Combination Hex Drill\Tap Bits: Easy Installation of Threaded Knobs and Rod
Review by DeLayne Peck posted 08-13-2013 08:26 AM 4340 views 1 time favorited 13 comments Add to Favorites Watch
Combination Hex Drill\Tap Bits: Easy Installation of Threaded Knobs and Rod No-picture-s No-picture-s Click the pictures to enlarge them
Maybe I just fell off the lumber truck, but I didn’t know about combination hex drill\tap bits. You don’t have to install a brass insert! Or, drill and then tap threads?! Do it all in one easy operation! Directly into wood with a low voltage driver!!
I have threaded a lot of brass inserts for the jigs I’ve built, like my Rip Snorter Push Block , and thought they were a pain. And, I have read about and used various methods for installing inserts. They work, but they are tedious.
I’ve looked a tap and die sets. I don’t need all that. Quarter inch, 20 TPI (threads per inch) is pretty much the standard in my shop. I always have a supply of nuts, bolts, knobs, and threaded rod on hand for jigs, hold-downs, connectors, and stops.
I found the Greenlee bits in a variety of sizes at Ace, $12. For a test drive, I slowly drove the bit into a block of Douglas Fir with an low voltage Skill driver. Then, threaded rod directly into the wood. It couldn’t be quicker and easier. And secure, standing on the block, I couldn’t pull the rod out.
I can foresee a lot of uses for this bit.
-- DJ Peck, Lincoln Nebraska. Lord, keep your arm around my shoulder and your hand over my mouth.
View DeLayne Peck's profile
DeLayne Peck
594 posts in 2401 days
13 comments so far
View woodklutz's profile
woodklutz
221 posts in 2968 days
#1 posted 08-13-2013 12:03 PM
Sounds like a great addition
On Amazon $8. with shipping, but a reviewer says not good for wood. What is your opinion?
-- honing my craft one mistake at a time.
View PurpLev's profile
PurpLev
8547 posts in 3848 days
#2 posted 08-13-2013 01:25 PM
an interesting accessory – I’ve never seen this.
Some more info from my experience: Greenlee is a company that is making tools for electricians. My guess is this bit is aimed at drill/tapping electrical boxes (sheet metal, or thin metal). where a combination like this could work and save time. otherwise for thicker materials this will probably not work so well as you need more room to clear chips as well as a tap with more torque to be able to sustain the deeper threaded holes.
That said – Wood isn’t exactly the material to be tapped. tapping relies on solid material that retains the thread, whereas wood has fibers that will sooner or later cause the threads to be non existent. For wood – as long as you drill the hole in the correct size, the screw/bolt once inserted can generate the threads in the wood all by itself to match it’s own threads. If you want to have “real” threads in a wooden application which is used to allow you to screw and unscrew that jig on a constant basis – you really do need to use inserts which will retain their threads.
Just my 0.02 – not to take away from this great looking drill/tap combination which I believe is great for it’s intended use.
DeLayne Peck
#3 posted 08-13-2013 01:58 PM
Greenlee offers an extensive range of products for the electrical trade. The opinion you found suggested it not the best for some applications, like soft materials, wood, and plastic, specially where there is high stress and/or wear. I’d agree, it depends on the application. The the bit should be used sensibly. There are applications where a brass insert would be wise.
At the same time, deeper in soft wood or less so in hard wood, there’s a wide range of wood shop applications with screws, bolts, knobs, and rods. And, Greenlee offers full sets and individual of bits in incremental sizes. Larger bits could be used in higher stress or higher wear applications. I like having the bit in my connector arsenal for the speed, ease, and possibilities.
Amazon’s product description bears repeating: Complete hole drilling, tapping, deburring and countersinking in one operation with power drill saves labor and time Back tapered beyond tap to prevent thread damage from over-drilling Deburr/countersink also provided on bit beyond back taper Made from hardened high-speed steel vs carbon steel for longer life Designed to tap up to 10-gauge metal
View NiteWalker's profile
NiteWalker
2738 posts in 2777 days
#4 posted 08-13-2013 04:45 PM
Re; tapping wood, I use a normal tap and it works great. I use my cordless drill to do the tapping going slow, but not a snail’s pace. Pouring a bit of thin CA glue on the threads hardens them to the point where inserts aren’t necessary.
I’ve done it with MDF, baltic birch plywood, oak, maple etc.
Wood holds threads surprisingly well.
View gtbuzz's profile
gtbuzz
427 posts in 2641 days
#5 posted 08-13-2013 08:36 PM
@NiteWalker
Never heard that before with the CA glue on the threads. Sounds like a great idea, I’m gonna have to try that.
View Woodknack's profile
Woodknack
12430 posts in 2580 days
#6 posted 08-13-2013 11:59 PM
DJ, I was looking at these awhile back and even asked about them on another forum but no one there had any experience with them. The Amazon reviews were all positive last time I looked. I look forward to reading your impressions once you’ve had some time with them and used them in a variety of materials.
DeLayne Peck
#7 posted 08-14-2013 05:04 AM
NIghtwalker!
Thank you for a very valuable contribution to this discussion. Your CA glue suggestion is a golden shop tip. Makes me wonder about using Wood Hardener. A couple of drops might work.
And, here is a tip: If your wife has wicked sense of humor, keep Wood Hardener away from her. She will taunt you with the can.
View MT_Stringer's profile
MT_Stringer
3183 posts in 3431 days
#8 posted 08-14-2013 08:30 PM
That sounds like a good idea for drilling/taping holes all in one operation. That got me to thinking. Liquid Nails construction adhesive is some tuff stuff. A little dab on the threads before inserting the bolt should seal the threads and make a permanent bond. Later if needed, the bolt could be backed out with a wrench. It is available in a hand size squeezable tube.
View ArtistryinWood's profile
ArtistryinWood
107 posts in 3887 days
#9 posted 08-15-2013 01:45 AM
Recently watched this on American Woodworker Site.
http://www.americanwoodworker.tv/videos/5025_machine-screw-joints/
-- It seem's to me i could live my life, a lot better than i think i am. Andrew, Midland, Ont.
View Mainiac Matt 's profile
Mainiac Matt
8553 posts in 2528 days
#10 posted 08-15-2013 03:43 PM
The key with tapping any machine screw threaded hole in a soft material is to make sure you don’t over tighten the screw. The mechanical advantage of the screw allows you to put an amazing amount of force on the threads with even a short wrench or decent tourque driver, you can easilly strip the threads.
You will definatley want to stick with UNC (coarse) theads.
I like the CA glue idea.
You can pick up tap sets on the cheap at places like harbor freight, but I’ve never personally seen the deep extension taps like the one shown in the AW clip.
-- I yam what I yam and that's all what I yam
Woodknack
#11 posted 08-15-2013 06:06 PM
The long taps in the AW clip cost around $30 each, it would be really spendy for a set although you’d probably only need one or two for woodworking.
NiteWalker
#12 posted 08-15-2013 07:18 PM
The tap I use is from lowe’s; kobalt brand.
Nothing special.
It’s been a hard worker in my shop.
View abie's profile
abie
878 posts in 3971 days
#13 posted 08-16-2013 10:43 PM
I’ve done this recently
Taped into wood slowly
then poured CA glue into the hole, let it dry over night then re tapped it slowly and I am happy with the result
wood was maple.
-- Bruce. a mind is like a book it is only useful when open.
