| Review by mgradwohl | posted 131 days ago | 454 views | 0 times favorited | 11 comments | ![]() |
- Irwin Miter Saw Laser Guide
- Brand: Irwin | Category: Miter Saws
This weekend I bought and installed the Irwin Miter Saw Laser Guide onto my DeWalt Miter Saw. I’m very happy with it so far.
- It was easy to install
- It projects a crisp clean line to the left of the blade (unless your blade retaining nut is on the right of the blade)
- It is very helpful with complex cuts or cutting complex material
- It is less helpful with straight cuts on square material (it’s easier for you to know where the blade will be cutting in this regard)
- It was cheap
I bought mine at Lowe’s, but you can find it (and more reviews) at Amazon here
-Matt in Redmond, WA
11 comments so far
bobdurnell
home | projects | blog
160 posts in 378 days
posted 131 days ago
I have one of these, very similar but I got it at Rockler a while back. I can’t see the line very well when outdoors but I really like that it tells you ecactly where NOT to put your hand when making a bevel cut.
-- bobdurnell, Santa Ana California.
teenagewoodworker
2024 posts in 249 days
posted 131 days ago
that looks cool. i always though about getting one but i like to use the blade to see where it will cut.
GaryK
8487 posts in 469 days
posted 131 days ago
Hmmm. I wonder how it would work on a table saw? What size arbor does a miter saw have?
9024 posts in 303 days
posted 131 days ago
Thanks for the review. I have one of these as well. It works fine inside but, as Bob said, outside it is impossible to see in the sunlight. Since it projects slightly left of the cut line it does take some getting used to but it is a nice addition to a miter saw.
out2sea71
7 posts in 159 days
posted 130 days ago
I have also used this item but I have 2 installed on the miter saw; one on either side of the blade. The batteries have lasted almost 2 years without fail. My shop is in the basement so any additional light i can generate is welcome.
-- kein Schaden ohne Nutzen
4129 posts in 727 days
posted 130 days ago
I have a Rigid 12” in saw and I can’t find one that’ll work on it. I sure wish I could find one to. I’ve used them before and they are a great addition to a miter saw. I see the new Rigids have them but the new lasers don’t fit the older saws. mike
-- Mike. Profisher50@yahoo.com
gator9t9
282 posts in 185 days
posted 130 days ago
I have an INFINITER laser BEAM on my Dewalt Miter Saw ….And to answer Gary K question of how does it work on a table saw ..AS you know, the laser beam tool is about the size of a silver dollar maybe just a bit larger in diameter…It is mounted on the arbor and the speed of turning blade/laser lite projects laser beam down and below the blade of a miter saw .
...so on a table saw …the cut, which is above the blade …..the laser beam would be projected up …..so the laser would be below the stock being cut ….and so I dont think you would be able to see the beam …
I think ..
-- Mike in Bonney Lake " If you are real real real good your whole life, You 'll be buried in a curly maple coffin when you die."
Brad_Nailor
725 posts in 438 days
posted 130 days ago
Good review. I have been suggesting this to a friend.
Gary, the only thing this would do in a table saw is maybe project a cut line across your face, or down into the saw base! Not too effective!
-- Women love me.....trees fear me
mgradwohl
110 posts in 294 days
posted 130 days ago
- Matt in Redmond, WA
GaryK
posted 130 days ago
In reference to using one on the table saw.
I know how it functions. It would work the same on a miter saw as a table saw.
Sometimes I nibble away to get to just the right spot where I want to cut. I have to bend over the workpiece to check it out anyway. If the laser were consistant I could use it for my starting cut.
As long as I didn’t have a zero clerance insert installed I see no reason why it wouldn’t work.
Brad_Nailor
posted 129 days ago
I guess your right Gary, it would project a line up onto the front edge of the board, that you would be able to see if you bent over the table. That would take the guesswork out of where your starting cut would be. I have done that leaning over the saw thing a few times to look at the starting kerf…I never got a really great feeling doing it, so I try not to!
