I have to agree
Review by motownjg posted 01-31-2013 07:35 AM 4500 views 0 times favorited 8 comments Add to Favorites Watch
I have to agree No-picture-s No-picture-s Click the pictures to enlarge them
I just received my Grizzly $140 router table and its all I could ask for after having tried to make my own router table and ending up with a bowed/warped tabletop with no fence.
The black powder coated lets and braces were stuck to the paper inserts meant to keep the pieces apart, but I think that is a minor complaint given the value of the overall package.
Once put together, I now have a fully functional router table with fence and insert plate. Assembly was very easy. Although it looks like UPS dropped the package on one end, the table suffered no more than cosmetic damage as far as I can tell. I certainly wouldn’t return it and look forward to using it with my old, 1980’s Craftsman router. Best value out there best as I can tell.
-- John
View motownjg's profile
motownjg
24 posts in 2344 days
8 comments so far
View PurpLev's profile
PurpLev
8548 posts in 3890 days
#1 posted 01-31-2013 02:11 PM
nice.
how long have you been using this router table?
seeing that it got a 5 stars rating, how does it hold up to use over time? does it start to sag or stay flat?
how about the insert? is that plastic or aluminum? does it seem to hold the weight of the router properly over time?
congratulations on your new router table :)
View brtech's profile
brtech
1054 posts in 3164 days
#2 posted 01-31-2013 05:28 PM
I’ve had this for over a year. It’s great. No problems other than those I listed in my original review (mostly I had problems mounting a Hitachi M12VC router).
The insert is plastic. It holds the weight of my router just fine.
View helluvawreck's profile
helluvawreck
32086 posts in 3108 days
#3 posted 01-31-2013 05:35 PM
Thanks for the review. I’ve seen some pretty good bargains in Grizzly’s catalog. At least I think they have some good bargains.
helluvawreck aka Charles
motownjg
#4 posted 01-31-2013 07:24 PM
HAH! I gave it a five star rating???? Didn’t even know I did that. I can’t say anything about how it holds up after time since I just got it.
It is highly functional and great value for the price. Metal frame is solid and went together easily – maybe 1/2 hour all told to get the top attached to the frame (had to read the directions, but that’s because I’m me); all parts accounted for/nothing missing. Good thick right-angle aluminum backs up the two adjustable fence pieces. It comes with two pieces of plastic to shim the outfeed side for jointing wood. Vacuum hose attachment; little magnets hold the plate down & sit right under the adjustment set screws. Plate is plastic but fairly thick and hard. I’m sure I could route into the tabletop to install a KREG if I had to but that would defeat the “cost vs value” idea, I think.
Anybody know if the plate takes standard brass inserts for different bit sizes?
-- John
View TJ11's profile
TJ11
63 posts in 2870 days
#5 posted 11-23-2013 12:05 PM
I am looking at the same table—Grizzly has it on sale for about $130. Do you still give it 5 stars, has it held up, any fence or top issues?
-- If I had more money, I'd have more tools
motownjg
#6 posted 11-25-2013 02:18 PM
No real issues. Haven’t had the plastic insert warp, nothing has gone off kilter (at least, nothing that was the table’s fault), and it’s performed just as I wanted it to. Of course, now that I’ve used it I see the advantages of the more expensive tables – those with a router lift, etc. But then they were more expensive too.
It fits me just fine.
-- John
View TJ11's profile
TJ11
#7 posted 11-28-2013 01:07 PM
Thanks John. I am ordering one. I have bigger wants/needs than a router lift at this time and it sure will beat my old Skil $20 aluminum table (it has seen hard use and better days).
View MeloYellow's profile
MeloYellow
11 posts in 3178 days
#8 posted 04-30-2015 02:45 PM
It looks exactly like my BusyBeeTools router table (I imagine it is manufactured by the same company and sold under different badges). I have had it for the past year, solid table, solid fence. The only issue is with the phenolic insert plate supporting my Freud FT2200VCE 3-1/4 HP router , there is sag with time. From what I read on the net, I can either use hardwood or aluminum angle as support beams under the insert plate to straighten it out. I will go with the angle iron and see how it helps. Besides this issue, the only other problem where the corner leveling screws that kept vibrating out of their setting with use, a couple of drops of loctite took care of that.
-- Philip - Laval, Quebec, Canada
