| Review by SST | posted 119 days ago | 590 views | 0 times favorited | 5 comments | ![]() |
- Shopsmith 11-Inch Bandsaw
- Brand: Shopsmith | Category: Bandsaws
I decided I’d review my 1956 Shopsmith band saw. Why would anyone care about a 50 plus year old band saw???
(except for a couple of old Shopsmith nuts?)
Because it’s a great saw and you can still buy one new today from Shopsmith, or used on ebay, and you’d be getting essentially the same machine as my 50 year old saw.(and I consider that a good thing)
Now, why would anyone build the same tool for a half century while everyone around you changes stuff almost as often as car companies change models or Hollywood celebs change spouses?
You could argue that they just didn’t want to spend the money in tooling and R & D, but I would argue here that the old saying “if it ain’t broke, don’t fix it” applies, and here’s why I feel that way. (it also might be said that I’m a bit prejudiced in my love for old Shopsmith stuff, and I won’t deny that, but I’ll try to be as objective as I can here for this review)
This particular saw was made circa 1956,and I bought it 2 years ago along with my second model 10er that came in a couple of bushel baskets. While the Smith needed restoration, this accessory did not, it was mint.
The reason I consider this review of an old tool valid is that this saw is essentially the same as those manufactured today. The design has stood the test of time. I love it because it needs virtually no adjustments. My previous saw (craftsman) needed tracking adjustments periodically….often…actually, always.
This saw has no tracking adjustments. The blade, once installed, just self adjusts, stays put, and that’s it. The only thing to adjust is the blade tension with an allen wrench (#1 on pic). You adjust so the red line matches the blade width (#2 on pic). then adjust one screw for blade depth between the guide blocks, and you’re ready to go.
I’ve never had to re-adjust after it’s set up.
The saw is small at 11” throat and 6” max thickness of cut, but if you don’t need bigger, it’s a great choice.
It mounts to the end of a Shopsmith Mark 5 (adaptor is needed for use with a 10er, & they’re rare, but repros are available) or you can mount it on a tool stand and use a separate motor.
I’ve shown an example of some re-sawing of a 2×4 and you’ll note that I’ve cut down to 1/16” using my sophisticated rip fence system. Real rip fences and larger tables are available on later models and can be added to the older ones, too. I’ve re-sawed some ash from tree branches that, when squared off, were just under 6” across, and the power was adequate, and the saw ran true, so if you have a Shopsmith, or just need a small, well built, simple to operate band saw, this one would serve you well.
That’s my story, and I’m stickin’ to it. -Shopsmithtom…-SST
-- Accuracy is not in your power tool, it's in you
5 comments so far
Napaman
home | projects | blog
1634 posts in 528 days
posted 119 days ago
so what I hear you saying is…my 2003 stuff is gonna last a while and I found a great deal??? when I bought my SS last year (hard to believe it has almost been a year since I got it) it came with a jointer and the band saw as extra…I used the jointer a lot because I did not already have one…but barely used the the band saw…since I had a Ryobi…on a seperate stand.
Then I finally gave my ryobi away to make more room in my shop and started using my SS Band saw—-and boy what a differnce…I could never get my ryobi to track right…and when i was setting on a new blade for my SS i was worried that I would run into the same trouble…but in minutes I was set with no problems…
I want to make a re-saw jig so I can start cutting some small logs i have…and will do so soon…
Great review…I AM LEARNING ABOUT MY OWN GEAR between you and Hops….lately!!!
-- Matt, Napa, CA...177 days to sanity...
Kipster
833 posts in 204 days
posted 118 days ago
My 1980 vintage bandsaw works as good as it was when new. Nice review.
Thank you for the post.
-- Kip Northern Illinois ( If you don't know where your goin any road will take you there) George Harrison
4905 posts in 302 days
posted 118 days ago
I doubt if many of the modern machines will stand the test of time like that one SST.
Don Niermann
130 posts in 423 days
posted 118 days ago
Bought mine in 86 its a part of my shop even if I have ALL OF THE STAND ALONE TOOLS. Very accurate.
-- WOOD/DON (...one has the right to ones opinion but not the right to ones own facts...)
bilsborough
43 posts in 146 days
posted 112 days ago
This Is the same bandsaw my dad has had and I still use since I can remember and I’m now thirty. It is actually wearing out and I’ve been wanting to get a new on for a couple of years. I had assumed since I’ve never seen the brand around that I couldn’t get parts for it but if I can maybe I will just refurbish it. Do you know where I could get parts.
-- What do you learn from being right?
