Scheppach Deco-Flex - a decent starter scrollsaw for an OK price
Review by Skiedra posted 05-31-2013 05:57 AM 6570 views 0 times favorited 5 comments Add to Favorites Watch
Scheppach Deco-Flex - a decent starter scrollsaw for an OK price Scheppach Deco-Flex - a decent starter scrollsaw for an OK price No-picture-s Click the pictures to enlarge them
+ nice working capabilities
+ normal operating noise
+ large “throat” depth
+ takes both pin and pinless blades
+ the addons and the rotary tool is a perfect addition to a beginner scrollsawer. So you do not need to buy a dremel or any similar rotary tool
- bit painful process to change the blades. You have to rotate 3 screws, 2 on top, 1 at the bottom of the saw.
- you seriously need to bold it down, otherwise it moves
- attached rotating bit are a bit too “toyish”, but does some light sanding/drilling easily
- to change the blades, you have to tilt the table, and it takes effort to re-adjust the correct 90 degree angle
- throat depth is not big enough for larger templates.
For this price and as a starting scrollsaw, it fits me OK.
View Skiedra's profile
Skiedra
259 posts in 2287 days
5 comments so far
View stefang's profile
stefang
15881 posts in 3329 days
#1 posted 05-31-2013 08:31 AM
We have to be satisfied with what we have. My first scrollsaw was very basic and inconvenient in many ways, but I did manage to do a lot of fun work with it anyway. It sure beat sawing by hand.
Skiedra
#2 posted 05-31-2013 09:02 AM
Mike, truly, it is way much better than sawing by hand.
I juest tried to write down some limitations. I.e. a templete with many inner cuts would be bit difficult to make.
View Tennessee's profile
Tennessee
2873 posts in 2510 days
#3 posted 05-31-2013 12:26 PM
My first one was I believe a Skilsaw that took about three-four minutes to change out a blade, had too aggressive a cut, and also had to be bolted down. But I loved every minute of it. Now I have owned the Delta for about 11 years, and that is all I will ever need.
Scroll on, brother!
stefang
#4 posted 05-31-2013 08:02 PM
I have to admit that I wouldn’t appreciate my current good quality scroll saw if I hadn’t had a couple of lesser saws first. It’s all about relativity.
View clark101's profile
clark101
4 posts in 687 days
#5 posted 07-04-2016 06:14 AM
Thank you for your sharing. Actually this is the first times I hear about this name
-- Clark Kent, http://woodworkingtoolkit.com/scroll-saw-reviews/
