Just the right size for many projects
Review by bkhop posted 54 days ago 271 views 0 times favorited 6 comments Add to Favorites
View bkhop's profile
bkhop
55 posts in 454 days
Just the right size for many projects No-picture-s No-picture-s Click the pictures to enlarge them
SST just left his review of the Shopsmith 11” bandsaw. What you’ll see between my bandsaw and his bandsaw is that both of them are the same “base” units. The saws are exactly the same, even though mine was manufactured about 45 years later, just as he mentioned in his review. The differences are what I’ll point out in my review.
The table, as you can see, is the first main difference.
SST’s bandsaw has a nice, heavy cast iron table. Mine has an aluminum table, which I believe is a bit larger. There’s advantages to either table style. The cast iron table is obviously much heavier and has a lot of heft to it. The aluminum table is lighter but takes more accessory options. Both tables have miter gauge slots – just “borrow” the miter gauge from the Shopsmith “system” and you’re in business; everything shares across tools. The aluminum table has the ability to accept an accessory table extension (which is shown in the picture) and also a circle cutting jig (which has the ability to cut a 36” circle.) If you have an older bandsaw – or any vintage Shopsmith bandsaw, to be exact – you can upgrade it to the current aluminum table – just give Shopsmith a call.
Another difference between the older saws and the newer ones is the dust collection port. Early models didn’t have any kind of port, but one is now built in… and in a very good location: right under the table as the blade comes down (some manufacturers have placed their dust collection ports in the absolute wrong positions to actually suck up any dust.) But, fear not, if you currently have any older Shopsmith bandsaw (or come by one used), Shopsmith has a retro-fit kit that you can install yourself to bring an older saw up to speed with dust collection. (See a recurring theme here… Shopsmith doesn’t sell you a tool and then leave you hanging.)
I have also installed the made-for-Shopsmith Kreg rail and fence kit on my bandsaw – this upgrade, however, is only available for the newer aluminum table models – though I suspect a fellow really could adapt the cast iron table pretty easily to make it work also.
With the Kreg’s longer rails, the cross-cut capacity is increased to 9 3/8”.
Resaw capacity is 6”. The Kreg fence is great for resawing, as it allows you to micro-adjust a measurement on a thumbwheel. I’ve made veneers for smaller projects or just sliced up figured wood to get more out of it.Photobucket
One thing that I just about forgot to mention is that when mounted on the Mark V, the bandsaw is powered by a 1 1/8HP motor. -And with variable speed, no less! The bandsaw, as with any of Shopsmith’s “Special Purpose Tools,” can also be set up on its own dedicated stand if you so choose.
The Shopsmith bandsaw, obviously, is not a huge Powermatic or Laguna. For most hobby woodworking, the Shopsmith is more than sufficient and fits into the whole Shopsmith “family” of tools very nicely.
-- † Hops †
6 comments so far
7752 posts in 209 days
posted 54 days ago
Hi Hops,
Thanks for the review. I found it interesting, especially with the comparison between the two models.
View SST's profile
SST
224 posts in 582 days
posted 53 days ago
Great additional information. I think it’s safe to say that none of the Shopsmith stuff is cheap. But as any tool owner knows, cheap won’t get the job done.
After seeing your table setup, it’s got me thinking about an upgrade, it looks like a great addition. I’m glad you mentioned the variable speed. Even though I added the optional speedchanger to my old 10er, I forgot to bring it up. It really is nice to adjust speeds incrementally, and there’s actually enough power even with my 1/2 hp motor, I can’t even imagine the punch the Mark 5 motor has.
While I don’t intend this to be some sort of “mutual admiration society” for SS owners, I do believe that separate tool woodworkers shouldn’t ignore some of the SS peripheral tools. The planer is also a terrific unit and puts most benchtop planers to shame…but, again, it’s not a cheapie. -SST
-- You get no points when you punt
bkhop
posted 53 days ago
http://lumberjocks.com/reviews/156
-- † Hops †
3775 posts in 238 days
posted 53 days ago
Nice piece of equipment Hop.
View Kipster's profile
Kipster
506 posts in 140 days
posted 53 days ago
Informative review Hop
-- Kip Northern Illinois ( If you don't know where your goin any road will take you there) George Harrison
View Napaman's profile
Napaman
1341 posts in 464 days
posted 53 days ago
i have been looking at the Kreg fence…and I do like the table extension you are showing…mine does not have the measuring and extensions…
I just chatted with an LJ who has 3 bandsaws…but uses and like his SS bandsaw the most…
thanks for the review…
-- Matt, Napa, CA...SING WITH ME: "Sum...sum...sum...summ...summ...summ...summertime..."
Bookmark And Share This Page
