| Review by Len | posted 181 days ago | 530 views | 0 times favorited | 11 comments | ![]() |
- Ridge Carbide Tool High Performance Super Blade
- Brand: Ridge Carbide Tool | Category: Saw Blades
I first saw this blade demonstrated at a woodworking show, and was amazed at the smoothness of each cut. The guy not only used the same blade throughout the 3 day show, but intentionally stopped pushing a piece through a cut, removed his hand, and answered a question. While reciting the “don’t try this at home” stuff, he explained that the blade is so perfectly flat, he could get away with doing it. And, because it’s so perfectly flat, you don’t need a stiffener, which other manufacturers recommend.
That was about 10 years ago, and I’ve never been disappointed. I send it back to them for sharpening, and it’s back in only a few days. I called a month ago to order a blade for my chop saw, and had that in a couple of days—and the chop saw has never performed so well. It’s the only blade I’ll ever buy.
-- Len Rogers
11 comments so far
jcees
home | projects | blog
473 posts in 339 days
posted 181 days ago
That thick [.110”] blade plate is what makes it such a honey. I won’t use a “thin kerf” blade anymore—unless you hold a gun to my head. But seriously, I’ve found that industrial blades use the thicker plates and that alone makes for a whole lot less headaches, i.e. flutter, burns, teeth marks, vibration, ragged rips and crappy crosscuts. Be Gone! Buy a better [heavier] blade and be done with it. Selah.
Besides, the only reason mfr’s came out with thin kerf blades was to allow those puny and woefully underpowered contractor saws to actually make it through a 2×4 without choking or blowing the breaker.
always,
J.C.
-- "Imagination is more important than knowledge" -- Albert Einstein
GaryK
8565 posts in 528 days
posted 181 days ago
Len – nice review.
jcees – I prefer a thin kerf blade even with my 3hp Unisaw. It doesn’t seem like much, but I like the material I save from turning into sawdust. I have no “flutter, burns, teeth marks, vibration, ragged rips and crappy crosscuts” using my Forrest WWII blade. Maybe I’m just lucky though. :-)
Greg3G
686 posts in 625 days
posted 181 days ago
Hey Len. I use this blade as well. I love it. Cuts easily and never had a problem with burning, and I have cut a lot of cherry and oak. Does well with both.
-- Greg - Charles Town, WV
teenagewoodworker
2143 posts in 308 days
posted 181 days ago
thanks for the review. i can see what you mean, i never really like using the 10” regular blades, it may be different but if i can i use an 8” blade as is works for most of my cuts. less vibration and everything to.
USCJeff
815 posts in 608 days
posted 181 days ago
Can’t believe he stopped holding the board. I’m glad he’s confident in his product, but wow, any number of things with the saw can happen.
I’m using a higher end Freud TK blade currently. Fairly satisfied with it. I would like to try a WWII to see what the rage is about. I haven’t noticed deflection with the TK. I’ve read that it is possible when shaving a piece, but haven’t noticed it yet. Nice review.
-- Jeff, South Carolina
9950 posts in 362 days
posted 181 days ago
Len,
This is a good review. I have never tried out this blade but it does sound as if it is a pretty good one to have.
Thanks for the post.
TomK
398 posts in 414 days
posted 181 days ago
I use this blade too, but have only had it for two months. It makes my underpowered saw perform great. Customer service is great too. I broke a carbinde tip off one tooth while changing to my rip blade, and they fixed it, no charge, just paid shipping.
-- North Texas
Tim Dorcas
80 posts in 398 days
posted 180 days ago
I have this blade. I find it works great in hard woods, soft woods, melamine, or just about anything I throw at it. I do think a thin kerf is the way to go however. I make a lot of small items. It’s a bit of a pain using the band saw and then planing it down. At some point I would like to try using some of the other “high end” blades to see how they compare.
Nice review!
-- www.responsetolight.com - A Woodworking & Renovation Blog & www.craftedbytim.com - I make. You buy.
6735 posts in 391 days
posted 180 days ago
Thanks Len. Blade technology has improved ouit of sight recently.
grovemadman
549 posts in 312 days
posted 179 days ago
Thanks for the review. It might be a good blade for some applications. I will stick to Forrest blades though.
-- --Chuck
twomartinis
3 posts in 233 days
posted 144 days ago
I have this blade – A-mazing. Initially got it for crown molding on our kitchen renovation. Now it cuts everything else like hot butter too!
-- http://www.flickr.com/photos/74108677@N00/
