Pretty good for the price!
Review by Sodabowski posted 06-12-2013 08:45 PM 3527 views 0 times favorited 13 comments Add to Favorites Watch
Pretty good for the price! Pretty good for the price! Pretty good for the price! Click the pictures to enlarge them
So I was tired of my crappy U-frame saw, made of steel tubing, having hacked it as much as I could to improve – that’s a lesser word – the blade locking mechanism. It kept twisting blades on me and they snapped too easily. So I litterally tossed it out and settled to raid eBay, in search for a better saw frame.
I had already purchased several times from the Proops Bros, and had noticed they carried a wide array of hardware, all made by themselves in the UK. And so I shelled out the £6.95 plus £3 postage for France, and a few other things (which didn’t graduate to my standards, but that’s another story). A week later the parcel comes in, bubblewrap and all.
Let me tell you straight: I love this little saw! It’s sturdy, once locked it doesn’t move (unlike the U-shaped ones), it adjusts to any blade length you have up to 6 1/2” (16,5 cm) down to as small as 1 1/4” (3,5 cm) if you’re really on a budget and you can’t buy new blades after the last one broke on you. Sure would be quite a thing to saw with something so small but you get the point: adjustability, which I didn’t have before.
The handle is a standard round handsaw one: plain boring white wood, but it’s decent enough for the calling price (could be a chisel handle). If you really pull hard enough (I didn’t try but it’s sturdily attached) you can certainly take it out and replace it with your own fancy pants handle turned out of solid mahogany from a parasol stick (Mads, are you reading me? ;p)
The blade is firlmy held between two rather large square nuts (11×11mm, 7/16” by), knurled on the inside for a nice grip on the blade, along with large flat thumbscrews: very comfortable to use, not like the wing nuts of the old (25€!) crap that I had before.
Frame length is adjusted by a 9/16” (16 mm) deeply knurled thumb screw, again really easy to adjust and once it’s locked in, nothing moves at all.
So if you’re shopping around for a nice little frame saw for small-scale veneer cutting (or if like me you plan on building a small tabletop chevalet to go around it), you can check this one out.
-- Thomas - Pondering the inclusion of woodworking into physics and chemistry classes...
View Sodabowski's profile
Sodabowski
2374 posts in 2861 days
13 comments so far
View poopiekat's profile
poopiekat
4356 posts in 3762 days
#1 posted 06-12-2013 09:54 PM
where can people in North America get them?
Sodabowski
#2 posted 06-12-2013 09:57 PM
Well, check their website, I don’t know their postage fees for N.A, but they don’t overdo it, and Royal Mail is cheaper than USPS anyway :)
View Dominik Matus's profile
Dominik Matus
104 posts in 1937 days
#3 posted 06-12-2013 10:31 PM
it looks like high quality saw. I am using Pichrt saws, it’s Czech brand. Their saws are very strong and light. See here http://www.pichrt.com/html/pilky.html (in Czech).
-- Cabinetmaker, restorer
Dominik Matus
#4 posted 06-13-2013 12:32 PM
http://www.pichrt.com/html/pilkyen.html it is in english too.
Sodabowski
#5 posted 06-13-2013 02:13 PM
Eww, that’s exactly the kind of saw I had before… the design itself is flawed because it flexes
Dominik Matus
#6 posted 06-14-2013 12:55 PM
You are right, but this (your) type of saw is useless for me, because It has a small frame. I’m often sawing big pieces of wood.
View Jamie Speirs's profile
Jamie Speirs
4168 posts in 2884 days
#7 posted 06-14-2013 01:55 PM
Dominik have you tried the Eclipse Range
Solid steel frame mine is 50 years old and I have
a 4 year old one, the difference is the new one is blue
not chrome
Jamie
-- Who is the happiest of men? He who values the merits of others, and in their pleasure takes joy, even as though 'twere his own. --Johann Wolfgang von Goethe
Dominik Matus
#8 posted 06-14-2013 04:02 PM
I meant this type. I need big frame to width. I’m very satisfied with this.
Sodabowski
#9 posted 06-14-2013 05:37 PM
Yep, the opening of the one from Proops is too small for big projects. I guess the one you bought from Pichrt is made of higher quality/strength steel than the crap I used before. As long as it doesn’t flex on you and break blades :)
Dominik Matus
#10 posted 06-14-2013 09:47 PM
Yes, it’s very high quality, made of steel tube. I tried to blend it, but nothing happenned. I sawed metres with it and blades are breaking only because of material.
View horologist's profile
horologist
104 posts in 3767 days
#11 posted 06-16-2013 02:00 PM
Thomas,
Interesting your saw appears to be a modern equivalent of this one. These saws are great, I buy them when I can and have an assortment that I keep set up with different blades.
For projects requiring more depth I also have these. I prefer this style over the tubular ones as you get more control over the blade tension and the frames are stiffer.
An extreme example, I haven’t really worked with this one and need to make a proper toggle for the saw, a future small shop project. When I bought the saw I had reservations about getting proper blade tension and it may well be that it won’t be very useful.
-- Troy in Melrose, Florida
Sodabowski
#12 posted 06-16-2013 06:15 PM
Ah Troy, the last one is a well-used model, it’s been around for ages and if memory serves it was the first design that allowed for tensioning of the blade. Mads made a similar one some time ago, and believe me (I have a very old one at the parents’ ) you can tension it so much that you can actually crack the arms.
The 6” throat version looks great for medium scale work!
View Ron Tocknell's profile
Ron Tocknell
42 posts in 1025 days
#13 posted 11-27-2016 11:36 PM
I have one of these jewellers’ saws similar to the Proops one. The one bugbear I have with them is that the beam of the adjustable bow extends over the handle, making them difficult to use without jabbing yourself in the wrist at every stroke. I solved this by pulling the handle off (which I can confirm is quite easy) and fitting it to the shorter ‘tang’ on the other end. Although this tang is shorter, it holds in the handle good enough for general use. I use it for cutting small pieces of M. O. P. for inlays. I don’t know why they’re made with the beam over the handle. It seems so illogical!
