Ridgid T1300 Planer Blade Replacements
Review by OakHill posted 07-02-2013 08:41 PM 4681 views 0 times favorited 18 comments Add to Favorites Watch
Ridgid T1300 Planer Blade Replacements No-picture-s No-picture-s Click the pictures to enlarge them
As an owner of the Ridgid T1300, buying new blades from Home Depot or
Ridgid is darn near impossible. While searching the internet for replacements
I found the Powertec 128070 blades. Advertised as “Replacement blades for
the T1300”
Two sets were purchased through Amazon for $25.19 per set. A few dollars
less than the price at Home Depot, when they were available.
Upon receiving the blades the first thing I did was inspect the blades using a
Micrometer. The thickness was .073, the same as the original blade. Next I
checked the width and it was .747, only .002 narrower than the original. The
dimensions were consistent from end to end.
Test cuts were made using 1×3 Red Oak. Depth of cut started at 1/32 in.
and increased in increments of 1/64 in. up to 3/32 in. per pass. As
a rule of thumb, I stay at or below the 3/32 depth of cut as a personal preference.
The Ridgid T1300 states that its maximum depth of cut is 1/8 in.
All cuts produced a finish smooth enough that it could go to final assembly.
Example being the Fish Trivet Set as seen in my projects list. The “Ribs” of the
Fish were planed to size and only required corner sanding after assembly.
The next test will be how long they hold an edge. As of now they have my approval.
-- John, Illinois, http://OakHillWoodCreations.com
View OakHill's profile
OakHill
282 posts in 2035 days
18 comments so far
View gfadvm's profile
gfadvm
14940 posts in 2931 days
#1 posted 07-03-2013 12:59 AM
Thanks for posting this and please let us know how they hold up.
I still have my “disposable” Ridgid blades sharpened and am very pleased with the results.
View Chris 's profile
Chris
1879 posts in 4232 days
#2 posted 07-03-2013 02:32 AM
Hey John… I have the same planer and I appreciate the review. Do you happen to have a link to the blades handy?
-- "Everything that is great and inspiring is created by the individual who labors in freedom" -- Albert Einstein
gfadvm
#3 posted 07-03-2013 03:10 AM
The pic shows a 2 blade set. My model uses 3 blades so I need my model # to figure out which set to order?
OakHill
#4 posted 07-03-2013 10:03 AM
Chris
I used a search engine and typed in “Ridgid T1300 replacement blades”, or you can go directly to Amazon.com and do the same. I am not up to speed on how to add a link yet.
I could not find a direct link to the Powertec Company.
OakHill
#5 posted 07-03-2013 10:33 AM
gfadvm
I will try to keep track of the number of board feet planed (and wood species) before they are changed to the second side. I will post it on this review and will also post it to your page when that happens.
As to your three blade question, assuming it is a Ridgid then I suspect that your model is the newer R4341.
Those should still be available where you bought the machine. However, if you are looking for an alternative source, then see my reply to Chris and just substitute your model number.
Thanks for asking
View Tennessee's profile
Tennessee
2893 posts in 2755 days
#6 posted 07-03-2013 02:00 PM
Oakhill, thanks for the post. I don’t use my Rigid T1300 much anymore, but I also sharpened my blades, a lot! It’s nice to know there is still a good source for replacements out there.
gfadvm
#7 posted 07-03-2013 04:31 PM
Thanks for the reply John. Mine is a newer 3 blade model.
View Hawaiilad's profile
Hawaiilad
3312 posts in 3262 days
#8 posted 07-03-2013 10:36 PM
I also have the Rigid 13” planer and it’s time to turn over the blades for the first time. No matter what I do, I can not release the screws holding in the blades. I am afraid I will either break the screw head off or strip it out. Have any of you owners had this problem and what did you do to correct it?
-- Larry in Hawaii,
gfadvm
#9 posted 07-04-2013 12:23 AM
Use the CORRECT sized metric driver in a battery powered impact to break them loose. Or insert that driver and give it a smack with a hammer (Ridgid tech showed me that tip) to loosen them.
That factory tool will strip them out as it isn’t a perfect fit.
Check yours but I’m pretty sure a 4mm driver is what I use.
OakHill
#10 posted 07-04-2013 01:43 AM
Hawaiilad
I remember the first time I went to change over the blade it seemed awkward as to which direction to turn the wrench.
If you have the Ridgid Model T1300, it should have a tool compartment on the left hand side, as you are facing
the infeed side of the machine. There should be an open end wrench hanging in there.
The wrench fits very good on the square head screws holding in the blade, on my planer. To loosen them I turn the wrench from left to right.
I hope this is of some help.
Hawaiilad
#11 posted 07-04-2013 07:42 AM
I will have to check tomorrow to see which model I do have. I know it uses 3 blades. I have heard about taping on the screw head before…I will try that. Thanks for the answers guys
-- Larry in Hawaii,
View Dusty56's profile
Dusty56
11830 posts in 3929 days
#12 posted 07-05-2013 05:41 AM
Thanks for the info : )
Chris
#13 posted 07-05-2013 05:54 PM
Hey guy’s I have one more question for you Ridgid owners…. well, actually two:
1) do you know if I can purchase replacement blade retaining screws/nuts?
2) Have you ever had feed issues where the rollers are slipping constantly? this just started on me this morning. and yes, I have cleaned the rollers.
OakHill
#14 posted 07-05-2013 08:46 PM
Chris
I found two sources for Ridgid spare parts: Toolpartsdirect.com & ereplacementparts.com
I have not personally had any experience with either of these sources, but made a note in my Ridgid file as to their existence. Locate your model number, then open the schematic and look for the part in question. Take the number in the schematic and look in the list of parts for cost and availability.
As far as your feed issues, sorry I have not encountered that problem yet! I’m sure someone will respond to it.
Hope this helps.
gfadvm
#15 posted 07-05-2013 08:59 PM
Chris, I picked up replacement screws at the local Ridgid service center. But if that’s not handy for you I’ll bet Ace Hardware or Fastenall can match them.
As far as the feed problem: you have cleaned the rollers, now wax the table and check that your depth of cut is not set too deep.
showing 1 through 15 of 18 comments
