| Review by vipond33 | posted 90 days ago | 1519 views | 7 times favorited | 10 comments | ![]() |
- Lee Valley Drill Bushings and Inserts
- Brand: Lee Valley | Category: Drill-Driver Accessories
I’m quite enamored of dowels as joinery, especially in cabinet construction. Fast, accurate and plenty strong enough if used with good technique, tooling and materials, they also allow me flexibility in appearance of the finished case without too much fuss.
However, I do not own a doweling jig. Don’t get me wrong, I’d love to have a Dowel Max, but with all its accessories to be more costly than the price of a used motorcycle, well, no thanks. Besides, all doweling jigs are somewhat limited in their scope. Using bushings I can do anything they can, albeit somewhat slower because of the setup time. As hobbyists though, we have a fair bit of free time.
Having said that, once you’re set it is faster than any commercial jig, especially when doing multiples.
In use:
Cabinet end frame
Cabinet bottom
Short apron for cabinet stand
At work, setting up to drill for a mitred & doweled joint in a 20” wide solid wood credenza.
A tip if using them for bi-directional drilling. Tighten the insert into the bushing with two pairs of pliers, for any binding of the drill working from the opposite side, or even reversing to clear the muff will cause the insert to unwind.
I use 3/4” MDF for my jig pieces as it allows accuracy without splitting when the bushings are driven in (I usually use a clamp or a vise to be sure of a perpendicular alignment). When a row of bushings is needed close to an edge they are inserted in a much wider piece (to avoid bulging and breakage) and then the strip is trimmed on the saw
When extreme angular accuracy is required you may double up the bushings inline on a thicker piece of wood. Holding a drill exactly square in both directions takes some practice.
Lee Valley markets these bushings primarily for hardware installations and they are great for those things as well. They are probably available from many other sources though I haven’t checked.
A full range of sizes.
Up close and personal with my 3/8” favourite.
Reasonably priced and well made in usa, by non outsourced usan’s.
So six stars for the high quality and low price sweet spot.
gene
-- gene@toronto.ontario.canada : dovetail free since '53, critiques always welcome.
10 comments so far
madts
home | projects | blog
656 posts in 507 days
#1 posted 90 days ago
I agree. Dowels are misunderstood apart from the cabinet industry, where point to point CNC machines are used. But jigs like yours do the same job, at a slower pace.
-- Thor and Odin are the greatest of Gods.
gbear
327 posts in 2266 days
#2 posted 90 days ago
This is a great idea…one I will probably adopt.
Thanks
-- gbear, Carmichael, CA
JL7
3604 posts in 1132 days
#3 posted 90 days ago
Great review Gene…...didn’t even know these were available….Lee Valley has so many little gems hiding about….
I’ll be putting some of these in cart with my next trip….......thanks.
-- Jeff - I have not failed. I've just found 10,000 ways that won't work.
PASs
324 posts in 1265 days
#4 posted 90 days ago
thanks for the post.
I still have the dowel centers I got 25 years ago….drill the hole, put the center in, press the mating board together, drill the matching hole.
Made a massive entertainment center using dowels as the joinery with those centers.
But these look better for drilling the holes.
on the favorites list !!!
-- Pete, "It isn't broken, you just aren't using it right."
Steve - stevensmasterwoodworks.com
189 posts in 160 days
#5 posted 90 days ago
great!
-- http://www.stevensmasterwoodworks.com
jap
1029 posts in 221 days
#6 posted 90 days ago
thanks for the review.
-- Joel -- http://diversitywoodworks.wordpress.com
DocSavage45
2866 posts in 1009 days
#7 posted 90 days ago
Gene,
Your photos are great. What kind of camera? Nice review too!
-- Cau Haus Designs, Thomas J. Tieffenbacher
SPalm
4108 posts in 2049 days
#8 posted 89 days ago
Great idea. I have used many dowels with varying results.
It looks like these little puppies would solve some of the problems. Hmmm.
Thanks for the tip,
Steve
-- -- I'm no rocket surgeon
Paul Stoops
273 posts in 728 days
#9 posted 89 days ago
Good review! I have several sets of these bushings and liners. The liners press fit nicely into 5/8” holes just squeezing them in with a bench vise. The smooth surface at the end of the liner does a good job of piloting the liner into the hole and keeping it aligned when inserting.
These drill bushings are much lower cost than standard slip fit or press fit drill bushings. I wish they offered a wider range of sizes, tho. I have used these parts to make several drill jigs for various projects. A great value.
I have also used the Veritas Optical Center Punch (http://www.leevalley.com/us/wood/page.aspx?p=45502&cat=1,180,42311) in conjunction with a 5/16” bushing to accurately align a drill jig with a hole layout pattern. A great combination for precision work!
-- Paul, Auburn, WA
Thomas Hanson
29 posts in 119 days
#10 posted 83 days ago
It took me 5 minutes to realize you weren’t trying to make dowels but merely drill for them. This is definitely the way to do it.
-- Okie from Council Hill
