a big time saver
Review by randy hudon posted 07-25-2013 06:42 AM 5443 views 0 times favorited 8 comments Add to Favorites Watch
a big time saver No-picture-s No-picture-s Click the pictures to enlarge them
I bought this sander a year ago and wish I had purchased one years ago. this machine saves hours worth of hand sanding. the only problem I have with it is the feed belt tracking. I have to adjust it after a few hours of use but it is a simple chore to readjust
View randy hudon's profile
randy hudon
22 posts in 2033 days
8 comments so far
View Ottacat's profile
Ottacat
495 posts in 2088 days
#1 posted 07-25-2013 01:45 PM
What types of projects components do you use it on? What type of sandpaper does it take and how easy is it to change? Have you had any issues with it bogging down and tripping a breaker? Have you had any issues with it burning the wood?
View Guss's profile
Guss
94 posts in 2677 days
#2 posted 07-25-2013 09:40 PM
I also have this sander I had the tracking issue so I took all the rollers loose and squared up the rollers after that I was able to get my belt to track right. I do have bogging issues when its been running for longer then 30 minutes the motor gets hot and trips the on board breaker it used to trip the 20 amp in the box so I traded it out with a 30. I do have issues with saning end grain cutting boards the aluminum drum gets hot and will expand burining the sandpaper. it takes 3 inch sanpaper and I buy the bulk role and use the sand paper cutting jig it shown to make in the owners manual. for long grain sanding and fine thikness adjustments and finale sanding on all sort of thing it works great but with 220 the sanding is vary light or it will burn the project. its a super great little sander
View dahenley's profile
dahenley
136 posts in 2329 days
#3 posted 07-25-2013 11:48 PM
MORE More MORE….
Thanks Guss.
i would love to live up north where people sell table saws and drum sanders everywhere…. but here in the south…. its hard to come by used equipment and i just cant afford a new performax/jet drum sander…..... (college takes 99.99% of all my money….)
-- David Henley
View gfadvm's profile
gfadvm
14940 posts in 2926 days
#4 posted 07-26-2013 12:51 AM
If you only have to adjust your tracking every few HOURS, you are fortunate. I have to adjust my Jet every few MINUTES :(
randy hudon
#5 posted 07-26-2013 02:34 AM
ottacat I use it for every thing from face frames and doors to materials I just planed down.i buy all the sand paper rolls in bulk length and what ever grit I can find.and yes when you get down to 220 or higher grit paper you have to take light passes or it will burn the wood but all my final finish sanding is by hand anyway. my last big sanding job was over a thousand lineal feet of base trim that I molded.the nice part of this machine is the variable speed feed rate from 1 foot a min to 12 foot a min
View Woodbum's profile
Woodbum
846 posts in 3301 days
#6 posted 07-26-2013 07:44 PM
I must be fortunate. I have a Performax 16-32 and have never adjusted the tracking on the feed belt. It WILL bog down and trip it’s integrated breaker on the motor if you try to take too big of a bite. The size of the bite varies according to what I am running and with what grit. I have never used higher than 150-180 grit. I leave the rest of the grits for the ROS, PC Speedbloc or by hand.This is probably one of the best investments that I made for the shop. It pays for itself on highly figured stock with grain running in every direction. Have you checked with the Griz service/technical folks? Maybe they can offer a more permanent solution. They were great when I had questions about my Griz machines.
-- "Now I'm just another old guy wearing funny clothes"
randy hudon
#7 posted 07-27-2013 12:49 AM
every machine I own is from grizzly and when ever I have a problem I call their service techs and have things fixed in a big hurry.i think the reason it tracks bad was my fault.i over tightened the feed belt and stretched one side of it
Rick Dennington
6347 posts in 3430 days
#8 posted 07-28-2013 02:39 PM
How’s the sander working out for you…..? Personally, I would have added in / out feed tables to handle long stock…...Cost a few more $$$, but well worth the added convenience….....
-- " At my age, happy hour is a crap and a nap".....!!
