JET 708100 - Excellent value
Review by TheDane posted 102 days ago 465 views 0 times favorited 5 comments Add to Favorites
View TheDane's profile
TheDane
18 posts in 106 days
JET 708100 - Excellent value No-picture-s No-picture-s Click the pictures to enlarge them
I purchased my Jet 708100 from a local machine shop, and consider it an excellent value.
Assembly was easy (once I figured out some missing info in the instructions) and the trunion, fence, and miter gauge all checked out true with no alignment or adjustment required. I installed my saw on one of Jet’s adjustable rolling bases and have found it to be quite stable.
Unlike other contractor saws, the 1.5HP motor is inside the saw’s cabinet, which makes it an excellent candidate for a small shop (the absence of a rear-mounted motor/pulley allows it store flush against the wall of my shop).
The only negative I have found is the table insert. It does not conform to any standard I can find. The (optional) dado insert has a slot wide enough to drive a truck through, so the only way I found to deal with small pieces is to adapt a shop-made sled to act as a zero-clearance insert.
A Jet dealer gave me a part number (709382) for a zero clearance insert, but couldn’t locate one anywhere, and it doesn’t show up in their online parts. I suspect he had it confused for the ZCI Jet makes for their Xactasaw.
For those who need a zero-clearance insert for the Jet 708100, making one is a viable alternative but takes a little patience.
1) I bought a 1/4” phenolic sheet (from McFeely’s), and used a pattern-cutting router bit to make a blank that fit the saw’s throat.
2) The resulting blank was a little proud of the saw table, so next, I cut a 1/16” x 1/2” rabbit around the underside of the blank.
3) I drilled 4 holes for leveling screws, and threaded them to #10-24, and used #10-24 3/16” set screws.
4) I used a 2” long piece of spring steel to fashion a front hold-down screw and attached it to the blank with a #10 1/2” flathead machine screw, countersunk.
5) I drilled a 1/2” finger hole toward the rear of the blank, and a 5mm countersunk hole to accommodate the flat head screw that secures the insert at the front.
6) I installed one of the cutters from a 6” dado blade set, installed the blank insert, clamped a scrap piece of 2×4 over the throat plate, powered up the saw, and raised the blade through the insert.
7) Lastly, I replaced the dado blade with the 10” blade I run in my saw, clamped a 2×4 scrap over the throat plate, and raised the blade to complete the cut through the insert.
The first one took a couple of hours to make, with most of the time spent trying to find a suitable piece of spring steel for the front hold-down clip. Now that I have the necessary parts (set screws, spring steel, etc.) it takes about a half hour to knock one out, and I have made ZCI’s for each of my most common dado setups as well as my thin kerf finish blade.
-- The Dane, Wisconsin
5 comments so far
8497 posts in 265 days
posted 102 days ago
Thanks for the review. I have been looking to upgrade my Craftsman- when my wife gives me my allowance of course. I may have to look at the Jet series.
TheDane
posted 102 days ago
I think it is worth looking at. I don’t know what they go for now (I bought my saw in November ‘06 when they first came out). I paid $399 plus sales tax … the local shop I bought from didn’t charge any shipping or handling.
View runngt's profile
runngt
107 posts in 182 days
posted 102 days ago
Nice review! I find just about all Jet products are A+
runngt
-- It seem's I just make scrap wood and saw dust most of the time !
teenagewoodworker
1932 posts in 211 days
posted 102 days ago
thanks for the review. i like Jet products too and i might be getting a contractors saw too (used). thanks again for the review.
Beginningwoodworker
351 posts in 116 days
posted 102 days ago
Congats I think its a nice saw, I hope to upgrade my Delta Benchtop table saw.
-- CJIII Future cabinetmaker
Bookmark And Share This Page
