| Review by douglbe | posted 110 days ago | 1854 views | 5 times favorited | 35 comments | ![]() |
- The Works Toilet Bowl Cleaner
- Brand: The Works | Category: Other
I have been looking for something to easily remove rust from some hand planes I am restoring. I was contemplating using electrolysis and I came across an article the other day on using The Works Toilet Bowl cleaner, so today I gave it a try. I used it at full strength and put the parts in for 20 minutes and this virtually removed all rust, it doesn’t get any easier than this. Now I need to find a pan largest enough to hold the body of this #5 Stanley. Use in a well ventilated area and wear rubber gloves. Easily 5 stars!
-- Doug, Reed City, Michigan
35 comments so far
GlennsGrandson
home | projects | blog
414 posts in 481 days
#1 posted 110 days ago
I have a Millers Falls No.22 that I recently acquired, I will be trying this and reporting back as well.
20 minutes and what did you use to scrub/wipe it off?
-- Grant - S/N Dakota
waho6o9
2928 posts in 749 days
#2 posted 110 days ago
Good to know, thanks Doug.
douglbe
337 posts in 2133 days
#3 posted 110 days ago
GlennsGrandson, there were two very small areas I lightly scrubbed with steel wool and rinsed with water, it was that easy. Good luck with your Millers Falls.
Mark Davisson
276 posts in 1489 days
#4 posted 110 days ago
Great discovery, Doug! It’s always gratifying to find common solutions like this.
I’ve also found that you can soak rusted metal in 10:1 water-molasses or straight apple cider vinegar. Takes a lot longer than 20 minutes (like a week longer), but it works!
-- From the fruit of their lips people are filled with good things, and the work of their hands brings them reward. - Prov 12:14
Dan Krager
723 posts in 406 days
#5 posted 110 days ago
“Snobol” is a stronger cousin to “The Works”, but around here you are a terrorist if you buy it…you have to sign for it and give all sorts of personal information to get it. Never thought about using them on tools! I’m gonna try this too.
DanK
-- Dan Krager, Olney IL http://www.kragerwoodworking.weebly.com
Brandon
3773 posts in 1123 days
#6 posted 110 days ago
I’ll have to try this. I wonder how it compares to EvapoRust which has been my go-to rust remover. One thing is that it’s probably a heck of a lot cheaper than EvopoRust.
-- "hold fast to that which is good"
Radu
240 posts in 1215 days
#7 posted 110 days ago
Thanks for the tip. I’ll try it next time I need to de-rust anything. I’ve been using phosphoric acid (the one for pool cleaning)
87330 posts in 1749 days
#8 posted 110 days ago
Not sure what the active ingredients are in “the Works” so I might be a little Leary, I have used Evapo-Rust and many others have had good results with it too. Evapo-Rust is not caustic and is reusable.
JohnnyB
61 posts in 561 days
#9 posted 110 days ago
The active ingredient in this appears to hydrochloric acid, aka muriatic acid, according to the MSDS. One of the industrial uses of hydrochloric acid is “pickling” steel to remove oxides. That explains why it works so well. HCl is dangerous in liquid and in aerosolized forms, so you don’t want to breathe it or get it on you. Thanks for the review. I am going to give it a try.
-- JohnnyB - - Sometimes determination can substitute for skill.
Tedstor
929 posts in 805 days
#10 posted 110 days ago
But Jim, The Works is a dual use product. You can’t get a gleaming toilet bowl with evapo-rust.
Tedstor
#11 posted 110 days ago
Thanks Johnny. We’ll try to resist the temptation of brushing our teeth with it. ;)
#12 posted 110 days ago
funny stuff Tedstor
I think I’ll stick with Evapo rust it’s much safer
.http://www.evaporust.com/
http://lumberjocks.com/reviews/2808
ChuckV
1757 posts in 1699 days
#13 posted 110 days ago
I have a suggestion:
Thanks for the tip!
-- I was walking down the street, something caught my eye, and dragged it 15 feet.
Dan Krager
#14 posted 110 days ago
I ordered a pot tray from a garden supply store for putting the saw plates in. Just right sizes available.
DanK
NormG
2580 posts in 1176 days
#15 posted 110 days ago
I read about this products use for cleaning rust someplace and they did recommend safety precautions
-- Norman
View all comments »
showing 1 through 15 of 35 comments
