| Review by ShannonRogers | posted 188 days ago | 334 views | 0 times favorited | 6 comments | ![]() |
- Lee Valley Edge Trimmer Plane
- Brand: Lee Valley | Category: Hand Planes
I got a great deal on the set of these on ebay, but after using them on my new countertop and router table to trim edge banding I would definately pay full price in a heartbeat. These use the same thick iron and easy adjustment as all the other bevel up planes in the Veritas line. I followed the set up instructions included and was making shavings in just a few moments. After using the set screws to dial in the fit, I pulled out the iron and honed it up to 8000. The back of the iron was already flat and within a few minutes I have honed both the back and the bevel to a mirror shine. These things take a really clean cut and create some really funky shavings…
With the skewed blade I found that you get a clean cut with the grain as well as across the grain. I was planing the edge to my new router table and at the corners where the grain switches 90 degrees I was able to continue with the stroke and still get a really clean shaving. I also have used these planes as a quick and easy to control chamfering tool. I believe this was mentioned in the latest Woodworking magazine as well.
A very enthusiastic thumbs up from me on these planes. Having the set is really useful because you can just pick up the other one to switch directions in tough grain.
-- Check out my blog and podcast "The Renaissance Woodworker" at www.rogersfinewoodworking.com/blog
6 comments so far
jcees
home | projects | blog
473 posts in 339 days
posted 188 days ago
I was wondering if these puppies would be worth the price. Thanks for answering.
Always,
J.C.
-- "Imagination is more important than knowledge" -- Albert Einstein
9950 posts in 362 days
posted 187 days ago
Thanks for the review Shannon. I have been considering one of these. This looks like it is well worth the money.
tenontim
962 posts in 284 days
posted 187 days ago
Thanks for the post, Shannon. I’ve had these on the “short list” for a while. Didn’t know anyone that had used them. Glad they are “keepers”. Veritas makes very good planes.
-- Tim -- http://tmuli.com
teenagewoodworker
2143 posts in 308 days
posted 187 days ago
those are nice. i’ve seen those a lot but wasn’t sure how well it was going to work. thanks for the review.
Doug S.
218 posts in 248 days
posted 187 days ago
Yup. Handy little buggers to have and they work really well. The holes for attaching blocks is real useful too. I needed some 30 degree bevels a while back and made a angled hardwoor block for it. It worked great for cleaning up saw marks without worrying that I was messing up the angle in the process.
-- Use the fence Luke
263 posts in 188 days
posted 186 days ago
I owned a bronze one of these planes several years ago.
Honestly, I didn’t find it very useful. If you have a pair
so you can cut both ways that would overcome some
of the weakness of the plane in trimming edge-banding.
The blade angle is low. In theory this is good for end
grain work… but honestly I find that regular bench planes
do quite well on end-grain if they are properly tuned
up. I seldom use a block plane at all.
I liked the idea of the integral fence for squaring work…
but I found once I got some practice with bench planes
cutting square edges was too hard.
-- http://amherstcabinets.com - also a marketing consultant with expertise in direct response marketing for woodworking and online businesses - http://COPYMATCH.COM
