Porter Cable should be ashamed to have their name on these
Review by A Slice of Wood Workshop posted 06-28-2013 04:48 PM 3006 views 0 times favorited 20 comments Add to Favorites Watch
Porter Cable should be ashamed to have their name on these No-picture-s No-picture-s Click the pictures to enlarge them
I bought these bits a year and a half ago. They were a “name brand” and in a price range I could afford at the time.This was a major mistake on my part. I bought an expensive sticker with crappy bits in the box. These bits are very cheap and not worth your time or money. I’ve seen reviews on these bits before usually stating that the person just bought them and they work great. That’s the truth. They work great during the “30 day satisfaction” period. These bits dull very quick and heat up even quicker. Over time they will just give you frustration and need to be resharpened over and over. The only thing they are good in is to drill in pine or other soft woods (if that). Don’t waste your money. Buy a quality bit, one at a time if that’s all you can afford.
-- Follow me on YouTube- http://YouTube.com/user/asliceofwoodworkshop
View A Slice of Wood Workshop's profile
1080 posts in 3411 days
20 comments so far
View whope's profile
whope
147 posts in 2683 days
#1 posted 06-28-2013 04:59 PM
Hmm. I bought the same set a couple years ago. I guess I’ll replace them one at a time..
-- Measure it with a micrometer, mark it with chalk, cut it with an axe.
19610 posts in 2094 days
#2 posted 06-28-2013 05:09 PM
Yeah, I bought same set for $15. As cheap as they were I’m not surprised. I have noticed that they have dulled, but I can’t complain much for $15.
View lab7654's profile
lab7654
266 posts in 2484 days
#3 posted 06-28-2013 05:27 PM
Well I was about to go out and spend a $50 Lowes gift card on these. Thanks for steering me away, now I can pick up a Marples ripping blade.
-- Tristin King -- When in doubt, sand it.
View 1yeldud1's profile
1yeldud1
301 posts in 3279 days
#4 posted 06-28-2013 05:32 PM
Hmmmm, – I have the same set I purchased about 3 years ago – I’m wondering if the have cheapened them up as mine has held up well drilling into oak and walnut.
View OhioMike's profile
OhioMike
79 posts in 2400 days
#5 posted 06-28-2013 06:44 PM
Sometimes the drill press is the culprit. I’m not saying that’s the case here, but it was for me. I started woodworking with a bench top drill press with a “slow” speed of 600 rpm – too fast for large bits. When I used a larger diameter forstner bit, smoke would rise up from the hole and the bit would get hot enough to turn blue – ruining the temper and dulling the bit.
After I upgraded to a drill press with a slow speed that’s under 200 rpm, the problem disappeared.
Mike
View Tennessee's profile
Tennessee
2893 posts in 2752 days
#6 posted 06-28-2013 07:03 PM
I have a set of these about two years old. The 7/8” bit has drilled over 50 holes, a lot of those holes end grain, into the sides of all those guitars to make the hole for the jack. Just in the last 4 or 5 did I have to sharpen the 7/8” bit once then it was fine again. All the other ones don’t have that kind of use, but I drill some tough exotic hardwood, and so far, so good. Maybe you got a bad cast or they changed suppliers?
#7 posted 06-28-2013 07:09 PM
Mike, I like your theory. I could define tilt see the high speed killing a larger bit. My smaller bits however are the same way. I may have got the bad batch or something. I do use a bench top press, so maybe guys should stay away from these bits if they have the benchtop versions. I would think that drill bit suppliers would consider guys using a benchtop drill press though instead of just manufacturing for floor models.
View pintodeluxe's profile
pintodeluxe
5816 posts in 3050 days
#8 posted 06-28-2013 07:21 PM
I am familiar with cheap Forstner bits. Mine are not P.C. brand, but probably similar quality. I sharpen them with diamond hones to keep them going. The slowest setting on my d.p. seems to work best.
You get the feeling that P.C. is just putting their brand on stock items to make them sell.
Same with Dewalt. Although I really like my Dewalt tools, their blades and sandpaper are not always top notch.
View cutworm's profile
cutworm
1075 posts in 3031 days
#9 posted 06-28-2013 07:55 PM
Thanks for the review.
-- Steve - "Never Give Up"
View bobasaurus's profile
bobasaurus
3546 posts in 3421 days
#10 posted 06-28-2013 08:29 PM
I’ve been using the exact same set for about a year now without any trouble, drilling very hard woods.
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
View Manitario's profile
Manitario
2703 posts in 3120 days
#11 posted 06-28-2013 10:26 PM
I’ve spent probably more money on “cheap” tools than on quality ones over the few years I’ve been woodworking, including “cheap” brand name sets of forstner bits/drill bits and router bits. Found almost universally that they all dull quickly. I’ve started buying all of them individually and although the initial expense is more, in the long run I’ll save money.
View whitebeast88's profile
whitebeast88
4128 posts in 2428 days
#12 posted 06-28-2013 10:28 PM
i bought a set less than a year ago and figured they’d be decent but didn’t know how much i would use them.so far no problems but will invest in better ones later on.thanks for the review.
-- Marty.Athens,AL
View NormG's profile
NormG
6378 posts in 3241 days
#13 posted 06-29-2013 01:21 AM
I had to go look, I thought I had this set but I have the PCFSB12 1/2 to 2 inch set. I also have some singles I had purchased, they look he same, I only have a bench top and run it slow speed. I have made a few cube within a cube without issue
-- Norman - I never never make a mistake, I just change the design.
View robscastle's profile
robscastle
5631 posts in 2441 days
#14 posted 06-29-2013 04:14 AM
Yep know the feeling guys, every now and then we get some clinkers in our good gear
I have a reasonably good (expensive) set of Forstner bits, and they cut very well, apart from the biggest one which is 54mm. You would think it would be the easiest to grind and sharpen.
All it did was cut an edge circle and then chewed at the timber, no nice wafer of material spiralling out !
Upon checking it this is what I found
I guess it saves on having to sharpen both blades as this blade will never cut!
This was brand new unused straight out of the box.
The gap is so bad it cannot even be ground out, and typical the buy price for a single one to replace it is almost as the set price.
Go figure !
-- Regards Rob
View Ken90712's profile
Ken90712
17614 posts in 3426 days
#15 posted 06-29-2013 08:12 AM
i have heard the same thing about these. Sorry to hear about this and good luck.
