Rockler - Jig It Drill Guide (Rating: 5)
If you don't have a drill press, (or even if you do) the Jig It Drill Guide by Rocker is a great little jig.
For those who don't have a drill press but want to use forstner bits; the drill guide helps keep your power drill steady allowing for more precise holes. For those who do have a drill press there are certain times when it's just not possible to use it. I needed to drill some bench dog holes into my workbench. I wanted to use a forstner bit with my power drill. The Jig It Drill Guide made this easy. It kept my power drill steady, and the end result was a perfectly centered hole.
For more specs, and detailed pictures check out my entry over at woodlogger.com
