Timbermate Woodfiller Review
Review by Kjuly posted 01-22-2013 03:32 PM 10201 views 2 times favorited 9 comments Add to Favorites Watch
Timbermate Woodfiller Review No-picture-s No-picture-s Click the pictures to enlarge them
Woodworkers have a vast selection of wood fillers to choose from. Every paint store, lumber yard, or woodworking supply store sells wood fillers of one type or another. The most common arethe ready to use fillers. Sold in sizes from small squeeze tubes that hold a few ounces to pint cans. I prefer the pint cans as they offer the best value when considering the cost per ounce. I tried the water based fillers and became frustrated with the product drying out before it was used up. I switched to a solvent based filler with moderate success. I still encountered the putty drying out so I added a small amount of lacquer thinner to the can after each use. This reduced the waste considerably but I still could not use the entire can before it became too thick to use. I started buying my wood putty in smaller cans, which costs more per ounce and led to occasionally running out of filler.
In November 2010 our woodworking club, The Mid-Michigan Woodworkers Guild, was introduced to Timbermate. www.timbermate.com A water based wood filler from Australia, also called wood putty.
A representative from Timbermate gave the club a demonstration on the uses of Timbermate. He covered several points on how Timbermate can be used, including thinning it with water for different uses such as grain filling or for filling tiny cracks. It can be applied with a trowel or the traditional putty knife. It takes a stain well and sands very smooth. Other than thinning with water it looks and and acts like the wood filler that we all use. One bit of information that stood out in his presentation is, if Timbermate dries out, it can be reconstituted by adding water. No more waste. We hit the jackpot!! I am going to go out and buy every color that Timbermate makes and use nothing else.
But wait…maybe I should try this product first before spending money on all 13 colors. The Timbermate rep gave our club members a two ounce sample of the natural color. In an effort to give this product an honest review and see if it lives up to the claims put forth by Timbermate’s web site. I took the sample, after all who doesn’t like free samples.
I removed the top of the little plastic container and set it on a shelf next to my shop clock.
After two months here’s what I found .
The putty had dried to the point that I had to dig it out of the container nearly destroying the container in the process. I took the lump of hardened putty and added a small amount of water, kneading it and continuing to add small amounts of water until I had a creamy putty. I then tested the reconstituted filler on several small gouges and cracks on two different boards one Maple and one Walnut. Applying the filler with a putty knife, it spread nicely with no lumps. An hour later it was dry so I sanded it smooth and applied a coat of lacquer. It worked as advertised, now lets try it on some real projects.
Fast forward two years and dozens of projects later, including a custom Cherry kitchen. I found Timbermate’s wood filler to be an excellent choice. It preformed as advertised in most cases and excelled in others. I purchased several colors and white. This gave me the ability to mix the putty to a near perfect match before adding stain. In one case I ran into a snag trying to match Red Oak with just stain and the Natural base. After several unsuccessful attempts, I found it best to add stain to a colored base, in this case I used Spotted Gum/Southern Chestnut, then added small amounts of stain to the putty for a match. On jobs that were finished natural, I found it easy to mix different colors for an exact match.
A real time saver.
While preparing to finish a sofa table, I found a small ding that was missed during final sanding. Faced with re sanding the table and delaying the finishing, I decided to fill the imperfection. After mixing the putty to match, I filled the flaw and then took a small block of wood wrapped with a rag dampened with water. Using light strokes, I smoothed out the patch making it flush with the surface. In ten minutes it was dry with the help of a hair drier and proceeded to finish the table without additional sanding.
Could this be “It” when it comes to wood putty/filler? No, but it will be my first choice.
Keith
-- Keith, Charlotte, MI www.julyswoodworks.com
View Kjuly's profile
Kjuly
308 posts in 3372 days
9 comments so far
View oldretiredjim's profile
oldretiredjim
206 posts in 2472 days
#1 posted 01-22-2013 04:48 PM
my first choice. still working on colors but all my problems are self inflicted. i like the stuff and it is readily available.
117179 posts in 3664 days
#2 posted 01-22-2013 04:55 PM
Thanks for your review.
View smitdog's profile
smitdog
386 posts in 2192 days
#3 posted 01-22-2013 06:05 PM
Nice review. Glad to know I can leave it set on the shelf and bring it back to life when I need it. Perfect for the occasional user!
-- Jarrett - Mount Vernon, Ohio
Kjuly
#4 posted 01-22-2013 06:49 PM
Thanks smitdog,
Evan as a business I don’t use it that often and some colors are rarely used. I buy mine at Woodcraft and every time I stop by, I pick a different color. I don’t have to worry about it going bad while siting on the shelf.
Keith
View Dave G's profile
Dave G
332 posts in 2135 days
#5 posted 01-23-2013 02:05 AM
It acts just like Wunderfil sold by Rockler. The Rockler product smells ok. I like the water based concept and have zero complaints about how it works.. The Timbermate is about 40% less costly than the Wunderfil. I’ll try it!
-- Dave, New England - “We are made to persist. that's how we find out who we are.” ― Tobias Wolff
View jcwalleye's profile
jcwalleye
306 posts in 3160 days
#6 posted 01-23-2013 02:40 AM
Thanks for the review and guidance. When mixing colors to match, does the product change as it dries? What about staining or dyeing after its been applied and dried? Thanks.
-- Trees, a wonderful gift --Joe--
View gfadvm's profile
gfadvm
14940 posts in 2777 days
#7 posted 01-23-2013 02:49 AM
I agree with the 5 stars. It’s the only filler/grain filler I use. I still haven’t tried any of the “natural” base as the colored one have always been pretty close to what I needed. When would you use the “natural” vs. one of the color matched ones?
Kjuly
#8 posted 01-23-2013 01:09 PM
Dave G,
I wasn’t aware of Wunderfil but 40% difference is a big price difference. Speaking of smell, Timbermate smells like a bandage. They add an antiseptic to prevent mold growth.
JCwalleye,
No, the color does not change as it dries. After it has dried, it takes stain and dye very well.
Keith
View 9FINGERTIM's profile
9FINGERTIM
54 posts in 2027 days
#9 posted 03-01-2013 05:49 PM
sounds like a great product I love the concept of colors, some of the puttys that say they take stain dont. for years ive poured a little water in the plastic tub of wood putty and it would be usable the next day.
-- TIM, FLORIDA
