| Review by paratrooper34 | posted 94 days ago | 1932 views | 3 times favorited | 25 comments | ![]() |
- Lie-Nielsen #51 Shoot Board Plane
- Brand: Lie-Nielsen | Category: Hand Planes
This is a second review on LJs for this plane. I am going to go through receiving the plane, unpacking it, setting it up, and putting it to use.
As a hand tool worker, I have become very dependent on my shooting board for many uses. It excels at cleaning up pieces that have been crosscut to get them square and smooth. I also use it for precise length sizing for multiple pieces. So it is in use on every project. That alone convinced me to purchase this plane.
I ordered the plane by phone on a Monday and received on Friday of the same week. When I called LN, they told me they didn’t have it in stock, but would get one to me soon. Delivery on the fifth day is pretty darn good service.
It arrived packed in this box:
Inside the box were the plane (it was held in the box with a piece of wood screwed to the inside of the box so it wouldn’t move), a dessicant, and a package that had some LN instructions and data and a three page pamphlet explaning shooting boards and some appliances you can add (for making mitered cuts).
The plane had a light coat of oil on it which was easily removed by wiping it down. It has a cast iron sole with a brass frog. The cap iron is LN’s improved type, which is nice. The blade is an A2 blade and it was ground to a 25 degree bevel. It was partially lapped on the back and needed to be sharpened (which is fine, I have no issue with that). I finished lapping the back which was made easy by the fact that the back is flat. I started by using my extra coarse diamond lapping plate and then finished it on my water stones. Being flat already was a big help as A2 is not my favorite blade to flatten a back on. Here are a couple of pics from before and after.
That is all that was required to put the plane into action. The frog was already set, everything else flat as it should be. So I put the blade in, adjusted it to the depth I wanted and gave it a quick test run. It works great.
Now, my shooting board needed a modification to use this plane. As the other review mentioned, this plane really shines for shooting because it can ride inside of track. Because I was using a Record T-5 on my shooting board previously, I needed to install an outside rail to keep the plane captured on the shooting board. Here is what it looked like before:
You can see that the plane is free, but a rail will hold it in place and make the process easier. Here it is with the rail installed.
I put a fresh coat of paste wax to all of the surfaces in the track and also to the plane. It slides effortlessly and is very easy to push when cutting.
In summary, this is a very fine tool. It is every bit the quality item you would expect from LN. It is very close to a useable level right out of the box. This plane is a major upgrade from a standard plane such as a #5 or #6. This is due to the mass of the plane (just over nine lbs), the skewed blade, and the placement of the handle. After I got it up and running and set up the shooting board, I was taking a full length end grain shaving off a piece of maple with ease. I am surprised at how much easier it is to cut than the previous plane I was using. The downside is the cost; it is steep at $500. However, I consider this an investment and it will indeed be passed down to my son or grandchildren. I highly recommend this plane if a shooting board is something you use often.
Here are some shavings pics: The wood is an 8 1/2” wide piece of butternut.
Those are full width end grain shavings.
Oh, and my shop cats showed up to hang out.
-- Mike
25 comments so far
felkadelic
home | projects | blog
158 posts in 736 days
#1 posted 94 days ago
Just curious if you’re right- or left-handed, and if you’re a lefty do you find the plane awkward to use with your right hand?
paratrooper34
699 posts in 1148 days
#2 posted 94 days ago
felkadelic, I am right handed. It doesn’t appear that they make a left hand version.
-- Mike
Dennisgrosen
10851 posts in 1311 days
#3 posted 94 days ago
congrat´s with your new toy :-)
have lie-nielsen started to make the shootingtable for it yet
just asking of curriusity …. no way is this plane in my budget range :-(
though I like how they pack it for shipment :-)
enjoy … enjoy
Dennis
CessnaPilotBarry
635 posts in 306 days
#4 posted 94 days ago
Thanks for the review! I’ve tried one, and it’s a sweet tool.
What is the purpose of the T-track on the shooting board?
-- It's all good, if it's wood...
Jamie Speirs
3719 posts in 1053 days
#5 posted 94 days ago
Mike a great review, I’ve never used a dedicated shooting plane unless you count a
Record T5.
Looks and sounds like a great plane. felkadelic If you phone LN they will swap your hands over. :)
Jamie
-- Who is the happiest of men? He who values the merits of others, and in their pleasure takes joy, even as though 'twere his own. --Johann Wolfgang von Goethe
Manitario
1857 posts in 1079 days
#6 posted 94 days ago
Thanks for the review. That looks like an awesome plane, and if I ever had a spare $500 and the talent to put it to use, I’d buy one.
The only thing this review lacks is the obligatory pic of a shaving coming off the plane.
-- Rob, Sault Ste. Marie, Ontario
paratrooper34
#7 posted 94 days ago
Thanks guys!
Dennis, Dankeschoen! No shoot board from LN as of yet. Their website says it is in the future.
Barry, the t-track is for some Rockler hold downs that I have to hold down stock and to put blocks in place for making multiple pieces of the same length. Comes in handy.
Jamie, I do count the T-5, been using for one for a few years now. It is great for shooting, but the 51 is a nice upgrade.
-- Mike
mariva57
179 posts in 201 days
#8 posted 93 days ago
Hello Mike,
excellent purchase, an instrument of excellent workmanship.
Have a nice day.
mariva57
-- The common man thinks. The wise man is silent. The stupid man discusses.
bobasaurus
697 posts in 1380 days
#9 posted 93 days ago
Excellent review. You’re making me want one of these now, and I’ve just started using shooting boards. Is it tricky getting blade depth uniform because of the skew? I have a lie nielsen skew block plane that has that problem.
Jorge G.
1324 posts in 671 days
#10 posted 93 days ago
This guy makes them for the 51, he is really nice and makes great shooting boards. I wanted to buy one but the shipping to Mexico broke the deal.
-- Just because you’ve always done it that way doesn’t mean it’s not incredibly stupid.
paratrooper34
#11 posted 93 days ago
Bob, this is my first LN plane that has a frog on it. All my other are Records and old Stanleys. I have to say, this LN plane adjusts smooth as silk. I am very impressed at how easy everything moves. No slop in the lateral adjuster, the adjustment knob turns easily. It was very nice to use a plane of this quality. Because the blade sits on a traditional frog, it is no issue to set the depth.
I say go for it if you want to buy one. This is a great tool. Truth be told, I might have to sell off my Records and Stanleys and upgrade to LNs, I am that impressed with it.
-- Mike
paratrooper34
#12 posted 93 days ago
Manitario, I will get one for you, don’t know how I missed that.
Mariva, grazie mille!
-- Mike
Deycart
215 posts in 454 days
#13 posted 93 days ago
I was wondering if you could tell me how thick the bed of the casting is and how thick the support ribs are.
paratrooper34
#14 posted 93 days ago
Deycart, here you go; the sole (the bottom) is sloped. At the thinnest, it is 5/32”, thickest is 3/8”. The rest of the body is 3/8” to include the ribs. It is definitely a robust plane.
-- Mike
SFLTim
52 posts in 177 days
#15 posted 93 days ago
So very very jealous….... man that’s nice!
View all comments »
showing 1 through 15 of 25 comments
