A HOME RUN FOR ROUTER TEMPLATES
Review by motthunter posted 09-13-2013 12:32 AM 3937 views 4 times favorited 9 comments Add to Favorites Watch
A HOME RUN FOR ROUTER TEMPLATES No-picture-s No-picture-s Click the pictures to enlarge them
I used this tape and had to say WOW!
It is an advance for the art of router templates like i have never seen. You tear off a piece of this tape and attach it to your router template. Peel off the backing paper and place the template on the wood you want to rout. The tape holds strong and when you are done, you pick off the template and it pops off with zero adhesive left on the wood.. No more scraping adhesive, no more lacquer thinner to remove the adhesive, no more crazy sanding. This is amazing.
I saw it at the Woodcraft store and had to get a roll. The guy there explained that the side you attach to the template has a strong adhesive but the side under the paper you peel off has low adhesion but really strong shear strength.. In other words things barely stick to it unless there is a bit of top pressure and it then can’t move side to side.
Anyhow, I got saw dust on the tape so I had to replace it with a new piece. Taking care to keep it clean though, I used a new piece of tape and was able to reuse the same tape on my template 3 more times without replacing the tape. Now my Mr. Science brain went to work.. This stuff is cool.. I took a thin veneer I couldn’t have sanded in my drum sander and attached it to some mdf and ran it through perfectly.. then I picked it up and didn’t crack the veneer.. Score!
Sorry for sounding so giddy, but this was the first really cool thing I’ve seen in woodworking in a long time.
You have to get some if you do any routing. I plan to play with it for more stuff. You can see it on the woodcraft site as follows:
http://www.woodcraft.com/Product/2085967/44688/Woodworking-Tape-2-x-50'.aspx
-- making sawdust....
View motthunter's profile
motthunter
2141 posts in 3914 days
9 comments so far
View bobasaurus's profile
bobasaurus
3530 posts in 3299 days
#1 posted 09-13-2013 12:41 AM
Looks really useful. Might have to pick up a roll.
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
View Mark Gipson's profile
Mark Gipson
189 posts in 3496 days
#2 posted 09-13-2013 12:48 AM
Have you tried it with a MDF template? Does it come off the MDF OK? The only double sided tape I found in Thailand sticks far too well to MDF, it’s very hard to remove the template from the work and impossible to remove the tape from the MDF!
motthunter
#3 posted 09-13-2013 12:51 AM
I used an mdf template and it came off perfectly.. even the strong adhesive seems to remove easily.. just not as easily as the removable side.. Of course I didnt leave it on for a really long time.. I don’t know if that adhesive would set up to be stronger over time.
Mark Gipson
#4 posted 09-13-2013 12:55 AM
Sounds good, I will have to add some to my next order and give it go.
View NiteWalker's profile
NiteWalker
2737 posts in 2692 days
#5 posted 09-13-2013 11:16 AM
Sounds nice but $30 a roll?
Come on now.
I’ll stick with my $8/roll carpet tape. So long as you don’t leave the pieces stuck together longer than 24 hours it comes off cleanly, mdf included.
View MontanaBob's profile
MontanaBob
832 posts in 2799 days
#6 posted 09-13-2013 11:49 AM
I’m going to give it a try….
motthunter
#7 posted 09-13-2013 11:51 AM
I used carpet tape once and thought the adhesive was off.. got a healthy surprise when I put my finish on … Ruined a 200 dollar piece of waterfall bubinga veneer… 30 bucks for 50 feet would have been a bargain since i only would have used a few inches…
View pintodeluxe's profile
pintodeluxe
5739 posts in 2928 days
#8 posted 09-13-2013 06:25 PM
Thanks for the info, carpet tape is a mainstay in my shop.
The carpet tape at Lowe’s is good too. It runs about $9 for a 75 ft. roll.
I use it on every project, and have never had any finishing problems with it.
motthunter
#9 posted 11-17-2013 07:08 PM
