Outstanding countersink/bit combination
Review by Rick M. posted 90 days ago 1295 views 1 time favorited 9 comments Add to Favorites Watch
Outstanding countersink/bit combination Outstanding countersink/bit combination No-picture-s Click the pictures to enlarge them
Over the years I’ve tried a number of countersink + drill bit brands, most use a replaceable bit but they are all pretty mediocre and few lasted a year. I’ve owned this Dewalt set for several years and they still perform like the first day I brought them home. Some folks believe combination bits are gimmicky, preferring to use separate products but these might change their mind. Not only do the countersinks perform flawlessly, the tapered bits are exceptional and probably the best wood bits I’ve owned. Frequently I use them for straight screws and they work equally well. A 3/8” dowel fits the countersink hole perfectly.
Set includes a #6 (9/64”), #8 (11/64”), & #10 (3/16”) Rapid Load bits.
Current price around $25.00
Time of ownership: several years at least
I’ve all but given up on quick change bit/driver holders but the solid performance of these bits has made me want to buy the Dewalt Rapid Load holder.
-- -- Rick M.
View Rick M.'s profile
Rick M.
1465 posts in 547 days
9 comments so far
View lab7654's profile
lab7654
184 posts in 414 days
#1 posted 90 days ago
I’ve been thinking about picking up some tapered countersink bits, so thanks for letting me know about these! I like having options without having to buy online or track down a specialty store, so the DeWalt brand is welcome here.
-- Tristin King -- When in doubt, sand it.
View MT_Stringer's profile
MT_Stringer
710 posts in 1398 days
#2 posted 90 days ago
I bought that set recently and I have had good luck with them.
View oldnovice's profile
oldnovice
1738 posts in 1535 days
#3 posted 90 days ago
I am going to have to try those! The Roybi bits I have are next to worthless!
Rick M.
#4 posted 90 days ago
Yep, the Ryobi’s are terrible but so is pretty much every other major brand. Most all of them are identical just different branding. I was actually looking for a stand alone countersink when I found these Dewalts, glad I bought them.
-- -- Rick M.
View AttainableApex's profile
AttainableApex
336 posts in 1000 days
#5 posted 90 days ago
i have bought this set i think 3 times over the years. they have been great and perform flawlessly.
the reason i bought so many is that i broke 1 bit ( defiantly my fault) and said these are so great i’ll buy them again and have spares.
since i have so many i have them color coded and set the countersink at different depths so i don’t have to change them.
highly recommend these.
-- Ben L
View joein10asee's profile
joein10asee
1670 posts in 174 days
#6 posted 90 days ago
I have only the #10 of these and I use it quite a bit. There was a slight learning cure because I figured out if you “lean” on the drill when you’re using it, that countersing will drive fast in soft wood (pine), which leaves plenty of depth for a plug :-)
In the hardwoods I’ve tried it in (oak, maple, poplar) it works great. I’ll definitely add other sizes as I need ‘em.
Rick M.
#7 posted 90 days ago
I use the #6 most often, the #8 occasionally, and the #10 only with larger (actual tapered) wood screws.
-- -- Rick M.
View BentheViking's profile
BentheViking
1134 posts in 731 days
#8 posted 88 days ago
I bought this kit from amazon 4+ years ago and love it. just used it again today. After a few years i had broken a number of the bits and countersinks so I just replaced it with a set I bought at sears for less than $10
-- It's made of wood. Real sturdy.--Chubbs Peterson
View darkone's profile
darkone
32 posts in 123 days
#9 posted 83 days ago
I have the same kit as Ben and I think these things are awesome. The only problem I’ve had is that one of the tiny allen heads that hold the drill bit in place rounded off on me. Other than that, these have been great!
