Grizzly Wood Threading and Die Set
Review by AKSteve posted 103 days ago 1652 views 3 times favorited 12 comments Add to Favorites Watch
Grizzly Wood Threading and Die Set No-picture-s No-picture-s Click the pictures to enlarge them
I bought this mostly on Price, I check around at other online stores and this appeared to be the cheapest, with that said I couldn’t just walk in the Door and purchase given my location. it was 11.95 for the Tap and 22.95 for the Die. Grizzly of course delivered right away and I got my purchase within the specified time suggested for my Delivery to Alaska.
Quality: Tap: the overall quality for the Tap was superb, it had no chips or loose metal ends to clean and was oiled to prevent from rusting, 3 pieces included in the package which were the Tap, a cross bar and a screw to hold down the cross bar for turning. the Die: the overall quality was also superb, made from maple and lathe turned handles, a brass nut to hold in the cutting tool and a metal insert for moving the thread through after being cut. this product had a “Made in Taiwan” sticker. yeah it would have been nice to have been made here but this will do for now. the Tap came with instructions in the wrapper and the die had the instructions on the Box. Pretty simple to follow and not much to have to do. Basically for the die you need to a 7/8’s hole to start the process. I used Paduak wood a real hard wood, and threaded the Tap thru with ease, it was very sharp and cut through the wood like butter! I backed it out occasionally to clean the threads. the Die as just as easy and just as slick. I used Home Depot’s 1 inch hardwood dowel. Once I complete the process I put some minwax on the threads to allow the dowel to be screwed into the Paduak, I worked it in and out a couple of times to allow it to loosen up some. the Threads hold really well and tightened the two pieces together really good. I can’t say anything bad about the product. I can’t wait to build something else with it now!
-- Steve - Wasilla, Alaska
View AKSteve's profile
AKSteve
412 posts in 469 days
12 comments so far
View Dusty56's profile
Dusty56
10496 posts in 1854 days
#1 posted 103 days ago
Nice review. Do they have other sizes available ?
-- When did quiet and quite become the same word ? I'm guessing about the same time as your and you're did.
View Charles Maxwell's profile
Charles Maxwell
825 posts in 1973 days
#2 posted 103 days ago
I use these exclusively for the connectors on my clock frames. Very useful indeed. www.hardwoodclocks.com
-- Max the "night janitor" at www.hardwoodclocks.com
AKSteve
#3 posted 103 days ago
yep you can get them at Grizzly 3/4 and 1/2 inch sizes.
Dusty56
#4 posted 103 days ago
Thank you : )
View JesseTutt's profile
JesseTutt
707 posts in 276 days
#5 posted 103 days ago
Thanks for the review. I have a 1” from Woodcraft but will consider Grizzly for the other sizes
View gfadvm's profile
gfadvm
6611 posts in 856 days
#6 posted 103 days ago
Thanks for posting this. I have been wanting to do wooden threads but was discouraged by all the problems others had posted using router jigs, etc. I’ll be having this set ASAP! Do you think they will tap and thread Jatoba?
AKSteve
#7 posted 103 days ago
I don’t know about Jatoba, but it went thru the Padauk like butter!
gfadvm
#8 posted 103 days ago
Thanks Steve. I’m ordering mine tomorrow! Jatoba should make really good stock as it acts like steel!
View racerglen's profile
racerglen
1690 posts in 946 days
#9 posted 102 days ago
Got the same sort of set some years back from Busy Bee tools, works realy well, just have to watch the dowels for roundness or you get some spots where the thread isn’t full size.
mine’s the 3/4 size and I bought both the through and bottoming taps.
The only modification I made was replacing the tap handles with the type that are used for metal taps, the originals were too light, bent like spaghetti
-- Glen, Vernon B.C. Canada
TopamaxSurvivor
13192 posts in 1842 days
#10 posted 102 days ago
Good review, thanks
View Shanem's profile
Shanem
98 posts in 632 days
#11 posted 81 days ago
Do you know what the tpi is for this die? I couldn’t find any info online.
View JamesVavra's profile
JamesVavra
255 posts in 1482 days
#12 posted 79 days ago
@Shane – I have the same one. It’s a pretty coarse thread, maybe 8 tpi. I’ll measure the tap when I get home and report back.
