ShopSmith Vs. Gator 3 X 21, 80 grit sanding belts. Price comparison.
Review by MarkTheFiddler posted 01-28-2013 12:53 AM 13998 views 0 times favorited 14 comments Add to Favorites Watch
ShopSmith Vs. Gator 3 X 21, 80 grit sanding belts. Price comparison. ShopSmith Vs. Gator 3 X 21, 80 grit sanding belts. Price comparison. No-picture-s Click the pictures to enlarge them
ShopSmith sells 4 3X21 Sanding Belts for $17.98 at Lowes
Gator sells 5 3X21 Sanding Belts for $5.98 at Lowes
Figure $4.50 for each ShopSmith Vs. $1.20 per Gator
I used both belts to sand the aluminum oxide finish off hardwood flooring for use in a project. That is some very tough finish. I sanded until I had to apply downward pressure on the belt sander to get a bite. I stopped there. Mind you the flooring finish dulls out the sand paper very quickly.
Take a look at this picture:
The 3 boards at the top of the image were done with the shopsmith paper. I felt I was starting to apply a little force toward the end of the last board. I stopped there and replaced the paper with the gator belt.
The board at the bottom of the image was sanded with the Gator Belt before I was applying more downward pressure than with the ShopSmith brand. That is roughly 1/3 of a board. The ratio thus far was 9 to 1. Because Shopsmith is reversible, I put it back on the belt sander running the opposite direction. There was plenty of grit left to finish the “Gator” board and the Shopsmith belt was still viable if I applied pressure to the sander. That was beyond the scope of the test.
Here is the math:
Each ShopSmith board cost $1.22 to sand (without downward pressure). Honestly, I use my belts much longer than that.
Each Gator Board would have cost $3.60 to sand (without downward pressure).
I’m not sure you will agree with this or not but my opinion is that it cost 3X more to sand with Gator than ShopSmith.
I’ll try other brands for future analysis. I DO want to save a buck and ShopSmith gave me sticker shock. However, Gator turned out to be far too expensive.
-- Thanks for all the lessons!
View MarkTheFiddler's profile
MarkTheFiddler
2068 posts in 2426 days
14 comments so far
View John's profile
John
341 posts in 4035 days
#1 posted 01-28-2013 01:07 AM
excellent review, shows the difference between price and cost, thanks!
-- John - Central PA - http://affyx.wordpress.com
View dustyal's profile
dustyal
1299 posts in 3712 days
#2 posted 01-28-2013 01:31 AM
well done analysis… thanks for posting. I was just in Lowes and saw the Shopsmilth 5 inch ROS disks. They looked impressive but at this time I am stocked up with old stuff. Once gone, I will try Shopsmith. Previously, I was not excited with the Gator.
Your review is strong evidence that you get what you pay for.
-- Al H. - small shop, small projects...
View Radu's profile
Radu
330 posts in 3281 days
#3 posted 01-28-2013 01:56 AM
Thanks for the review / analysis. I’d be interested to see where the red Diablo’s that HD sells, stand.
View 72hw's profile
72hw
88 posts in 2348 days
#4 posted 01-28-2013 02:18 AM
Empirical data – awesome! I have been using Gator brand belts on my Sand Devil and had often wondered about the higher priced belts. Many thanks for taking the time to do this experiment – definitely food for thought!
-- “Weird heroes and mould-breaking champions exist as living proof to those who need it that the tyranny of 'the rat race' is not yet final.” ― Hunter S. Thompson
Shawn Masterson
1325 posts in 2186 days
#5 posted 01-28-2013 02:31 AM
love the test. it just sucks that it is nearly impossible to find a quality product in stores now a days. you have to order it on line.
MarkTheFiddler
#6 posted 01-28-2013 03:14 AM
You all are very welcome.
Radu – I was going to give Diablo and Norton a try. If they cant knock this finish off the flooring like ShopSmith, I can surely use them on something else. I think I can get Norton Belts at Rockler. I don’t remember seeing Diablo belts but it was because I only needed ROS hook and loop discs at the time. They probably carry them.
View gfadvm's profile
gfadvm
14940 posts in 2927 days
#7 posted 01-28-2013 03:56 AM
Good review! And pretty scientific. Try the Norton 3X (not the same as the regular Norton). They outlasted everything else I tried. As a side note: man do you need a drum sander to clean that flooring up!
MarkTheFiddler
#8 posted 01-28-2013 04:56 AM
Will get the Norton 3x Andy. And thanks for the advice on the drum sander. Yet another tool on my list of want to gets. It doesn’t end, does it?
gfadvm
#9 posted 01-28-2013 05:01 AM
Mark- I don’t know how far you are from Tulsa but I saw a 16” dual drum Grizzly drum sander AND a Jet dust collecter on Tulsa CL last night for $700. I damn near bought it and I already have 2 drum sanders and a dust collecter! If you buy my 10-20 Jet, then I can buy that monster!
MarkTheFiddler
#10 posted 01-28-2013 05:07 AM
Sorry Andy – Just pulled the trigger on a Bosch contractor TS. That killed any hope of a budget for a while. About all I can afford is a pair of F-clamps. Good luck with that Grizzly.
Shawn Masterson
#11 posted 01-30-2013 04:26 AM
because of this review I tried the ros paper today. wow it is outstanding. as for the drum sander I just sold one . I had a performax 25×2 It was a monster, took a 4’ x 4’ foot print in my 26×30 shop. when it came to sanding finishes off it seemed to me once the drum got warm the paper gummed really fast. I had 80 on the front and 120 out back. I was sanding some Brazilian cherry I probably sanded 20’ and the front drum was already loadin up. it was amazing for raw stock. thanks for the review I probably would have over looked the paper (price & brand) but cause of you I am sold.
MarkTheFiddler
#12 posted 01-30-2013 05:34 AM
Wow Shawn, I’m humbled! Those are very kind words. I’m really happy this made such an outstanding difference for you.
Mark
View Oakum's profile
Oakum
4 posts in 1877 days
#13 posted 07-09-2015 06:44 AM
The ceramic media you used to cut down the aluminum oxide finish, which is very hard, was the right choice. I’m not sure which type of Gator belts you tried; it may have been aluminum oxide which would be no harder than the aluminum oxide used in the flooring finish… I think Gator also makes products that use ceramic though which would help you to compare apples to apples.
-- Oakum Slocum
MarkTheFiddler
#14 posted 07-10-2015 10:35 PM
Howdy Oakum,
I have noticed a lot of changes in sandpaper during the last few years. Allow me to qualify that, I have seen changes in the offerings at Lowes and other tool stores. Back when I ran these comparisons, there was Gator Garnet and Shopsmith ceramic on the shelves at my local Lowes.
Of course – apples and oranges that are supposed to do the same job are still valid. In terms of efficiency, durability and cost per unit of sanding, I keep getting the same results.
