MLCS Motorized router lift
Review by Indiana_Parrothead posted 04-22-2013 02:19 PM 15456 views 2 times favorited 13 comments Add to Favorites Watch
MLCS Motorized router lift MLCS Motorized router lift No-picture-s Click the pictures to enlarge them
I had decided to upgrade/build a new router table and wanted to add a router lift. When I started looking at options I found that there are many to choose from. Starting at the Woodpecker Side Winder lift at $245 upto the MLCS motorized lift at $389. Most of the better manual lifts were in the $325-$360 range. I decided to get the MLCS lift. I ordered it in early November and was put on a waiting list. The next shipment was scheduled to come in on Dec 31st. I found that all of those were spoken for and mine finally came in around mid March.
In the box was the lift fully assembled, an arm to hold the control box that clamps to your table, three router plate inserts, (two drilled and one you can drill your self) and all the cables. Since the aluminum plate is slightly bigger than most I also got the installation jig kit (#9331). After building the new router table (see picture, stock picture, not mine) I routed the top to install the router plate/lift. There are 4 setscrews in each corner of the mounting plate to make the plate flush with the top. I found that if you make the cutout the exect thickness of the plate (1/4”) and don’t screw in the leveling screws any, the top of them sticks out enough to scratch any material that you might be routing, it is better to make the cutout just a little deeper, about 1/16”.
The lift will work with any router that has 3 1/2” diameter motor body. I used a Poter Cable 690 that I had in my old router table. I did have to file off two of the “location studs” to get the router to fit. The fit was very tight when I put it in. The arm for the control box just clamps onto your table top, my top is 1 1/2” thick and it fit well. It looks like it can work on tops upto 2” thick. The arm is two piece that can adjust up and down. There were four cables that plug into the control box, the power cord, control line to the router lift motor, the height feedback and the line to the foot switch.
Here are my findings and why it got a 4 out of 5 stars.
There is a control for the speed that the lift moves up and down that is adjustable, from 5% to 100%. At the highest speed the operation is not very smooth, there were some “jumps” when moving both up and down at the highest speeed. At the lowest speed it was very smooth, moving about .001 to .002 with each touch of the pedal, great for setting the height you want.
The lift will lift the router high enough to change the bit from above the table which is nice. Once the bit is mounted you can lower it so the top is flush with the table and zero out the height gauge. Then raise it to the height you need. Once you are at the height you want you can also press the “hold” button that keeps it at the height you select in case you happen to hit the foot switch.
The the mounting screws for the rings are very small, they use a #1 phillips. There are three of them and one of the holes is covered by part of the lift and can’t be used.
I tested cutting some mortices raising the bit into the wood and it worked great. It is nice to keep your hands on the work piece and raise the bit into it and then retract it.
All in all it works very well and I think is worth the extra over a manual lift. It looks well built and has mostly metal parts and not plastic. Here are some things that I wished it had:
There is a height stop that can manually be set from under the table. It is a simple slide that hits a micro switch. It works okay but is hard to get it exect. A digital stop in the control box would be nice.
Variable speed on the foot switch would be nice. So that the further you pushed it the faster it would go. Having to change speed on the control box removes you hands from the work piece.
There are lots of cables, it would be nice if they included a piece of spiral wrap to combine all the cords.
Not too many cons, it is a nice addition that I will get a lot of use out of.
-- We are the people our parents warned us about.
View Indiana_Parrothead's profile
Indiana_Parrothead
110 posts in 3397 days
13 comments so far
View Matt Przybylski's profile (online now)
Matt Przybylski
570 posts in 2619 days
#1 posted 04-22-2013 02:31 PM
Thanks for the well written review. I’ve always wondered about this lift and if its any good. If I ever get another (I have the incra mast-r-lift II right now) I think I’ll give this one a chance.
-- Matt, Arizona, http://www.reintroducing.com
woodbutcherbynight
5837 posts in 2650 days
#2 posted 04-23-2013 01:45 AM
Someone somewhere will ask if it has a remote…...lol
View ScottKaye's profile
ScottKaye
718 posts in 2194 days
#3 posted 04-23-2013 01:07 PM
Does it have a remote? C’mon.. you know that was going to happen, after all you invited that comment! Seriously though, thanks for the well written review. Ill favorite this page so I can come back to it when I get to the point of deciding which lift is right for me.
Scottt
-- "Nothing happens until you build it"
View DeLayne Peck's profile
DeLayne Peck
608 posts in 2443 days
#4 posted 04-24-2013 08:19 PM
Great review. I’d love to have a motorized lift. I bought an expensive bit extension to get above the table changes. Now, I really have a lot of below the table grinding. Remote? My router table has a wind sock, top that.
-- DJ Peck, Lincoln Nebraska. Lord, keep your arm around my shoulder and your hand over my mouth.
117422 posts in 3818 days
#5 posted 04-24-2013 09:27 PM
Very good and interesting review.
woodbutcherbynight
#6 posted 04-27-2013 03:48 AM
Motion activated LED lights are the next shop craze….. (laughing)
View BBF's profile
BBF
143 posts in 2080 days
#7 posted 05-28-2013 03:13 PM
With just 2 posts holding it how stable is it when taking a heavier cut ie. panel bit.
-- I've never been disappointed buying quality but I have been disappointed buying good enough.
Indiana_Parrothead
#8 posted 05-28-2013 03:27 PM
I have not taken any cuts using a panel bit yet, the biggest cut that I have made with it so far is a 3/4” straight bit 1” deep. But even then I did it in severial passes. The nice thing that I found is that many passes doesn’t take as much time because you don’t have to stop and manually adjust the depth each time, you don’t even have to stop the router.
That being said the two posts are very solid and there is a lot of bearing surface on the router carrier. I think that you could get more flex in the shank of a 1/4” router bit that is extended far than you would in the bearing posts.
View MLCSmitch's profile
MLCSmitch
2 posts in 1156 days
#9 posted 11-24-2015 02:35 PM
Indiana_Parrothead Just curious if you still use this lift?
Indiana_Parrothead
#10 posted 11-24-2015 03:55 PM
I have been doing a lot more pen turning lately than flat work. But I am thinking about figuring out how I can make some pen boxes fast rather than buying them. They can get a little expensive and I think that I can get a lot of pen boxes out of a sq foot of wood. Most are just a rectangle that has been routed out leaving 4 sides so I think with being able to raise the bit into the wood should work pretty good.
woodbutcherbynight
#11 posted 11-25-2015 02:24 AM
- Indiana_Parrothead
Hit up Bearpaw, he made a jig for making them. The finished product looks great, I have two he gave me.
MLCSmitch
#12 posted 12-02-2015 01:35 PM
Indiana_Parrothead I am Mitch from MLCS Woodworking and would like to have a private conversation with you regarding the PowerLift. We have created a PowerLift PRO model and are working with some good customers to test it out. Can you send me a private message with contact info if you are interested?
View 2bad's profile
2bad
2 posts in 982 days
#13 posted 11-08-2018 02:00 AM
I love the idea of this PowerLift and am needing to make a replacement to a bad purchase. I sure don’t need another bad purchase but am a bit skeptical since the only post I find is this very good post by Indiana_Parrothead.Why would no one else be talking about this advancement? Should I go here or maybe go with Infinity’s table??
