD OF OSBORNE. WAS WILLING TO PAY SEVERAL HUNDRED DOLLARS. HELP!!!!!
WayneC
posted 536 days ago
stanley2
posted 536 days ago
So this morning the ebay listing is at $72 with 4 days to go while last week it sold for $41. Remember, this is an auction and this review might have influenced the number of bidders. Be patient because up to now the seller has listed one every week. Good luck
20807 posts in 721 days
posted 535 days ago
Phil,
This is a nice review. This looks like a quality miter gauge. Thanks for the post.
View mski's profile
mski
363 posts in 880 days
posted 517 days ago
I ordered the Osborne and sent it back it had 1/32” play, second one was worse, I had to peen the holes at the pivot points to tighten the play, (from a dull drill or improper drilling speed).
It works good for holding heavy or long pieces, the indexing button is not 100% accurate, always check when resetting. Osborne has excellent service, shipped the replacement 2nd day air the day I called, didn’t have to wait for the return. I paid $118.00
If I had to do over I would buy and Incra .
That Delta is the Osborne, made by Excalibur.
-- MARK IN BOB, So. CAL
View Kevin Willis's profile
Kevin Willis
9 posts in 488 days
posted 444 days ago
My Delta Hybrid saw came with one of these and I have a ton of trouble getting true 90 degree cuts with it…has anyone figured out how to get the “slop” out of it?
-- something profound should go here
3056 posts in 921 days
posted 444 days ago
No one has mentioned putting sandpaper on the carrying surface.
I found from experience that most of the inaccuracies I encountered were from the saw blade pushing the work away from the miter.
That certainly doesn’t offset poor manufacturing practices and quality control but it sure saves bad cuts when everything else checks out.
stanley2
posted 444 days ago
I haven’t found any play in mine. As for accuracy, I don’t trust automatic settings so avoid cutting errors by checking my set-up frequently. Sandpaper or a clamp is a good substitute for the stop block if the piece is too long in order to avoid stock movement during the cut.
