| Review by ChuckC | posted 121 days ago | 1312 views | 2 times favorited | 18 comments | ![]() |
- Rockler Magnetic Jointer Jig
- Brand: Rockler | Category: Other
I always dread the time when I have to sharpen the blades on my jointer. For some reason I can never get the blades back in just right.
Rockler put this jig on sale from $33 to $25 so I picked it up. When it arrived I was surprised to find that it is all metal, no plastic, and well made (for what it is). Each leg has two magnets on the out feed side and one that picks up the blade.
Using the jig is simple. You have to find TDC for the cutter head and you mark that on the fence. I punched a small line on the fence so I’ll always have it there. You then rotate the blade to the mark on the fence and place the jig over the blade. There’s a mark on the jig that lines up with the mark on the fence and four magnets hold it down. Another two magnets on the jig lift the blade so it is exactly the same height as the out feed table and parallel with the out feed table. Tighten the blade. Repeat two more times and you are done. Total time 15 minutes. Now that I have the TDC marked it will only take 10 minutes going forward.
I ran some wood through and the jointer never cut so well. The jig does what it’s supposed to do so I give it 5 stars.
18 comments so far
Matthew Parker
home | projects | blog
5 posts in 219 days
#1 posted 121 days ago
I have the same jig and totally agree. I paid full price but even then it works so well it was worth it.
ichbinpete
102 posts in 864 days
#2 posted 121 days ago
I got it with a 20% off coupon when I bought it. I only changed my blades twice prior to getting it, and I never got them set right. This product just works.
-- It is better to keep your mouth shut and appear stupid than to open it and remove all doubt.
Richard
357 posts in 864 days
#3 posted 121 days ago
Thanks for the review – I just got a couple of sets of knives for my jointer and was dreading replacing them. I am hitting my local Rockler tomorrow to grab one of these.
-- "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so." - Mark Twain
mbs
971 posts in 1113 days
#4 posted 121 days ago
I’m not trying to be a smart a$$ and I don’t have anything against the jig but to answer your question directly – “Yes, it can get easier than this”. Using a Byrd shelix head is much easier to change “knives”, and, in my opinion, you get a better cut than straight knives provide.
The shelix has small square, carbide inserts than can be rotated 90 degrees to get a fresh edge using nothing more than a screw driver type tool. Probably takes less than 10 seconds. There is no other adjustment necessary.
-- Sorry the reply is so long. I didn't have time to write a short reply.
ChuckC
548 posts in 1108 days
#5 posted 121 days ago
^^ Huh?? This is a review for a jig that assists in setting up straight blades for a jointer. My comment “Can it get any easier than this” was directed at that. It was not my intention to review or compare aftermarket jointer heads.
Enjoy the Byrd…
doordude
862 posts in 1156 days
#6 posted 121 days ago
chuckc great review, i just happened to be in rockler last week and bought the same jig, glad it worked well.
mbs: this jig is 25 bucks and we already have blades in the jionter. the byrd is great but you’re talking about another 200 plus bucks for your solution.
LoydMoore
52 posts in 129 days
#7 posted 120 days ago
quess I am a tightwad. Built my own version for $4.
Six block magnets from Harbor freight and some scrap MDF.
Just make sure everything is clean and no magnetic chips are hanging around. Place three magnets in line 3” apart on the jointer table or granite surface plate. Next place a liberal amount of silicon on each magnet and press the MDF home. The router table or granite plate establish the magnets on a single plane and all the MDF does is hold the magnets in that plane while setting the knives. Make two of these and you have a hybrid version of the Rockler jig for 1/6 the price.
-- Loyd, San Angelo, TX http:www.moorewoodenboxes.com
Jorge G.
1313 posts in 648 days
#8 posted 120 days ago
FWW had an article about what LoydMoore did, I also made mine, two pieces of wood and some magnets and it was done. In any case, for $24 it is a good deal and I would probably have bought it if I had known about it, I am not one for making jigs, my time is more valuable.
-- Just because you’ve always done it that way doesn’t mean it’s not incredibly stupid.
Bsmith
260 posts in 843 days
#9 posted 120 days ago
Thanks Chuck, I’m headed to the Rockler site right now. Hope it’s still on sale.
-- Bryan
ChuckC
#10 posted 120 days ago
If you Google “Rockler coupon code” you can usually dig up a free shipping coupon code.
david_larch
64 posts in 475 days
#11 posted 120 days ago
Just bought this – perfect timing. Thanks for the review I had been waiting to set up my new jointer till work slowed down.
Dusty56
10562 posts in 1861 days
#12 posted 120 days ago
Can it get any easier than this??
Yes , have someone else do it while you go have a beer / coffee / snack / etc.. : )
I bought two Aluminum 9” levels with rare earth magnets (on bottom edge) from Harbor Freight to accomplish this with : )
They were on sale ($7.99) at the time and the price was less than the jig I was going to buy previously.
http://www.harborfreight.com/9-inch-solid-aluminum-level-66617.html
Works pretty slick : )
-- When did quiet and quite become the same word ? I'm guessing about the same time as your and you're did.
Dusty56
#13 posted 120 days ago
oooops .double post : (
Jorge G.
#14 posted 120 days ago
LOL, he said easier not cheaper, huh?
Dusty56
#15 posted 120 days ago
Yes , Jorge . I typed ; Yes , have someone else do it while you go have a beer / coffee / snack / etc.. : ) Easier , no ? LOL
View all comments »
showing 1 through 15 of 18 comments
