Pretty good compressor
Review by Tedstor posted 12-31-2012 02:22 AM 3913 views 0 times favorited 6 comments Add to Favorites Watch
Pretty good compressor Pretty good compressor Pretty good compressor Click the pictures to enlarge them
!!!!Update 4/17/13. SO I’ve been using this product for several months now. Its been flawless. I’ve used it for nailers, inflation, clean-up, and impact wrenches. It runs them all well. I originally mentioned that I disliked the orientation of the gauges. Senco positioned them facing inboard, rather than outboard. However, that hasn’t proved to be an issue in reality. That said, I take-back that gripe.
Anyway, I just thought I’d re-affirm my admiration of this machine now that the “honeymoon period” is over. It works as advertised, is relatively quiet (for a compressor), and is well-built. !!!!
So for the past few years I’ve been using a cheap, 3 gal pancake compressor. Its had an admirable career, but its always been horribly loud, slightly under-powered for my needs, and its developed an ever-worsening leak. All said, it was time for an upgrade.
I wanted a compressor that was fairly portable and had small dimensions. As much as I’d like a 15-20+ gallon unit, I needed a compressor that can be stored in the smaller nooks/crannies of my garage. Fourish gallons seemed about right.
I considered several options, but I narrowed the search down to the Makita MAC700 and the Senco PC1131. Both had adequate specs, but the Senco was advertised to have slightly more CFM output. Of course, the Makita was advertised to be less noisy due to a larger piston bore and slower motor. I was firmly on the fence between the two (but was starting to lean toward Makita), but availability became the deciding factor. My family (wife and MIL) are die-hard amazon shoppers. When it came time to put a compressor on the amazon xmas wishlist, the Makita was out of stock. So Senco got the nod by default.
I had the chance to use the compressor 5-6 times now. I don’t usually publish reviews of tools until I’ve had it for a few weeks, but I’ve already put the tool through most usual tasks and I don’t think my opinion will change much moving forward (barring breakdown).
Setting this compressor up was a little harder than it should have been. For whatever reason, Senco didn’t ship the unit with the air filter per-installed. The problem is, there is very little room to install the filter housing in the inadequate gap between the tank and compressor unit. I had to disassemble the housing, screw the smaller portion of the housing into the compressor, then muscle-jam the other portion into position. This was certainly not an insumountable problem, but I was a professional mechanic for nearly ten years, so I’ve grown a violent hatred of engineering oversights like this one.
Once set-up…........
It initially fills to 125psi in just under a minute, and recharges in about 15-20 seconds. The regulator and gauges work fine, BUT i hate how the gauges are positioned on the machine. They are oriented inboard, toward the compressor motor (see pics). Not a game changer, but it does make them harder to read. Maybe it better protects the gauges? The product pictured on the Amazon page showed the gauges facing outward. So its a little annoying that the product recieved was different. But admittedly, I probably care more about this detail than most other people would.
Overall performance is fine. Compressors are pretty much a pass/fail tool. It either does what you need it to do, or it doesn’t. This one works well. It charges and recharges quickly (by my standards), and its LESS NOISY than my old oiless pancake. Notice I didn’t say “quiet”. Its not. But being an oil-splash unit, it produces noticably less racket. This is actually the one factor that makes me wish I got the Makita, since it was advertised as being the quietest compressor in the universe. Oh well.
So far, I’ve used the Senco to run trim nailers, tire infaltors, and to blow dust off machines and off the garage floor. Nothing too heavy, but if I expected a compressor to do more, I would’ve got a bigger model. At any rate, the Senco works well. Portability is ok. At 60ish pounds, I wouldn’t want to carry it all day, but its easy enough to position anywhere in my shop/house. Overall fit/finish is good. I had to move the gauge/regulator assembly slightly because the bottom gauge was rubbing against the motor shroud. But that was fixed with a 1/8 turn of a 14mm wrench. Otherwise, no other issues can be noted.
Finally, when you’re done using the Senco, purging the unit is easy enough. There is a pull-ring relief valve mounted near the regulator. And there is a drain valve located on each tank. I actually feel these valves are located a bit too high on the tanks. I’m not sure that water can’t collect at the bottom of the tanks, below the drain valves. And being a oil pump, tipping the machine to allow the water to drain would be ill-advised. I’m not sure if this is even an issue, but it might affect longevity.
Overall, I think I got a decent compressor. There are several compressors available in this class from a number of manufacturers. I don’t see how this one couldn’t be considered a contender among them. At $209, its less expensive than many, while still getting pretty good reviews in most cases.
I hope this helped.
View Tedstor's profile
Tedstor
1643 posts in 2658 days
6 comments so far
View cutworm's profile
cutworm
1075 posts in 2818 days
#1 posted 01-01-2013 01:01 AM
Thanks for the post. Glad it’s doing well. I’m shopping for a new compressor. Mine is getting old. Good info.
-- Steve - "Never Give Up"
View NormG's profile
NormG
6138 posts in 3029 days
#2 posted 01-01-2013 02:04 AM
I am also seeking a compressor, as I have found I am needing one more often that would make task much easier
-- Norman - I never never make a mistake, I just change the design.
View Cato's profile
Cato
701 posts in 3338 days
#3 posted 01-03-2013 07:14 PM
Congrats on your purchase. Glad you got a nice quiet compressor for your shop. They really do come in handy.
I remember looking at the Senco, but when I was building my storage shed I wanted a wheeled compressor at the time.
Senco’s and Makita’s do seem to get high reviews on them and I’m sure are probably way better than pancake models.
I ended up with a Dewalt, wheeled model, that works well and is not too loud even though it is not an oiler model.
I may be wrong on this so others can correct me, but I don’t think you are supposed to use the emergency pressure release as a routine for bleeding off the pressure. I have a ball cock valve on the bottom of my Dewalt and I just slowly open that to bleed off air pressure and moisture when I am done.
Tedstor
#4 posted 01-03-2013 10:12 PM
You’re right about the pull-ring. Poorly written on my part as I make it sound as if its part of the normal purging process.
View bobasaurus's profile
bobasaurus
3483 posts in 3209 days
#5 posted 10-22-2015 07:49 PM
Just bought one of these. Screwing in the air filter was easy, nothing in the way… maybe they changed the design a bit. Gauges are still positioned oddly. Runs pretty noisy but not bad when wearing earmuffs. Mine came with the oil already in it and at the perfect level.
I agree that the drain valves are a little high… I wonder if I should tilt the thing to ensure proper drainage.
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
Tedstor
#6 posted 10-23-2015 03:01 PM
Bob- I tilt mine slightly whenever I think about it. But you obviously have to be careful to not spill the oil from the reservoir.
Three years later with moderate use…....mine is still humming along like new. I’d be thrilled to get 10-15 years out of it.
