Easy sharpening
Review by Iggles88 posted 07-24-2013 07:51 PM 6584 views 4 times favorited 6 comments Add to Favorites Watch
Easy sharpening No-picture-s No-picture-s Click the pictures to enlarge them
When I first got this sharpener about two years ago I did not like it too much, I didn’t know too much about sharpening and wasn’t getting the results I thought I would, I did some research and understood better what needed to be done to get a sharp edge, I only used the sandpaper that was included in the worksharp which is Norton sandpaper, I was pretty happy about that. They sell a honing kit that includes a 3600 and 6000 grit that I considered buying but since it came with the 3600 out of the box I figured that was fine enough. After getting the best edges I’d ever gotten I still thought it could be better so I bought the leather hone that worksharp sells. I cannot recommend the leather wheel enough, what a difference! I could not believe how sharp the edges I was getting were, it was almost scary how sharp they’d get. I have read a ton of times that this isn’t the be all end all for sharpening and that more equipment would be needed to get the best edges but I firmly disagree. All I sharpen are plane blades and chisels and for those two things there isn’t anything this tool can’t accomplish. You’ll see in the picture that I built the stumpy nubs stand so that I could sharpen my wider plane blades on the top of the disks. I really recommend checking out his video at stumpynubs.com if you do happen to get this tool register the warranty online and they will send you free abrasive disks, I’ve had to deal with their customer service a few times and they have been great. Overall I’d say this tool cannot be beat for the money, don’t forget to get the leather wheel with it.
View Iggles88's profile
Iggles88
247 posts in 2595 days
6 comments so far
View Tom Coster's profile
Tom Coster
120 posts in 3072 days
#1 posted 07-24-2013 08:42 PM
For irons & chisels The Stumpy nubs set up really is great. Fast and easy. I tried the bar and Tormek jig for Lathe chisels and did not like it though. Just couldn’t get the right curve on the Ellsworth grind.
-- Tom, MI, SC
Iggles88
#2 posted 07-24-2013 09:17 PM
Tom your probably right I don’t think I’d be able to get used to sharpening turning tools either, but like I said I only need to sharpen plane blades and chisels so it does everything I could ever need. Also forgot to mention klingspors sells replacement disks that are much cheaper then work sharps offerings, I have used both and while worksharp definitely has better quality paper the klingspors lasts almost as long and comes with much more for a lot less money
View DamnYankee's profile
DamnYankee
3312 posts in 2796 days
#3 posted 07-25-2013 01:36 PM
I have the WS3000 and also built the StumpyNubs stand.
I sharpen plane irons, chisels and my turning gauges on it. Once they are all initially trued and sharpened almost all I EVER use is the leather honing disk. I keep it near my lathe and the table I do most of my plane and chisel work at and before I use any plane, chisel or gauge I run them on the honing disk for a few seconds and do so periodically (for chisels and gauges) as I use them. Unless I happen to nick a plane iron, chisel or gauge I never resharpen and only hone.
-- Shameless - Winner of two Stumpy Nubs Awards
View Gerry's profile
Gerry
264 posts in 3474 days
#4 posted 07-25-2013 05:29 PM
Thanks for this review, and the inspiration. I have the WS 3000 as well, have been using it for a couple of years, and, like you, had not begun using it to it’’s potential till recently. You are so right about the honing wheel and it’s effect on my tools. Surprising and awesome!
I will build the sharpening work station by Stumpy with one modification. I have found their wide blade accessory to be most useful for it’s heat-sinking characteristics when sharpening a wide blade, like the setup for all other blades with the built in heat sink. However, once you get the right angle ground on the blade, touch up is easy using the leather wheel, and heat is no longer a big issue.
I’ve not tried sharpening lathe tools ( don’t have a lathe) as yet, but the see through charqcteristics of the disk makes it easier, and cleaner than the wet wheel, IMO.
Overall, I too am pleased with the ease of sharpening, and the performance of my sharpened tools. I’ll use my honing wheel more!
-- -Gerry, Hereford, AZ ” A really good woodworker knows how the hide his / her mistakes.”
Iggles88
#5 posted 07-25-2013 08:21 PM
Yankee, you seem to use it the same exact way as I do. I only touch my tools up on my leather disk unless on the slim chance something more needs to be done. I probably do it too much maybe once every 15 minutes because I love my tools to be as sharp as they can be. Thanks for the response
Gerry the stumpy stand has been amazing for the storage, one thing I would recommend though is to make as many slots for the disks as you can fit. I spaced my shelves a little more then I probably should have and have run out of room for all my disks. Of course I have 5 glass disks, 2 edge vision wheels, the leather hone, surface conditioning wheel and two mdf disks so I probably have more then most but you never know when your going to want to add more. I have the same grit on both the top and bottom of each disk so I can use the sharpening port then go right to the back without flipping them, which is why I have 5 glass wheels.
View douglbe's profile
douglbe
370 posts in 4195 days
#6 posted 07-27-2013 03:37 AM
Very nice review, I to have the 3000 for a few years now and I love it. The Stumpy Nubs station is on my to do list, I may just have to move it up a few notches and get it done.
-- Doug, Reed City, Michigan
