CMT Orange, Saw blade cleaner
Review by CalgaryGeoff posted 05-20-2013 06:59 AM 5066 views 1 time favorited 17 comments Add to Favorites Watch
CMT Orange, Saw blade cleaner No-picture-s No-picture-s Click the pictures to enlarge them
This is my first product review I’m writing, I can’t help myself. I’m impressed with the product so much I need to share my experience with it.
I never took before pictures as I never believed it would work so well. I cleaned three blades and I thought all required sharpening and had broken teeth, ok but close. They were full of pitch and tar from all the rough timber I use so I finally got to it as they were all off the saw since the dado stack was on.
This picture shows the after photos of cleaning. All I did was put the blades in a plastic tray and spray on the CMM Orange cleaner and let sit for maybe five minutes. I then took each blade out and placed it on a towel a scrubbed it with a tooth brush. Wow, did the blades ever came clean. If you use a scrub pad it could be better. Then I wipe off with a towel, spray each side and then wipe again with a clean towel. Results are terrific.
-- If you believe you can or can not do a thing, you are correct.
View CalgaryGeoff's profile
CalgaryGeoff
937 posts in 2716 days
17 comments so far
View alph's profile
alph
11 posts in 2097 days
#1 posted 05-20-2013 09:23 AM
409 works great too.
-- alberto angelo
View JoeinGa's profile
JoeinGa
7739 posts in 2241 days
#2 posted 05-20-2013 11:19 AM
Where can you buy this stuff? I’ve got several blades that are pitch coated and been wondering what would clean ‘em.
View SPalm's profile
SPalm
5325 posts in 4116 days
#3 posted 05-20-2013 11:33 AM
Nice,
I gotta do that.
Steve
-- -- I'm no rocket surgeon
View YanktonSD's profile
YanktonSD
190 posts in 2766 days
#4 posted 05-20-2013 12:39 PM
I to have tried different things from 409 to oven cleaner to whatever that green stuff is. But by far CMT blade cleaner is the best I was very surprised how well it worked to.
View longgone's profile
longgone
5688 posts in 3542 days
#5 posted 05-20-2013 01:44 PM
I have used Empire blade cleaner and have had excellent results. Obviously there are several great products available that do the job.
View waho6o9's profile
waho6o9
8539 posts in 2811 days
#6 posted 05-20-2013 02:08 PM
http://compare.ebay.com/like/120394293078?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar
Here ya go Joe, it’s Ebay close.
Thanks for the review
CalgaryGeoff
JoeinGa
#7 posted 05-20-2013 02:11 PM
Thanks Geoff!
View Woodknack's profile
Woodknack
12455 posts in 2614 days
#8 posted 05-20-2013 02:24 PM
Is it a citrus based cleaner? I’ve been using Home Depot brand orange citrus cleaner and it works very fast. Light pitch comes right off, thick pitch I let soak a minute or two and burned/hardened pitch comes off with a couple minute soak and a brass brush. Previously I tried WD40 and it worked but was slow compared to citrus.
View lumberdog's profile
lumberdog
245 posts in 3501 days
#9 posted 05-20-2013 02:30 PM
I use simple green and a little water, i put blade in plastic dish pan and cover with liquid and let set for 24 hrs. works great.
-- Lumberdog.. Morley, Michigan
View ic3ss's profile
ic3ss
391 posts in 3011 days
#10 posted 05-20-2013 03:36 PM
I use Simple Green. I pour enough in a parts pan to barely cover the blade and let sit for an hour then go over with a tooth brush, it just falls off. Then I pour it back into the jug to use again. I’ve been doing this for many years and it,’s not worn out yet.
Wayne
-- "I am endeavoring, ma'am, to construct a mnemonic memory circuit using stone knives and bear skins."
View OggieOglethorpe's profile
OggieOglethorpe
1276 posts in 2344 days
#11 posted 05-20-2013 03:39 PM
I think I’ve also tried ‘em all, oven cleaner to WD-40 to Simple Green to 409…
All things considered, I think the CMT stuff is a great balance of speed and effectiveness, with a lack of noxious fumes or skin irritation.
View lew's profile
lew
12495 posts in 3989 days
#12 posted 05-20-2013 03:46 PM
Thanks, Jeff. I gotta get some of that stuff!
View pintodeluxe's profile
pintodeluxe
5815 posts in 3047 days
#13 posted 05-20-2013 08:14 PM
the Purple colored Simple Green works excellent too. Available by the gallon (concentrated) at Home Depot.
I dilute it 50/50 with water. Safe for carbide blades and cutters. Be aware that the green colored simple green can erode carbide, but only if you soak the blade for extended periods.
Thanks for the review.
View NormG's profile
NormG
6375 posts in 3238 days
#14 posted 05-21-2013 12:14 AM
Speed is great, thanks
-- Norman - I never never make a mistake, I just change the design.
HillbillyShooter
5811 posts in 2526 days
#15 posted 05-21-2013 11:24 PM
Agree 100%, in fact I bought a gallon a few years ago to keep the 16 oz. bottle full. I’ve found that regular cleaning keeps my saw cuts at their best. I’ve used this CMT formula for 20 years and never been disappointed.
