First Re-Saw with this blade
Review by Adam posted 07-23-2013 12:42 AM 3651 views 0 times favorited 7 comments Add to Favorites Watch
First Re-Saw with this blade First Re-Saw with this blade First Re-Saw with this blade Click the pictures to enlarge them
I had purchased a 1 hp King bandsaw for $80 off Kijiji (Canada’s Craig List) and gage it a complete overhaul and added a 6” riser kit to it. I purchased a Little Ripper Bandsaw blade for $36 from R&D Bandsaws are located in Brampton, Ontario, just 30 min from me.
This is my first real experience re-sawing anything substantial with it and it worked very well. This is 12” of hard maple and the surface finish is not the best but that is because I kept on stopping a starting. It was slow going with just a 1 hp motor but I would have never gotten though this material if I had not purchased this blade. Overall it was a good purchase.
-- Adam, St. Catharines, Ontario, Canada
View Adam's profile
Adam
84 posts in 3298 days
7 comments so far
View Surfside's profile
Surfside
3389 posts in 2409 days
#1 posted 07-23-2013 08:57 PM
The results look great. Nice resawing. Great review.
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
View WayneC's profile
WayneC
13794 posts in 4333 days
#2 posted 07-23-2013 09:03 PM
Thanks for the review.
View Howie's profile
Howie
2656 posts in 3159 days
#3 posted 07-23-2013 11:53 PM
Tell more about the blade. TPI? blade width? Overall doesn’t look that bad in the picture.
-- Life is good.
View Dusty56's profile
Dusty56
11830 posts in 3924 days
#4 posted 07-24-2013 03:11 AM
Your link doesn’t work at this time ;
Not Found
The requested URL /who was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Apache Server at www.tufftooth.com Port 80
Tell us something about the blade that makes it worth 4 stars. That’s what makes it a “review”. Was this your one and only cut with the blade ? How many tpi , raker , skip tooth, or what type of blade ? : ) Thanks.
View OakHill's profile
OakHill
282 posts in 2030 days
#5 posted 07-24-2013 10:23 AM
Thanks for the review. I made a copy of the info for my band saw file.
Thank You
-- John, Illinois, http://OakHillWoodCreations.com
View Adam's profile
Adam
#6 posted 07-24-2013 08:32 PM
The Website is http://www.tufftooth.com/
The Blade is 5/8” x .025” x 3TPI and is tungsten impregnated silicon blade. The website states that it will make the cut cleaner and faster than a normal band saw blade. Extra hard, stays sharp and cuts straight. It is extra wide to add stiffness to the blade, has a thin kerf and cuts extremely smooth. All of which I experienced when using it and after cutting through 4 pieces of this hard maple the blade seems just as asharp as when I started.
Dusty56
#7 posted 07-24-2013 10:58 PM
Nice job, Adam . Thanks for the link and the info : )
