A pleasant surprise from the Home Depot
Review by Chris Hudak posted 06-16-2013 08:10 AM 12427 views 0 times favorited 7 comments Add to Favorites Watch
A pleasant surprise from the Home Depot No-picture-s No-picture-s Click the pictures to enlarge them
It all started when my father in law gave his Craftsman radial arm saw. I am am his favorite son in law after all (my wife is an only child.) Well I soon found out that life is too short to mess with with a Craftsman radial arm saw. When I finally got the thing aligned and running the blade would slow down and jam in the wood and it would be out of alignment all over again. Not wishing to inflict this pain on another human being I took the dang thing to the dump. The man working there seemed happy to get it. Good luck with that! Anyway, cheapskate that I am, I checked out the HF 10” Sliding Compound Miter Saw. I had a coupon for 79.99. Not a bad price at all. However, this unit seemed to be built very cheaply and I thought it would not hold up even in home workshop use.I had some gift cards saved up from Home Depot so I went there to see their saws. I ended up buying the Ryobi 10” Sliding Compound Miter Saw for 199.99 and 25.00 for the replacement warranty. Since the saw has a 2 Year warranty this covers the saw for 4 years. Well worth it I thought. The box says it has a 3 year warranty so maybe its 5 years? Anyway, the Ryobi is well built for its price and has nice fit and finish. It is not heavy at all so it wuold be very portable. This was not an issue for me as mine is used in my woodshop. It was not aligned perfectly out of the box but took only about 30 mins to square up. The saw comes with a 40 tooth blade that would be OK for construction projects. Luckily I had a 60 tooth negative hook blade I had purchased for radial arm saw. With that blade installed the saw cuts very well . It has plenty of power and the slides are very smooth. The included dust bag only catches a small amount of the dust that flies everywhere but I knew it would not. Also the laser does not work well for long as it becomes covered up with sawdust and pitch very quickly. However, that is also not a problem for me. I have noticed that the detents for the angles while accurate, do not lock in very solidly so one must be careful about that when changing angles. Overall, I think this saw is a great value for the price and I would recomend highly to a woodworker on a budget or just a tightwad like me! I gave it 4 stars because of the issues with the bag, laser, and soft miter detents but dont let that stop you. This is my first post and i thrilled to be a part of Lumberjocks Thanks Chris Hudak
View Chris Hudak's profile
Chris Hudak
6 posts in 2071 days
7 comments so far
View RonInOhio's profile
RonInOhio
721 posts in 3106 days
#1 posted 06-16-2013 08:37 AM
I purchased a Ryobi 10” CMS about 5 years ago. Very pleased with the accuracy and decent quality, (for the price point) of this saw. It’s a budget tool, but seems well built. One of the most often used tools in the shop .
View whitebeast88's profile
whitebeast88
4128 posts in 2432 days
#2 posted 06-16-2013 11:20 AM
thanks for the review.
welcome to lumberjocks!!!
-- Marty.Athens,AL
View eddie's profile
eddie
8565 posts in 2855 days
#3 posted 06-16-2013 05:19 PM
welcome to LJ ,i have the same saw its ok and has did what it was suppose to but neve got it completly square but it close enough for a a decent cut
-- Jesus Is Alright with me
View Tennessee's profile
Tennessee
2893 posts in 2756 days
#4 posted 06-18-2013 05:31 PM
Welcome to Lumberjocks!
I own the new style of HF 12” double compound sliding. I love the thing, after I got rid of a runout issue that was caused by washers that were on the blade shaft for some strange reason.
I looked at the Ryobi – looks like a pretty good unit.
View Kirk Hutcherson's profile
Kirk Hutcherson
42 posts in 2195 days
#5 posted 06-19-2013 04:34 AM
I have the same saw. It works great!
-- Kirk
View woodmaker's profile
woodmaker
321 posts in 2933 days
#6 posted 06-20-2013 04:38 PM
I had this same saw, loved for the 1st year hated it after that. It would not stay into alignment no longer than a month at a time. I’d saw a board and look at it and then go “why is that bevel there?” I hope you have better luck than I did. Sorry to sound negative, just sayin’
-- Mike
View MarkTheFiddler's profile
MarkTheFiddler
2068 posts in 2430 days
#7 posted 06-20-2013 09:37 PM
I had a problem with the fence warping after a lot of heavy use. I’m going to rebuild the fence when I get around to it. In the meantime, It just sits there looking lonely.
-- Thanks for all the lessons!
